Electron vs. hadron mean free path in single scattering (G4EmStandardPhysicsSS) — different angular threshold?
Geant4 Version:11.4-patch-01
Operating System:Ubuntu 22.04 (Google Colab)
Compiler/Version:geant4-pybind 0.1.3 (prebuilt manylinux wheel)
CMake Version:N/A (prebuilt geant4-pybind wheel, no local CMake build)
I’m measuring the Coulomb-scattering mean free path in Geant4 by using the
single-scattering physics constructor (G4EmStandardPhysicsSS) and fitting the
unscattered fraction P0 vs. target thickness to the Poisson form
P0 = exp(-x/lambda).
For heavy charged particles this gives consistent physics: at 2 GeV/c in
copper, lambda = 161.4 nm for pi- and 161.5 nm for mu- (agreement <0.1%),
and lambda/beta^2 is constant to 1.4% across 0.25-8 GeV/c. This all matches
the expected screened-Coulomb scaling.
Electrons don’t follow this. At 2 GeV/c in copper, lambda(e-) = 60.4 nm vs.
lambda(pi-) = 161.4 nm – a factor of 2.67 at essentially identical beta^2
(0.99515 vs 1.00000). The ratio is:
  • momentum-independent: 0.371-0.374 from 100 MeV/c to 8 GeV/c
  • charge-sign-independent: e+ gives 60.68 nm vs e- 60.43 nm
  • unaffected by /process/msc/UseMottCorrection (verified the parameter
    block changed from 1 to 0; lambda unchanged at 60.25 nm)
  • not consistent with a Z^2-scaling radiative contribution: electrons give
    sigma ~ Z^1.29 vs pions’ Z^1.23 over 10 elements, too close for a
    bremsstrahlung-sized effect, and the ratio lambda_pi/lambda_e shows no
    monotonic Z trend (scatters 2.67-4.18 about ~3.4)
Is the angular threshold theta_S that separates “single scattering” from
“no interaction” defined differently for e-/e+ than for hadrons in
G4EmStandardPhysicsSS – e.g. via different lowest-bin energy or different
handling in the electron vs. hadron single-scattering model classes? That
would be a natural source of a threshold-dependent quantity like lambda
differing between species at fixed beta.
Geometry: thin slab in vacuum, primary scored on the slab-exit boundary
crossing, lambda extracted from a fit of -ln(P0) vs thickness (R^2 > 0.9999
in all cases). Happy to share the full setup if useful.
