Error in running the make file
I’m very new to Geant4 so pls bear with my lack of knowledge, I don’t really know how to check the CMake version or the Compiler version. I tried to run the MakeFile by using make command it downloaded upto 8% then gave a lot of error lines, I’m attaching the last few lines output (I believe the make file might be corrupt as the hash didn’t match when running the make command:
make[2]: *** [CMakeFiles/G4NDL.dir/build.make:98: Externals/G4NDL-4.7/src/G4NDL-stamp/G4NDL-download] Error 1
make[1]: *** [CMakeFiles/Makefile2:945: CMakeFiles/G4NDL.dir/all] Error 2
make: *** [Makefile:156: all] Error 2
I ran the ls command and the output seemed alright, I’ll attach that also it might help figure out the problem:
~/geant4-v11.1.3/build$ ls
BuildProducts            G4ModuleAdjacencyList.txt   Makefile                  data
CMakeCPackOptions.cmake  G4ModuleInterfaceMap.csv    Modules                   geant4-config
CMakeCache.txt           G4MotifShim.cmake           README.txt                geant4_module_check.py
CMakeFiles               G4X11Shim.cmake             UseGeant4.cmake           geant4_validate_sources.cmake
CPackConfig.cmake        Geant4Config.cmake          UseGeant4_internal.cmake  geant4make.csh
CPackSourceConfig.cmake  Geant4ConfigVersion.cmake   _source_extras            geant4make.sh
Externals                Geant4LibraryDepends.cmake  cmake_install.cmake       source
G4EXPATShim.cmake        Geant4PackageCache.cmake    cmake_uninstall.cmake     source_package_extras.cmake
G4FreetypeShim.cmake     InstallTreeFiles            cmake_uninstall.cmake.in
G4HDF5Shim.cmake         LICENSE.txt                 cxx_filesystem
Any help is greatly appreciated, thanks.
_Geant4 Version:_11.1.3
_Operating System:_Ubuntu 22.04.5 LTS
This is almost certainly a failure to download the dataset file(s). This can happen if there’s a network interruption. The build can simply be retried, as the downloads will restart.
If the problem persists, you can set the GEANT4_INSTALL_DATA CMake variable to OFF and after installation of the C++ code either:
  1. Use the installed geant4-config script to download/install the data via:
    $ geant4-config --install-datasets
    Run geant4-config --help for more options.
  2. Manually download the datasets and unpack the datasets from here: Download Geant4-11.1.3 - Geant4. See also the Postinstall Setup section of the install guide for locations where to unpack.
