Hi experts.
**I tried to simulate high hadron beams for high energies in the water phantom. **
**I am faced with this error in the terminal. I changed physiclist differently. I used hadronic examples physiclists in geant4 but it didn’t work. **
please help me.
I used Geant4 version 11.01
G4WT0 > G4BinaryLightIonReaction.cc: Cannot correct 4-momentum of cascade particles
G4WT0 >
*** G4Exception : had006
issued by : G4HadronicProcess::PostStepDoIt
In /home/mohaddese/Geant4/source/source/processes/hadronic/models/binary_cascade/src/G4BinaryLightIonReaction.cc, line 220:
===> G4BinaryCasacde::ApplyCollision()
Call for Binary Light Ion Cascade
Target element H Z= 1 A= 1
Unrecoverable error in the method ApplyYourself of tInelastic
TrackID= 1 ParentID= 0 triton
Ekin(GeV)= 1.14029; direction= (0.0120396,-0.0130088,0.999843)
Position(mm)= (2.5781,8.69101,202.828); material G4_WATER
PhysicalVolume
ApplyYourself failed
G4WT0 > G4Track (0x7ff1529b5460) - track ID = 1, parent ID = 0
G4WT0 > Particle type : triton - creator process : not available
G4WT0 > Kinetic energy : 1.14029 GeV - Momentum direction : (0.0120396,-0.0130088,0.999843)
G4WT0 > Step length : 822.879 um - total energy deposit : 242.691 keV
G4WT0 > Pre-step point : (2.56818,8.70175,202.005) - Physical volume : phantom (G4_WATER)
G4WT0 > - defined by : hIoni - step status : 4
G4WT0 > Post-step point : (2.5781,8.69101,202.828) - Physical volume : phantom (G4_WATER)
G4WT0 > - defined by : tInelastic - step status : 4
G4WT0 > *** Note: Step information might not be properly updated.
G4WT0 >
G4WT0 >
G4WT0 > *** G4Exception: Aborting execution ***
CAUGHT SIGNAL: 6 ### address: 0x3ec000028cd, signal = SIGABRT, value = 6, description = abort program (formerly SIGIOT).
Backtrace:
[PID=10445, TID=0][ 0/23]> /usr/lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb) [0x7ff15c38700b]
[PID=10445, TID=0][ 1/23]> /usr/lib/x86_64-linux-gnu/libc.so.6(abort+0x12b) [0x7ff15c366859]
[PID=10445, TID=0][ 2/23]> /home/mohaddese/Geant4/Install/lib/libG4global.so(Z11G4ExceptionPKcS0_19G4ExceptionSeverityS0+0x1117) [0x7ff15c850e87]
[PID=10445, TID=0][ 3/23]> /home/mohaddese/Geant4/Install/lib/libG4global.so(_Z11G4ExceptionPKcS0_19G4ExceptionSeverityRNSt7__cxx1119basic_ostringstreamIcSt11char_traitsIcESaIcEEE+0xa5) [0x7ff15c851025]
[PID=10445, TID=0][ 4/23]> /home/mohaddese/Geant4/Install/lib/libG4processes.so(+0x40c930) [0x7ff15aa31930]
[PID=10445, TID=0][ 5/23]> /home/mohaddese/Geant4/Install/lib/libG4tracking.so(_ZN17G4SteppingManager11InvokePSDIPEm+0x55) [0x7ff15d581b15]
[PID=10445, TID=0][ 6/23]> /home/mohaddese/Geant4/Install/lib/libG4tracking.so(_ZN17G4SteppingManager23InvokePostStepDoItProcsEv+0x8b) [0x7ff15d5822db]
[PID=10445, TID=0][ 7/23]> /home/mohaddese/Geant4/Install/lib/libG4tracking.so(_ZN17G4SteppingManager8SteppingEv+0x46c) [0x7ff15d57e81c]
[PID=10445, TID=0][ 8/23]> /home/mohaddese/Geant4/Install/lib/libG4tracking.so(_ZN17G4TrackingManager15ProcessOneTrackEP7G4Track+0x118) [0x7ff15d594488]
[PID=10445, TID=0][ 9/23]> /home/mohaddese/Geant4/Install/lib/libG4event.so(_ZN14G4EventManager12DoProcessingEP7G4Event+0x893) [0x7ff15d5d5303]
[PID=10445, TID=0][10/23]> /home/mohaddese/Geant4/Install/lib/libG4tasking.so(_ZN22G4WorkerTaskRunManager15ProcessOneEventEi+0x3c) [0x7ff15d74ec1c]
[PID=10445, TID=0][11/23]> /home/mohaddese/Geant4/Install/lib/libG4tasking.so(_ZN22G4WorkerTaskRunManager11DoEventLoopEiPKci+0x17e) [0x7ff15d74eb5e]
[PID=10445, TID=0][12/23]> /home/mohaddese/Geant4/Install/lib/libG4tasking.so(_ZN22G4WorkerTaskRunManager6DoWorkEv+0x15d) [0x7ff15d74eead]
[PID=10445, TID=0][13/23]> /home/mohaddese/Geant4/Install/lib/libG4tasking.so(_ZN22G4TaskRunManagerKernel17ExecuteWorkerTaskEv+0x6a) [0x7ff15d74bd3a]
[PID=10445, TID=0][14/23]> /home/mohaddese/Geant4/Install/lib/libG4tasking.so(+0x3a2d6) [0x7ff15d73b2d6]
[PID=10445, TID=0][15/23]> /home/mohaddese/Geant4/Install/lib/libG4tasking.so(_ZNSt13__future_base13_State_baseV29_M_do_setEPSt8functionIFSt10unique_ptrINS_12_Result_baseENS3_8_DeleterEEvEEPb+0x2d) [0x7ff15d74338d]
[PID=10445, TID=0][16/23]> /usr/lib/x86_64-linux-gnu/libpthread.so.0(+0x114df) [0x7ff1593244df]
[PID=10445, TID=0][17/23]> /home/mohaddese/Geant4/Install/lib/libG4tasking.so(_ZN3PTL4TaskIvJEEclEv+0x12c) [0x7ff15d74350c]
[PID=10445, TID=0][18/23]> /home/mohaddese/Geant4/Install/lib/libG4ptl.so.0(_ZN3PTL10ThreadPool14execute_threadEPNS_14VUserTaskQueueE+0x351) [0x7ff15c7486d1]
[PID=10445, TID=0][19/23]> /home/mohaddese/Geant4/Install/lib/libG4ptl.so.0(_ZN3PTL10ThreadPool12start_threadEPS0_PSt6vectorISt10shared_ptrINS_10ThreadDataEESaIS5_EEl+0x1a3) [0x7ff15c748e33]
[PID=10445, TID=0][20/23]> /usr/lib/x86_64-linux-gnu/libstdc++.so.6(+0xd6df4) [0x7ff15c627df4]
[PID=10445, TID=0][21/23]> /usr/lib/x86_64-linux-gnu/libpthread.so.0(+0x8609) [0x7ff15931b609]
[PID=10445, TID=0][22/23]> /usr/lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7ff15c463353]
: Aborted (Signal sent by tkill() 10445 1004)
Aborted (core dumped)
