Im trying to generate and record events into a root file. However, it always stops recording at the second last events and closes the root file immediately with this error message showing,
G4WT0 >
event: 9997000
G4WT1 >
event: 9999000
G4WT0 > ### Run 0 end.
G4WT1 > ### Run 0 end.
### Run 0 end.
... write file : 20250715_50x50_GeDet_withInnerShielding_Xe135_Uniform_10M.root - done
... close file : 20250715_50x50_GeDet_withInnerShielding_Xe135_Uniform_10M.root - done
Graphics systems deleted.
Visualization Manager deleting...
*** Break *** segmentation violation
[/usr/lib/system/libsystem_platform.dylib] _sigtramp (no debug info)
[<unknown binary>] (no debug info)
[/usr/lib/system/libsystem_c.dylib] __cxa_finalize_ranges (no debug info)
[/usr/lib/system/libsystem_c.dylib] exit (no debug info)
[/usr/lib/system/libdyld.dylib] dyld4::LibSystemHelpers::getenv(char const*) const (no debug info)
[/usr/lib/dyld] start (no debug info)
Non-critical error: mutex lock failure in ~G4Cache<P15G4HadFinalState>.
If the RunManagerKernel has been deleted, it failed to delete an allocated resource
and this destructor is being called after the statics were destroyed.
Exception: [code: system:22] caught: mutex lock failed: Invalid argument
Also, When I open my Detector geometry executable file, it gives me these waring messages:
G4WT1 > Cr_sctns: Glauber-Gribov Nucl-nucl: 0 eV ---> 25.6 PeV
Process: RadioactiveDecay
ERROR: Can not open a macro file <GPS.mac>. Set macro path with "/control/macroPath" if needed.
*** G4Exception : UIMAN0123
Command aborted (400)
Error code : 400
***** Illegal parameter (0) </control/execute GPS.mac> *****
Error code : 400
But I still can see my detector geometry with no problem.
Alongside, when I close it, I see the exact same error message.
@mkelsey pointed out in this linked post that it might be the error related to Physics list… anyone has idea?
thanks!
Geant4 Version: 11.3.0
Operating System: macOS Sonoma 14.7
Compiler/Version: Apple clang Xcode 16.2
CMake Version: 4.0.3
ROOT Version: 6.36.0
