Hello, i installed geant4.10.06 on mx linux and when i run example1 i get following:
"Geant4 version Name: geant4-10-06-patch-02 [MT] (29-May-2020)
<< in Multi-threaded mode >>
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
Registering graphics systems…
Current available graphics systems are:
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRep (HepRepXML)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML1FILE (VRML1FILE)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
OpenGLImmediateXm (OGLIXm, OGLIQt_FALLBACK)
OpenGLStoredXm (OGLSXm, OGLSQt_FALLBACK)
OpenGLImmediateX (OGLIX, OGLIQt_FALLBACK, OGLIXm_FALLBACK)
OpenGLStoredX (OGLSX, OGLSQt_FALLBACK, OGLSXm_FALLBACK)
RayTracerX (RayTracerX)
Registering model factories…
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolume
Registered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilter
“/vis/list” to see available colours.
parameter out of range: switch >= 0 && switch <=2
***** Illegal parameter (99) </control/verbose 2> *****
*** G4Exception : UIMAN0123
Command aborted (399)
Error code : 399
-------- WWWW -------- G4Exception-END --------- WWWW -------"
and there is no figure. Bur when i take lines with verbose in comment in init_vis mac i can see the figure but i can’t run commands.
Adding tracking cuts for neutron TimeCut(ns)= 10000 KinEnergyCut(MeV)= 0
phot: for gamma SubType=12 BuildTable=0
LambdaPrime table from 200 keV to 100 TeV in 61 bins
===== EM models for the G4Region DefaultRegionForTheWorld ======
LivermorePhElectric : Emin= 0 eV Emax= 100 TeV SauterGavrila Fluo
compt: for gamma SubType=13 BuildTable=1
Lambda table from 100 eV to 1 MeV, 7 bins/decade, spline: 1
LambdaPrime table from 1 MeV to 100 TeV in 56 bins
MollerBhabha : Emin= 0 eV Emax= 100 TeV
eBrem: for e- SubType=3
dE/dx and range tables from 100 eV to 100 TeV in 84 bins
Lambda tables from threshold to 100 TeV, 7 bins/decade, spline: 1
LPM flag: 1 for E > 1 GeV, VertexHighEnergyTh(GeV)= 100000
eBremSB : Emin= 0 eV Emax= 1 GeV ModifiedTsai
eBremLPM : Emin= 1 GeV Emax= 100 TeV ModifiedTsai
CoulombScat: for e-, integral:1 SubType=1 BuildTable=1
Lambda table from 100 MeV to 100 TeV, 7 bins/decade, spline: 1
ThetaMin§ < Theta(degree) < 180; pLimit(GeV^1)= 0.139531
eCoulombScattering : Emin= 100 MeV Emax= 100 TeV
msc: for e+ SubType= 10
RangeFactor= 0.04, stepLimType: 1, latDisp: 1
UrbanMsc : Emin= 0 eV Emax= 100 MeV Nbins=42 100 eV - 100 MeV
WentzelVIUni : Emin= 100 MeV Emax= 100 TeV Nbins=42 100 MeV - 100 TeV
eIoni: for e+ SubType=2
StepFunction=(0.2, 1 mm), integ: 1, fluct: 1, linLossLim= 0.01
eBrem: for e+ SubType=3
annihil: for e+, integral:1 SubType=5 BuildTable=0
eplus2gg : Emin= 0 eV Emax= 100 TeV
CoulombScat: for e+, integral:1 SubType=1 BuildTable=1
msc: for proton SubType= 10
RangeFactor= 0.2, stepLimType: 0, latDisp: 0
WentzelVIUni : Emin= 0 eV Emax= 100 TeV Nbins=84 100 eV - 100 TeV
hIoni: for proton SubType=2
StepFunction=(0.2, 0.1 mm), integ: 1, fluct: 1, linLossLim= 0.01
Bragg : Emin= 0 eV Emax= 2 MeV
BetheBloch : Emin= 2 MeV Emax= 100 TeV
hBrems: for proton SubType=3
hBrem : Emin= 0 eV Emax= 100 TeV
hPairProd: for proton SubType=4
Sampling table 17x1001; from 7.50618 GeV to 100 TeV
hPairProd : Emin= 0 eV Emax= 100 TeV
CoulombScat: for proton, integral:1 SubType=1 BuildTable=1
Lambda table from threshold to 100 TeV, 7 bins/decade, spline: 1
eCoulombScattering : Emin= 0 eV Emax= 100 TeV
msc: for GenericIon SubType= 10
UrbanMsc : Emin= 0 eV Emax= 100 TeV
ionIoni: for GenericIon SubType=2
StepFunction=(0.2, 0.1 mm), integ: 1, fluct: 1, linLossLim= 0.02
Stopping Power data for 17 ion/material pairs
BraggIon : Emin= 0 eV Emax= 2 MeV
msc: for alpha SubType= 10
UrbanMsc : Emin= 0 eV Emax= 100 TeV Nbins=84 100 eV - 100 TeV
ionIoni: for alpha SubType=2
BraggIon : Emin= 0 eV Emax=7.9452 MeV
BetheBloch : Emin=7.9452 MeV Emax= 100 TeV
msc: for anti_proton SubType= 10
hIoni: for anti_proton SubType=2
ICRU73QO : Emin= 0 eV Emax= 2 MeV
hBrems: for anti_proton SubType=3
hPairProd: for anti_proton SubType=4
CoulombScat: for anti_proton, integral:1 SubType=1 BuildTable=1
msc: for kaon+ SubType= 10
hIoni: for kaon+ SubType=2
Bragg : Emin= 0 eV Emax=1.05231 MeV
BetheBloch : Emin=1.05231 MeV Emax= 100 TeV
hBrems: for kaon+ SubType=3
hPairProd: for kaon+ SubType=4
Sampling table 18x1001; from 3.94942 GeV to 100 TeV
CoulombScat: for kaon+, integral:1 SubType=1 BuildTable=1
msc: for kaon- SubType= 10
hIoni: for kaon- SubType=2
ICRU73QO : Emin= 0 eV Emax=1.05231 MeV
hBrems: for kaon- SubType=3
hPairProd: for kaon- SubType=4
CoulombScat: for kaon-, integral:1 SubType=1 BuildTable=1
Used Lambda table of kaon+
msc: for mu+ SubType= 10
RangeFactor= 0.2, stepLimType: 0, latDisp: 0, polarAngLim(deg)= 180
muIoni: for mu+ SubType=2
Bragg : Emin= 0 eV Emax= 200 keV
BetheBloch : Emin= 200 keV Emax= 1 GeV
MuBetheBloch : Emin= 1 GeV Emax= 100 TeV
muBrems: for mu+ SubType=3
MuBrem : Emin= 0 eV Emax= 100 TeV
muPairProd: for mu+ SubType=4
Sampling table 21x1001; from 1 GeV to 100 TeV
muPairProd : Emin= 0 eV Emax= 100 TeV
CoulombScat: for mu+, integral:1 SubType=1 BuildTable=1
msc: for mu- SubType= 10
muIoni: for mu- SubType=2
ICRU73QO : Emin= 0 eV Emax= 200 keV
muBrems: for mu- SubType=3
muPairProd: for mu- SubType=4
CoulombScat: for mu-, integral:1 SubType=1 BuildTable=1
Used Lambda table of mu+
msc: for pi+ SubType= 10
hIoni: for pi+ SubType=2
Bragg : Emin= 0 eV Emax=297.505 keV
BetheBloch : Emin=297.505 keV Emax= 100 TeV
hBrems: for pi+ SubType=3
hPairProd: for pi+ SubType=4
Sampling table 20x1001; from 1.11656 GeV to 100 TeV
CoulombScat: for pi+, integral:1 SubType=1 BuildTable=1
msc: for pi- SubType= 10
hIoni: for pi- SubType=2
ICRU73QO : Emin= 0 eV Emax=297.505 keV
hBrems: for pi- SubType=3
hPairProd: for pi- SubType=4
CoulombScat: for pi-, integral:1 SubType=1 BuildTable=1
Used Lambda table of pi+
HADRONIC PROCESSES SUMMARY (verbose level 1)
Hadronic Processes for neutron
Process: hadElastic
Model: hElasticCHIPS: 0 eV —> 100 TeV
Cr_sctns: G4NeutronElasticXS: 0 eV —> 100 TeV
Process: neutronInelastic
Model: FTFP: 3 GeV —> 100 TeV
Model: BertiniCascade: 1 GeV —> 6 GeV
Model: Binary Cascade: 0 eV —> 1.5 GeV
Cr_sctns: G4NeutronInelasticXS: 0 eV —> 100 TeV
Process: nCapture
Model: nRadCapture: 0 eV —> 100 TeV
Cr_sctns: G4NeutronCaptureXS: 0 eV —> 100 TeV
Process: nKiller
Hadronic Processes for GenericIon
Process: ionInelastic
Model: Binary Light Ion Cascade: 0 eV /n —> 6 GeV/n
Model: FTFP: 3 GeV/n —> 100 TeV/n
Cr_sctns: Glauber-Gribov Nucl-nucl: 0 eV —> 100 TeV
Process: ionElastic
Model: NNDiffuseElastic: 0 eV /n —> 100 TeV/n
Hadronic Processes for He3
Process: hadElastic
Model: hElasticLHEP: 0 eV /n —> 100 TeV/n
Process: He3Inelastic
Cr_sctns: G4ParticleInelasticXS: 0 eV —> 100 TeV
Hadronic Processes for alpha
Process: hadElastic
Process: alphaInelastic
Hadronic Processes for anti_He3
Process: hadElastic
Model: hElasticLHEP: 0 eV /n —> 100.1 MeV/n
Model: AntiAElastic: 100 MeV/n —> 100 TeV/n
Cr_sctns: AntiAGlauber: 0 eV —> 100 TeV
Process: anti_He3Inelastic
Model: FTFP: 0 eV /n —> 100 TeV/n
Process: hFritiofCaptureAtRest
Hadronic Processes for anti_alpha
Process: hadElastic
Process: anti_alphaInelastic
Hadronic Processes for anti_deuteron
Process: hadElastic
Process: anti_deuteronInelastic
Hadronic Processes for anti_neutron
Process: hadElastic
Model: hElasticLHEP: 0 eV —> 100.1 MeV
Model: AntiAElastic: 100 MeV —> 100 TeV
Process: anti_neutronInelastic
Model: FTFP: 0 eV —> 100 TeV
Hadronic Processes for anti_proton
Process: hadElastic
Process: anti_protonInelastic
Hadronic Processes for anti_triton
Process: hadElastic
Process: anti_tritonInelastic
Hadronic Processes for deuteron
Process: hadElastic
Process: dInelastic
Hadronic Processes for e+
Process: electronNuclear
Model: G4ElectroVDNuclearModel: 0 eV —> 1 PeV
Cr_sctns: ElectroNuclearXS: 0 eV —> 100 TeV
Hadronic Processes for e-
Hadronic Processes for gamma
Process: photonNuclear
Model: BertiniCascade: 0 eV —> 6 GeV
Model: TheoFSGenerator: 3 GeV —> 100 TeV
Cr_sctns: PhotoNuclearXS: 0 eV —> 100 TeV
Hadronic Processes for kaon+
Process: hadElastic
Model: hElasticLHEP: 0 eV —> 100 TeV
Cr_sctns: Glauber-Gribov: 0 eV —> 100 TeV
Process: kaon+Inelastic
Hadronic Processes for kaon-
Process: hadElastic
Process: kaon-Inelastic
Process: hBertiniCaptureAtRest
Hadronic Processes for lambda
Process: hadElastic
Process: lambdaInelastic
Hadronic Processes for mu+
Process: muonNuclear
Model: G4MuonVDNuclearModel: 0 eV —> 1 PeV
Cr_sctns: KokoulinMuonNuclearXS: 0 eV —> 100 TeV
Hadronic Processes for mu-
Process: muMinusCaptureAtRest
Hadronic Processes for pi+
Process: hadElastic
Model: hElasticGlauber: 0 eV —> 100 TeV
Cr_sctns: BarashenkovGlauberGribov: 0 eV —> 100 TeV
Process: pi+Inelastic
Hadronic Processes for pi-
Process: hadElastic
Process: pi-Inelastic
Hadronic Processes for proton
Process: hadElastic
Process: protonInelastic
Hadronic Processes for triton
Process: hadElastic
Process: tInelastic
====== Pre-compound/De-excitation Physics Parameters ========
Type of pre-compound inverse x-section 3
Pre-compound model active 1
Pre-compound excitation low energy (MeV) 0.1
Pre-compound excitation high energy (MeV) 30
Type of de-excitation inverse x-section 3
Type of de-excitation factory Evaporation+GEM
Number of de-excitation channels 68
Min excitation energy (keV) 0.01
Min energy per nucleon for multifragmentation (MeV) 2e+05
Limit excitation energy for Fermi BreakUp (MeV) 20
Level density (1/MeV) 0.075
Use simple level density model 1
Use discrete excitation energy of the residual 0
Time limit for long lived isomeres (ns) 1000
Internal e- conversion flag 1
Store e- internal conversion data 0
Electron internal conversion ID 0
Correlated gamma emission flag 0
Max 2J for sampling of angular correlations 10
Upload data before 1st event for Z < 9
/tracking/storeTrajectory 2
parameter out of range: Store >=0 && Store <= 4
G4TrajectoriesModel:
Event ID (EventID): G4int
Run ID (RunID): G4int
G4SmoothTrajectory:
Track ID (ID): G4int
No. of points (NTP): G4int
PDG Encoding (PDG): G4int
Parent ID (PID): G4int
Particle Name (PN): G4String
G4SmoothTrajectoryPoint:
Visualization verbosity changed to warnings (3) "
