Hi everyone , I have to simulate a beam against a plate in different cases of 20 different thickness of the plate. Can i make a sort of loop with macros or in detector construction? Or I have to build different files with 20 different thickness in detector construction and compile and run evereyone divided from the others?
Thank you in advance
You can create a messenger, which you can see implemented in the run and event extended examples. The readme describes what is shown in each and the application developers guide shows this too.
Expanding on what @ParticleTruthSeeker said: There are several ways I came up with to handle this:
Write a messenger which allows you to change the geometry via macro commands, and run a macro loop. You’d need to write such a messenger for that yourself (look into the examples). This is a very “clean”, but involved solution.
Write a C++ loop in DetectorConstruction and stack several slabs with varying thickness in X direction, then move the gun in X direction with a macro loop. This can be implemented fairly easily, but you have to be careful about scattering particles (false positives?) in your analysis step.
Use a bash loop, and sed, awk or similar tools to change your DetectorConstruction source code, and run multiple compilations and simulations in the loop. I think this is also a clean solution. Also usually t_compile << t_sim, i.e. compile time is very small compared to runtime of a simulation, so the recompiling should take an negligible amount of time.
I prefer option 3 because of its simplicity, but your mileage might vary.
Thank you so much, I’ll try these solutions .
