I am trying to simulate a radioactive source irradiating a material. I’m fairly new but I’ve managed to run my code based on the B1 and rdecay01 examples. I’ve also included a sensitive detector class, as I am interested in the energy deposit in my target material. In DetectorConstruction.cc, I’ve specified the characteristics of the detector (geometry, shape, location,etc.). When I run it see that all of the secondaries from the radioactive particle do not deposit any energy in the medium.
For example. An electron shows:
- G4Track Information: Particle = anti_nu_e, Track ID = 6, Parent ID = 2
Step# X Y Z KineE dEStep StepLeng TrakLeng Volume Process
0 -1.55 cm -3.22 mm 4.69 cm 1.07 MeV 0 eV 0 fm 0 fm container initStep
1 -1.52 cm -3.11 mm 4.49 cm 1.07 MeV 0 eV 1.97 mm 1.97 mm container Transportation
2 -7.93 mm -726 um 4.9 mm 1.07 MeV 0 eV 4.07 cm 4.27 cm Envelope Transportation
3 -7.69 mm -646 um 3.55 mm 1.07 MeV 0 eV 1.37 mm 4.41 cm chip package Transportation
4 -7.65 mm -634 um 3.35 mm 1.07 MeV 0 eV 204 um 4.43 cm chip silicion Transportation
5 -7.4 mm -554 um 2 mm 1.07 MeV 0 eV 1.37 mm 4.57 cm chip package Transportation
6 -6.68 mm -316 um -2 mm 1.07 MeV 0 eV 4.07 mm 4.97 cm PCB Transportation
7 8.37 cm 2.93 cm -50 cm 1.07 MeV 0 eV 50.7 cm 55.7 cm Envelope Transportation
8 10.2 cm 3.52 cm -60 cm 1.07 MeV 0 eV 10.2 cm 65.9 cm World OutOfWorld
As you can see, “dEStep” is always 0eV. This applies for secondaries I see. Do you have any suggestions why this is the case?
Cheers,
johan
