Hi all,
I am trying to simulate a complex geometry and have relied heavily on GEANT’s visualization tools to ensure that my shapes are in the right place. I mostly use OGL however OGL fails to properly display several of my smaller volumes. In an attempt to visualize these volumes I have turned to RayTracer however, when I run RayTracer I encounter a runtime error which causes a breakdown. The error in questions is:
Point for surface = (-50.1946,58.8054,3.0478)
Surface Normal returned by Solid is not a Unit Vector.
G4Track (0x7fc6c9f79bc0) - track ID = 1, parent ID = 0
Particle type : geantino - creator process : not available
Kinetic energy : 1 GeV - Momentum direction : (-0.852869,-0.150384,-0.5)
Step length : 1 Ang - total energy deposit : 0 eV
Pre-step point : (-50.1946,58.8054,6.3978) - Physical volume : World (Vacuum)
- defined by : Transportation - step status : 1
Post-step point : (-50.1946,58.8054,6.3978) - Physical volume : MountPhys (G4_Al)
*** Note: Step information might not be properly updated.
The point at which this error occurs is close to, but not exactly on, any surface in my simulation. The error occurs ~0.7mm away from the nearest surface which belongs to a mount. The mount is, more or less, a rectangular prism with angled corners. Ive attached this image to help:
The mount is made with several subtraction solids and the error occurs just outside one of the corners.
In the event that it is helpful I have also included my full stack trace. You will see that I have many errors warning about a potential volume overlap. I have used the geometry test to unsure that no such overlap exists. I attribute these errors to the many small curved surfaces in my simulation.
I hope someone can provide some insight into why this is happening and what I can do to fix is. Thank you!
OS: Mac OSX Big Sur (11.3.1)
GEANT Version: 10.07
Compiler: Apple Clang 12.0.5
gabrielbridges@Gabriels-MacBook-Pro DetSim_Build % ./detSim ../macro/ray.g4mac ************************************************************** Geant4 version Name: geant4-10-07-patch-01 (5-February-2021) Copyright : Geant4 Collaboration References : NIM A 506 (2003), 250-303 : IEEE-TNS 53 (2006), 270-278 : NIM A 835 (2016), 186-225 WWW : http://geant4.org/ ************************************************************** Visualization Manager instantiating with verbosity "warnings (3)"... Visualization Manager initialising... Registering graphics systems... You have successfully registered the following graphics systems. Registered graphics systems are: ASCIITree (ATree) DAWNFILE (DAWNFILE) G4HepRep (HepRepXML) G4HepRepFile (HepRepFile) RayTracer (RayTracer) VRML1FILE (VRML1FILE) VRML2FILE (VRML2FILE) gMocrenFile (gMocrenFile) OpenGLImmediateX (OGLIX, OGLI) OpenGLStoredX (OGLSX, OGL, OGLS) Registering model factories... You have successfully registered the following model factories. Registered model factories: generic drawByAttribute drawByCharge drawByOriginVolume drawByParticleID drawByEncounteredVolume Registered models: None Registered filter factories: attributeFilter chargeFilter originVolumeFilter particleFilter encounteredVolumeFilter Registered filters: None You have successfully registered the following user vis actions. Run Duration User Vis Actions: none End of Event User Vis Actions: none End of Run User Vis Actions: none Some /vis commands (optionally) take a string to specify colour. "/vis/list" to see available colours. hInelastic QGSP_BERT Thresholds: 1) between BERT and FTF/P over the interval 3 to 6 GeV. 2) between FTF/P and QGS/P over the interval 12 to 25 GeV. -- quasiElastic: 1 for QGS and 0 for FTF ### Adding tracking cuts for neutron TimeCut(ns)= 10000 KinEnergyCut(MeV)= 0 Issue /vis/viewer/refresh or flush to see effect. Issue /vis/viewer/refresh or flush to see effect. Issue /vis/viewer/refresh or flush to see effect. WARNING: G4RayTracerViewer::DrawView: true orthogonal projection not yet implemented. Doing a "long shot", i.e., a perspective projection with a half field angle of 1e-06 radians. -------- WWWW ------- G4Exception-START -------- WWWW ------- *** G4Exception : GeomNav1002 issued by : G4Navigator::ComputeStep() Stuck Track: potential geometry or navigation problem. Track stuck, not moving for 10 steps. Current phys volume: 'World' - at position : (-7.592987981026624,160.73536123037,-22.83115224108178) in direction: (-0.8528685476877961,-0.1503835390132696,-0.5000000315587532) (local position: (-7.592987981026624,160.73536123037,-22.83115224108178)) (local direction: (-0.8528685476877961,-0.1503835390132696,-0.5000000315587532)). Previous phys volume: 'av_3_impr_1_Pipe_Logical_pv_1' Likely geometry overlap - else navigation problem ! *** Trying to get *unstuck* using a push - expanding step to 1e-07 (mm) ... Potential overlap in geometry ! *** This is just a warning message. *** -------- WWWW -------- G4Exception-END --------- WWWW ------- -------- WWWW ------- G4Exception-START -------- WWWW ------- *** G4Exception : GeomNav1002 issued by : G4Navigator::ComputeStep() Stuck Track: potential geometry or navigation problem. Track stuck, not moving for 10 steps. Current phys volume: 'World' - at position : (-2.379785671687216,161.8992192314643,-22.90566764848796) in direction: (-0.8528685461036258,-0.1503835384366788,-0.5000000344343503) (local position: (-2.379785671687216,161.8992192314643,-22.90566764848796)) (local direction: (-0.8528685461036258,-0.1503835384366788,-0.5000000344343503)). Previous phys volume: 'av_3_impr_1_Pipe_Logical_pv_1' Likely geometry overlap - else navigation problem ! *** Trying to get *unstuck* using a push - expanding step to 1e-07 (mm) ... Potential overlap in geometry ! *** This is just a warning message. *** -------- WWWW -------- G4Exception-END --------- WWWW ------- -------- WWWW ------- G4Exception-START -------- WWWW ------- *** G4Exception : GeomNav1002 issued by : G4Navigator::ComputeStep() Stuck Track: potential geometry or navigation problem. Track stuck, not moving for 10 steps. Current phys volume: 'World' - at position : (3.103988295097679,163.1107862198767,-22.82155863753266) in direction: (-0.8528685445194556,-0.1503835378600881,-0.5000000373099475) (local position: (3.103988295097679,163.1107862198767,-22.82155863753266)) (local direction: (-0.8528685445194556,-0.1503835378600881,-0.5000000373099475)). Previous phys volume: 'av_3_impr_1_Pipe_Logical_pv_1' Likely geometry overlap - else navigation problem ! *** Trying to get *unstuck* using a push - expanding step to 1e-07 (mm) ... Potential overlap in geometry ! *** This is just a warning message. *** -------- WWWW -------- G4Exception-END --------- WWWW ------- -------- WWWW ------- G4Exception-START -------- WWWW ------- *** G4Exception : GeomNav1002 issued by : G4Navigator::ComputeStep() Stuck Track: potential geometry or navigation problem. Track stuck, not moving for 10 steps. Current phys volume: 'World' - at position : (-10.1072858032255,160.7812852067228,-30.56675874430345) in direction: (-0.8528685445194556,-0.1503835378600881,-0.5000000373099475) (local position: (-10.1072858032255,160.7812852067228,-30.56675874430345)) (local direction: (-0.8528685445194556,-0.1503835378600881,-0.5000000373099475)). Previous phys volume: 'av_3_impr_1_Pipe_Logical_pv_1' Likely geometry overlap - else navigation problem ! *** Trying to get *unstuck* using a push - expanding step to 1e-07 (mm) ... Potential overlap in geometry ! *** This is just a warning message. *** -------- WWWW -------- G4Exception-END --------- WWWW ------- -------- WWWW ------- G4Exception-START -------- WWWW ------- *** G4Exception : GeomNav1002 issued by : G4Navigator::ComputeStep() Stuck Track: potential geometry or navigation problem. Track stuck, not moving for 10 steps. Current phys volume: 'World' - at position : (8.803215286136322,161.5856046023567,-23.16750624973193) in direction: (-0.8528685422145476,-0.1503835405280888,-0.5000000404390677) (local position: (8.803215286136322,161.5856046023567,-23.16750624973193)) (local direction: (-0.8528685422145476,-0.1503835405280888,-0.5000000404390677)). Previous phys volume: 'av_3_impr_1_Pipe_Logical_pv_1' Likely geometry overlap - else navigation problem ! *** Trying to get *unstuck* using a push - expanding step to 1e-07 (mm) ... Potential overlap in geometry ! *** This is just a warning message. *** -------- WWWW -------- G4Exception-END --------- WWWW ------- -------- WWWW ------- G4Exception-START -------- WWWW ------- *** G4Exception : GeomNav1002 issued by : G4Navigator::ComputeStep() Stuck Track: potential geometry or navigation problem. Track stuck, not moving for 10 steps. Current phys volume: 'World' - at position : (5.985752888295306,161.088810606893,-24.81926293101152) in direction: (-0.8528685422145476,-0.1503835405280888,-0.5000000404390677) (local position: (5.985752888295306,161.088810606893,-24.81926293101152)) (local direction: (-0.8528685422145476,-0.1503835405280888,-0.5000000404390677)). Previous phys volume: 'av_3_impr_1_Nitrogen_Logical_pv_2' Likely geometry overlap - else navigation problem ! *** Trying to get *unstuck* using a push - expanding step to 1e-07 (mm) ... Potential overlap in geometry ! *** This is just a warning message. *** -------- WWWW -------- G4Exception-END --------- WWWW ------- -------- WWWW ------- G4Exception-START -------- WWWW ------- *** G4Exception : GeomNav1002 issued by : G4Navigator::ComputeStep() Stuck Track: potential geometry or navigation problem. Track stuck, not moving for 10 steps. Current phys volume: 'World' - at position : (11.29028063900637,162.2687717368971,-24.84023809591622) in direction: (-0.8528685406303773,-0.150383539951498,-0.5000000433146647) (local position: (11.29028063900637,162.2687717368971,-24.84023809591622)) (local direction: (-0.8528685406303773,-0.150383539951498,-0.5000000433146647)). Previous phys volume: 'av_3_impr_1_Pipe_Logical_pv_1' Likely geometry overlap - else navigation problem ! *** Trying to get *unstuck* using a push - expanding step to 1e-07 (mm) ... Potential overlap in geometry ! *** This is just a warning message. *** -------- WWWW -------- G4Exception-END --------- WWWW ------- -------- WWWW ------- G4Exception-START -------- WWWW ------- *** G4Exception : GeomNav1002 issued by : G4Navigator::ComputeStep() Stuck Track: potential geometry or navigation problem. Track stuck, not moving for 10 steps. Current phys volume: 'World' - at position : (1.715286432549123,160.580444104695,-30.45364425394817) in direction: (-0.8528685406303773,-0.150383539951498,-0.5000000433146647) (local position: (1.715286432549123,160.580444104695,-30.45364425394817)) (local direction: (-0.8528685406303773,-0.150383539951498,-0.5000000433146647)). Previous phys volume: 'av_3_impr_1_Pipe_Logical_pv_1' Likely geometry overlap - else navigation problem ! *** Trying to get *unstuck* using a push - expanding step to 1e-07 (mm) ... Potential overlap in geometry ! *** This is just a warning message. *** -------- WWWW -------- G4Exception-END --------- WWWW ------- -------- WWWW ------- G4Exception-START -------- WWWW ------- *** G4Exception : GeomNav1002 issued by : G4Navigator::ComputeStep() Stuck Track: potential geometry or navigation problem. Track stuck, not moving for 10 steps. Current phys volume: 'av_3_impr_1_Nitrogen_Logical_pv_2' - at position : (12.01872538125829,159.8671082501723,-28.10034088081228) in direction: (-0.8528685383254693,-0.1503835426194988,-0.5000000464437849) (local position: (12.01872538125829,159.8671082501723,0.05965911918772093)) (local direction: (-0.8528685383254693,-0.1503835426194988,-0.5000000464437849)). Previous phys volume: 'World' Likely geometry overlap - else navigation problem ! *** Trying to get *unstuck* using a push - expanding step to 1e-07 (mm) ... Potential overlap in geometry ! *** This is just a warning message. *** -------- WWWW -------- G4Exception-END --------- WWWW ------- -------- WWWW ------- G4Exception-START -------- WWWW ------- *** G4Exception : GeomNav1002 issued by : G4Navigator::ComputeStep() Stuck Track: potential geometry or navigation problem. Track stuck, not moving for 10 steps. Current phys volume: 'MountPhys' - at position : (-50.19460069661336,58.80539930338663,6.397798206616849) in direction: (-0.8528685610600907,-0.1503836561017843,-0.4999999735327503) (local position: (-50.19460069661336,58.80539930338663,3.047798206616849)) (local direction: (-0.8528685610600907,-0.1503836561017843,-0.4999999735327503)). Previous phys volume: 'World' Likely geometry overlap - else navigation problem ! *** Trying to get *unstuck* using a push - expanding step to 1e-07 (mm) ... Potential overlap in geometry ! *** This is just a warning message. *** -------- WWWW -------- G4Exception-END --------- WWWW ------- -------- EEEE ------- G4Exception-START -------- EEEE ------- *** G4Exception : GeomNav0003 issued by : G4Navigator::GetLocalExitNormal() Parameters of solid: ----------------------------------------------------------- *** Dump for Boolean solid - Mount *** =================================================== Solid type: G4SubtractionSolid Parameters of constituent solids: =========================================================== ----------------------------------------------------------- *** Dump for Boolean solid - Mount *** =================================================== Solid type: G4SubtractionSolid Parameters of constituent solids: =========================================================== ----------------------------------------------------------- *** Dump for Boolean solid - holeCut *** =================================================== Solid type: G4SubtractionSolid Parameters of constituent solids: =========================================================== ----------------------------------------------------------- *** Dump for Boolean solid - cornerCut *** =================================================== Solid type: G4SubtractionSolid Parameters of constituent solids: =========================================================== ----------------------------------------------------------- *** Dump for solid - mountBase *** =================================================== Solid type: G4Box Parameters: half length X: 60 mm half length Y: 60 mm half length Z: 6 mm ----------------------------------------------------------- ----------------------------------------------------------- *** Dump for Displaced solid - placedB *** =================================================== Solid type: G4DisplacedSolid Parameters of constituent solid: =========================================================== ----------------------------------------------------------- *** Dump for solid - Corners *** =================================================== Solid type: G4MultiUnion Parameters: ----------------------------------------------------------- *** Dump for solid - corner *** =================================================== Solid geometry type: G4GenericTrap half length Z: 7 mm list of vertices: #0 vx = 0 mm vy = 0 mm #1 vx = 0 mm vy = -13 mm #2 vx = -13 mm vy = 0 mm #3 vx = 0 mm vy = 0 mm #4 vx = 0 mm vy = 0 mm #5 vx = 0 mm vy = -13 mm #6 vx = -13 mm vy = 0 mm #7 vx = 0 mm vy = 0 mm Translation is (61,61,0) Rotation is : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] ----------------------------------------------------------- *** Dump for solid - corner *** =================================================== Solid geometry type: G4GenericTrap half length Z: 7 mm list of vertices: #0 vx = 0 mm vy = 0 mm #1 vx = 0 mm vy = -13 mm #2 vx = -13 mm vy = 0 mm #3 vx = 0 mm vy = 0 mm #4 vx = 0 mm vy = 0 mm #5 vx = 0 mm vy = -13 mm #6 vx = -13 mm vy = 0 mm #7 vx = 0 mm vy = 0 mm Translation is (-61,61,0) Rotation is : [ ( 6.12323e-17 -1 0) ( 1 6.12323e-17 0) ( 0 0 1) ] ----------------------------------------------------------- *** Dump for solid - corner *** =================================================== Solid geometry type: G4GenericTrap half length Z: 7 mm list of vertices: #0 vx = 0 mm vy = 0 mm #1 vx = 0 mm vy = -13 mm #2 vx = -13 mm vy = 0 mm #3 vx = 0 mm vy = 0 mm #4 vx = 0 mm vy = 0 mm #5 vx = 0 mm vy = -13 mm #6 vx = -13 mm vy = 0 mm #7 vx = 0 mm vy = 0 mm Translation is (-61,-61,0) Rotation is : [ ( -1 -1.22465e-16 -0) ( 1.22465e-16 -1 0) ( 0 0 1) ] ----------------------------------------------------------- *** Dump for solid - corner *** =================================================== Solid geometry type: G4GenericTrap half length Z: 7 mm list of vertices: #0 vx = 0 mm vy = 0 mm #1 vx = 0 mm vy = -13 mm #2 vx = -13 mm vy = 0 mm #3 vx = 0 mm vy = 0 mm #4 vx = 0 mm vy = 0 mm #5 vx = 0 mm vy = -13 mm #6 vx = -13 mm vy = 0 mm #7 vx = 0 mm vy = 0 mm Translation is (61,-61,0) Rotation is : [ ( -1.83697e-16 1 0) ( -1 -1.83697e-16 -0) ( 0 0 1) ] ----------------------------------------------------------- =========================================================== Transformations: Direct transformation - translation : (0,0,0) - rotation : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] =========================================================== =========================================================== ----------------------------------------------------------- *** Dump for Displaced solid - placedB *** =================================================== Solid type: G4DisplacedSolid Parameters of constituent solid: =========================================================== ----------------------------------------------------------- *** Dump for solid - Cavity *** =================================================== Solid type: G4MultiUnion Parameters: ----------------------------------------------------------- *** Dump for solid - hole *** =================================================== Solid type: G4Tubs Parameters: inner radius : 0 mm outer radius : 47.5 mm half length Z: 6 mm starting phi : 0 degrees delta phi : 360 degrees ----------------------------------------------------------- Translation is (0,0,0) Rotation is : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] ----------------------------------------------------------- *** Dump for solid - topCavity *** =================================================== Solid type: G4Cons Parameters: inside -fDz radius: 0 mm outside -fDz radius: 47 mm inside +fDz radius: 0 mm outside +fDz radius: 51 mm half length in Z : 2 mm starting angle of segment: 0 degrees delta angle of segment : 360 degrees ----------------------------------------------------------- Translation is (0,0,4.5) Rotation is : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] ----------------------------------------------------------- *** Dump for solid - botCavity *** =================================================== Solid type: G4Tubs Parameters: inner radius : 0 mm outer radius : 57 mm half length Z: 4 mm starting phi : 0 degrees delta phi : 360 degrees ----------------------------------------------------------- Translation is (0,0,-3) Rotation is : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] ----------------------------------------------------------- =========================================================== Transformations: Direct transformation - translation : (0,0,0) - rotation : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] =========================================================== =========================================================== ----------------------------------------------------------- *** Dump for Displaced solid - placedB *** =================================================== Solid type: G4DisplacedSolid Parameters of constituent solid: =========================================================== ----------------------------------------------------------- *** Dump for solid - notches *** =================================================== Solid type: G4MultiUnion Parameters: ----------------------------------------------------------- *** Dump for solid - topNotch *** =================================================== Solid type: G4Box Parameters: half length X: 30 mm half length Y: 35 mm half length Z: 2.75 mm ----------------------------------------------------------- Translation is (-60,0,4.25) Rotation is : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] ----------------------------------------------------------- *** Dump for solid - botNotch *** =================================================== Solid type: G4Box Parameters: half length X: 4 mm half length Y: 6 mm half length Z: 3 mm ----------------------------------------------------------- Translation is (60,0,-3.5) Rotation is : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] ----------------------------------------------------------- =========================================================== Transformations: Direct transformation - translation : (0,0,0) - rotation : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] =========================================================== =========================================================== ----------------------------------------------------------- *** Dump for Displaced solid - placedB *** =================================================== Solid type: G4DisplacedSolid Parameters of constituent solid: =========================================================== ----------------------------------------------------------- *** Dump for solid - Screws *** =================================================== Solid type: G4MultiUnion Parameters: ----------------------------------------------------------- *** Dump for solid - screw *** =================================================== Solid type: G4Tubs Parameters: inner radius : 0 mm outer radius : 2.65 mm half length Z: 16.325 mm starting phi : 0 degrees delta phi : 360 degrees ----------------------------------------------------------- Translation is (48,48,0) Rotation is : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] ----------------------------------------------------------- *** Dump for solid - screw *** =================================================== Solid type: G4Tubs Parameters: inner radius : 0 mm outer radius : 2.65 mm half length Z: 16.325 mm starting phi : 0 degrees delta phi : 360 degrees ----------------------------------------------------------- Translation is (48,-48,0) Rotation is : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] ----------------------------------------------------------- *** Dump for solid - screw *** =================================================== Solid type: G4Tubs Parameters: inner radius : 0 mm outer radius : 2.65 mm half length Z: 16.325 mm starting phi : 0 degrees delta phi : 360 degrees ----------------------------------------------------------- Translation is (-48,48,0) Rotation is : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] ----------------------------------------------------------- *** Dump for solid - screw *** =================================================== Solid type: G4Tubs Parameters: inner radius : 0 mm outer radius : 2.65 mm half length Z: 16.325 mm starting phi : 0 degrees delta phi : 360 degrees ----------------------------------------------------------- Translation is (-48,-48,0) Rotation is : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] ----------------------------------------------------------- =========================================================== Transformations: Direct transformation - translation : (0,0,0) - rotation : [ ( 1 0 0) ( 0 1 0) ( 0 0 1) ] =========================================================== =========================================================== Point for surface = (-50.1946,58.8054,3.0478) Surface Normal returned by Solid is not a Unit Vector. *** Fatal Exception *** core dump *** G4Track (0x7fc6c9f79bc0) - track ID = 1, parent ID = 0 Particle type : geantino - creator process : not available Kinetic energy : 1 GeV - Momentum direction : (-0.852869,-0.150384,-0.5) Step length : 1 Ang - total energy deposit : 0 eV Pre-step point : (-50.1946,58.8054,6.3978) - Physical volume : World (Vacuum) - defined by : Transportation - step status : 1 Post-step point : (-50.1946,58.8054,6.3978) - Physical volume : MountPhys (G4_Al) - defined by : Transportation - step status : 1 *** Note: Step information might not be properly updated. -------- EEEE -------- G4Exception-END --------- EEEE ------- *** G4Exception: Aborting execution *** zsh: abort ./detSim ../macro/ray.g4mac
