Hello everyone.
I have written a code for simple HPGe detector configuration.
Where I have written codes for
1.hpgeDetectorConstruction
2.hpgePhysicsLists
3.hpgePrimaryActionGenerator
Both header and C++ files. I wrote the main program for this
#include "G4RunManagerFactory.hh"
#include "G4UImanager.hh"
#include "hpgeDetectorConstruction.hh"
#include "hpgePhysicsList00.hh"
#include "hpgeActionInitialization01.hh"
int main()
// construct the default run manager
auto runManager = G4RunManagerFactory::CreateRunManager();
// set mandatory initialization classes
runManager->SetUserInitialization(new hpgeDetectorConstruction);
runManager->SetUserInitialization(new hpgePhysicsList);
runManager->SetUserInitialization(new hpgeActionInitialization);
// initialize G4 kernel
runManager->Initialize();
// get the pointer to the UI manager and set verbosities
G4UImanager* UI = G4UImanager::GetUIpointer();
UI->ApplyCommand("/run/verbose 1");
UI->ApplyCommand("/event/verbose 1");
UI->ApplyCommand("/tracking/verbose 1");
// start a run
int numberOfEvent = 10;
runManager->BeamOn(numberOfEvent);
// job termination
delete runManager;
return 0;
Exactly similar to the code given in the geant4 User Documentation.
Also, I have written the CMakeLists.txt file:
# Setup the project
cmake_minimum_required(VERSION 2.6 FATAL_ERROR)
project(hpge)
# Find Geant4 package, activating all available UI and Vis drivers by default
# You can set WITH_GEANT4_UIVIS to OFF via the command line or ccmake/cmake-gui
# to build a batch mode only executable
option(WITH_GEANT4_UIVIS "Build example with Geant4 UI and Vis drivers" ON)
if(WITH_GEANT4_UIVIS)
else()
find_package(Geant4 REQUIRED)
endif()
# Setup Geant4 include directories and compile definitions
# Setup include directory for this project
include(${Geant4_USE_FILE})
include_directories(${PROJECT_SOURCE_DIR}/include)
# Locate sources and headers for this project
# NB: headers are included so they will show up in IDEs
file(GLOB sources ${PROJECT_SOURCE_DIR}/src/*.cc)
file(GLOB headers ${PROJECT_SOURCE_DIR}/include/*.hh)
# Add the executable, and link it to the Geant4 libraries
add_executable(hpge hpge_main.cc ${sources} ${headers})
target_link_libraries(hpge ${Geant4_LIBRARIES})
# Copy all scripts to the build directory, i.e. the directory in which we
# build hpge. This is so that we can run the executable directly because it
# relies on these scripts being in the current working directory.
set(HPGE_SCRIPT
hepgeDet.in
hpgeDet.out
init_vis.mac
run1.mac
run2.mac
vis.mac
foreach(_script ${HPGE_SCRIPTS})
configure_file(
${PROJECT_SOURCE_DIR}/${_script}
${PROJECT_BINARY_DIR}/${_script}
COPYONLY
endforeach()
# For internal Geant4 use - but has no effect if you build this
# example standalone
add_custom_target(hpge DEPENDS hpge)
# Install the executable to 'bin' directory under CMAKE_INSTALL_PREFIX
install(TARGETS hpgeDet DESTINATION bin)
But when I try to build the make file it shows the error like using the command cmake <path>:
-- The C compiler identification is GNU 9.3.0
-- The CXX compiler identification is GNU 9.3.0
-- Found EXPAT: /usr/lib/x86_64-linux-gnu/libexpat.so (found suitable version "2.2.9", minimum required is "2.2.9")
-- Found XercesC: /usr/lib/x86_64-linux-gnu/libxerces-c.so (found suitable version "3.2.2", minimum required is "3.2.2")
-- Found OpenGL: /usr/lib/x86_64-linux-gnu/libOpenGL.so
CMake Error at CMakeLists.txt:66 (add_custom_target):
add_custom_target cannot create target "hpge" because another target with
the same name already exists. The existing target is an executable created
in source directory "/home/subhrod/G4_project/HPGe_design". See
documentation for policy CMP0002 for more details.
CMake Error at CMakeLists.txt:71 (install):
install TARGETS given target "hpgeDet" which does not exist.
Please guide me towards the fixing of this type of error.
