Dose calculation
Hello everyone, I am calculating the deposited dose in the sensitive region of the detector (or, the dose rate, will consider the number of simulated particles and the actual activity scale of the source).
I used the B1: calculating the deposited energy in the sensitive region of the detector and then dividing it by the mass.
Additionally, I am also using the Scorer method, specifically /score/quantity/doseDeposit to calculate the dose.
However, the total deposited dose values obtained from these two methods are not the same.
1E6 events have been simulated, so the statistical error should be small enough.
Has anyone encountered this issue before?
shanhong
