Hi guys,
I need your help, if possible.
I used the G4Tubs class to construct a cylinder with a given radius and a given height.
Is it possible to replace the cylinder base (circumference) with an ellipse? Basically, what I need is the same geometry as a cylinder (see fgure below), but I want to replace the circle with an ellipse since I need r (radius) in one dimension and a smaller one in the orthogonal dimension.
Cheers,
Valeria
