Error code 400 / init_vis.mac cannot be opened
I finally set up Geant4 (I hope successfully) and I’m trying to run the B1 example. When doing so, I receive the following error pop up information in Geant4:
Geant4 version Name: geant4-11-00-patch-01 [MT] (8-March-2022)
<< in Multi-threaded mode >>
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
Registering graphics systems…
ou have successfully registered the following graphics systems.
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
OpenGLImmediateWin32 (OGLIWin32, OGLI)
OpenGLStoredWin32 (OGLSWin32, OGL, OGLS)
Registering model factories…
ou have successfully registered the following model factories.
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolume
egistered models:
None
Registered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilter
egistered filters:
None
/vis/list" to see available colours.
ERROR: Can not open a macro file <init_vis.mac>. Set macro path with “/control/macroPath” if needed.
------- WWWW ------- G4Exception-START -------- WWWW -------
** G4Exception : UIMAN0123
ommand aborted (400)
rror code : 400
** This is just a warning message. ***
------- WWWW -------- G4Exception-END --------- WWWW -------
/control/saveHistory
/run/verbose 2
Change the default number of threads (in multi-threaded mode)
#/run/numberOfThreads 4
Initialize kernel
/run/initialize
I can see that this above-mentioned file init_vis.mac is in the directory above the b1 execution file. But despite from that I don’t know anything about this error or its solution.
However, in Geant4 I can open a macro via the window and I guess I can run the mac-files in the upper directory, namely init_vis.mac, run1.mac, run2.mac and vis.mac. The init_vis and vis mac-files result in a new window showing visualizations of some geometry and some particles or so. I can also change viewing settings in the window options…
However, is it running as it should or do I have to care about this specific error? If so, how?
Thanks in advance!
I “solved” this via this thread: Error while running exampleB1.exe
Now I’m stuck at this:
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
egistered models:
None
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
egistered filters:
None
/run/verbose 2
→ G4TaskRunManager::ComputeNumberOfTasks() → 0 tasks with 1 events/task…
→ G4TaskRunManager::CreateAndStartWorkers() → Initializing workers…
Visualization setting
/control/execute vis.mac
ERROR: Can not open a macro file <vis.mac>. Set macro path with “/control/macroPath” if needed.
rror code : 400
***** Illegal parameter (0) </control/execute vis.mac> *****
rror code : 400
Although I can still open and run e.g. init_vis.mac which opens a visualized geometry where I can navigate. But the B1 example itself does not work, I guess. However I think init_vis.mac is part of this specific example…
Ok, reading some more lines above the last error I copied the vis.mac file also into the Release folder and now it runs successfully.
Now I have to figure out how to set up and build up all these things on my own… :wink:
