Hi all,
I was trying to simulate the energy deposited by the radiations from a radioactive source in a water column. My radioactive source is 252Cf, which gives out neutrons as result of spontaneous fission. The source(yellow colour cube) is enclosed in a stainless steel casing and is placed inside a water body ( blue colour cube).
There are different particles coming out of the source including gamma and neutron. I am using GPS to create the radioactive source 252Cf and I have successfully calculated the total energy deposited in the water column by all the radiations combined. But I want to calculate the energy deposited by each of the primary particles separately(neutrons and gammas separately). Also I want identify the different particles in the water column. I am using a modified version of example B4a and I have made the following changes in my stepping action.
void SteppingAction::UserSteppingAction(const G4Step* step)
auto volume = step->GetPreStepPoint()->GetTouchableHandle()->GetVolume();
G4double neutronEdep=0;
G4double gammaEdep=0;
auto edep = step->GetTotalEnergyDeposit();
if(step->GetTrack()->GetDefinition()==G4Neutron::Neutron()){
neutronEdep=step->GetTotalEnergyDeposit();
else if (step->GetTrack()->GetDefinition()==G4Gamma::Gamma()){
gammaEdep=step->GetTotalEnergyDeposit();
G4Track *track = (G4Track*)(step->GetTrack());
// step length
G4double stepLength = 0.;
if ( step->GetTrack()->GetDefinition()->GetPDGCharge() != 0. ) {
stepLength = step->GetStepLength();
if ( volume == fDetConstruction->GetAbsorberPV() ) {
fEventAction->AddAbs(edep,stepLength);
if ( volume == fDetConstruction->GetGapPV() ) {
G4int pdgcharge=step->GetTrack()->GetDefinition()->GetPDGCharge();
fEventAction->AddGap(edep,neutronEdep,gammaEdep,stepLength,pdgcharge);
Here gap is my sensitive volume. The function AddGap is defined in the EventAction.hh as follows.
class EventAction : public G4UserEventAction
public:
EventAction() = default;
~EventAction() override = default;
void BeginOfEventAction(const G4Event* event) override;
void EndOfEventAction(const G4Event* event) override;
void AddAbs(G4double de, G4double dl);
void AddGap(G4double de, G4double den, G4double deg, G4double dl, G4int i);
private:
G4double fEnergyAbs = 0.;
G4double fEnergyGap = 0.;
G4double fEnergyGapGamma=0.;
G4double fEnergyGapNeutron=0.;
G4double fTrackLAbs = 0.;
G4double fTrackLGap = 0.;
G4int fpdg=0;
// inline functions
inline void EventAction::AddAbs(G4double de, G4double dl) {
fEnergyAbs += de;
fTrackLAbs += dl;
inline void EventAction::AddGap(G4double de, G4double den, G4double deg, G4double dl, G4int i) {
fEnergyGap += de;
fEnergyGapNeutron+=den;
fEnergyGapGamma+=deg;
fTrackLGap += dl;
fpdg=i;
#endif
Also my EventAction.cc looks like this:
void EventAction::BeginOfEventAction(const G4Event* /*event*/)
// initialisation per event
fEnergyAbs = 0.;
fEnergyGap = 0.;
fTrackLAbs = 0.;
fTrackLGap = 0.;
fEnergyGapGamma=0;
fEnergyGapNeutron=0;
fpdg=0;
void EventAction::EndOfEventAction(const G4Event* event)
// Accumulate statistics
// get analysis manager
// fill histograms
analysisManager->FillH1(0, fEnergyAbs);
analysisManager->FillH1(1, fEnergyGap);
analysisManager->FillH1(2, fTrackLAbs);
analysisManager->FillH1(3, fTrackLGap);
analysisManager->FillH1(4, fEnergyGapNeutron);
analysisManager->FillH1(5, fEnergyGapGamma);
// fill ntuple
analysisManager->FillNtupleDColumn(0, fEnergyAbs);
analysisManager->FillNtupleDColumn(1, fEnergyGap);
analysisManager->FillNtupleDColumn(2, fTrackLAbs);
analysisManager->FillNtupleDColumn(3, fTrackLGap);
analysisManager->FillNtupleDColumn(4, fEnergyGapNeutron);
analysisManager->FillNtupleDColumn(5, fEnergyGapGamma);
analysisManager->FillNtupleDColumn(6, fpdg);
analysisManager->AddNtupleRow();
I have saved these ntuples into a root file named B4.root in my runaction.cc, but I think I am not getting the correct values of energy deposited by the neutrons and gammas. The results I got for the total energy deposited, energy deposited by neutrons, energy deposited by gammas and pdg code are as follows
Total
Neutrons
Gammas
PDG code
I am attaching my relevant codes with this post.
RunAction.cc (5.8 KB)
SteppingAction.cc (3.6 KB)
EventAction.cc (4.1 KB)
EventAction.hh (3.4 KB)
Any help with this issue will be greatly appreciated.
Thanks a lot in advance
_Geant4 Version:_11.1.2
_Operating System:_Ubuntu 22.04
