Energy Deposition higher in Plastic Scintillator than primary source
Hello, so I am modifying the TestEm5 example by including a plastic scintillator in its DetectorConstruction.cc file. I noticed that its energy deposition was much higher than the primary muon energy beam. I was wondering if there is some additional physics that needs to be included in the Physics list provided sufficient? I attached the image below for further reference:
Hi, I think I may have figured it out the energy is Kinetic energy given by the gun and doesn’t consider the total energy of particle i.e K.E + Rest. So that still preserves energy conservation.
forget my previous mail …
In 75 cm of scintillateur, muons of 100 MeV are totally absorbed. Then, they decay at rest.
You see the energy of this decay.
Okay, so what I am seeing is the 100 MeV absorbed by muons, and then the muons decay resulting in further energy deposition by its electron and its neutrino?
Yes.
You can run 1 event with tracking/verbose 2
you can also add in your macro /process/inactivate Decay
