/Library/Developer/CommandLineTools/usr/bin/clang++ -DG4LIB_BUILD_DLL -DG4UI_USE_QT -DG4UI_USE_TCSH -DG4VIS_USE_OPENGL -DG4VIS_USE_OPENGLQT -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NO_DEBUG -DQT_OPENGL_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -I/Users/edwardt/Documents/RE02_sensitivity_test/include -isystem /usr/local/Geant4/include/Geant4 -iframework /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk/System/Library/Frameworks -iframework /opt/homebrew/opt/qt5/lib -isystem /opt/homebrew/opt/qt5/lib/QtGui.framework/Headers -isystem /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk/System/Library/Frameworks/OpenGL.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtCore.framework/Headers -isystem /opt/homebrew/opt/qt5/./mkspecs/macx-clang-arm64 -isystem /opt/homebrew/opt/qt5/lib/QtOpenGL.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtWidgets.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtPrintSupport.framework/Headers -W -Wall -pedantic -Wno-non-virtual-dtor -Wno-long-long -Wwrite-strings -Wpointer-arith -Woverloaded-virtual -Wno-variadic-macros -Wshadow -pipe -Qunused-arguments -DGL_SILENCE_DEPRECATION -pthread -ftls-model=initial-exec -std=c++17 -O3 -DNDEBUG -fno-trapping-math -ftree-vectorize -fno-math-errno -O3 -DNDEBUG -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk -fPIC -std=gnu++17 -MD -MT CMakeFiles/RE02.dir/src/RE02PSPassageCellFlux.cc.o -MF CMakeFiles/RE02.dir/src/RE02PSPassageCellFlux.cc.o.d -o CMakeFiles/RE02.dir/src/RE02PSPassageCellFlux.cc.o -c /Users/edwardt/Documents/RE02_sensitivity_test/src/RE02PSPassageCellFlux.cc
/Library/Developer/CommandLineTools/usr/bin/clang++ -DG4LIB_BUILD_DLL -DG4UI_USE_QT -DG4UI_USE_TCSH -DG4VIS_USE_OPENGL -DG4VIS_USE_OPENGLQT -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NO_DEBUG -DQT_OPENGL_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -I/Users/edwardt/Documents/RE02_sensitivity_test/include -isystem /usr/local/Geant4/include/Geant4 -iframework /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk/System/Library/Frameworks -iframework /opt/homebrew/opt/qt5/lib -isystem /opt/homebrew/opt/qt5/lib/QtGui.framework/Headers -isystem /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk/System/Library/Frameworks/OpenGL.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtCore.framework/Headers -isystem /opt/homebrew/opt/qt5/./mkspecs/macx-clang-arm64 -isystem /opt/homebrew/opt/qt5/lib/QtOpenGL.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtWidgets.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtPrintSupport.framework/Headers -W -Wall -pedantic -Wno-non-virtual-dtor -Wno-long-long -Wwrite-strings -Wpointer-arith -Woverloaded-virtual -Wno-variadic-macros -Wshadow -pipe -Qunused-arguments -DGL_SILENCE_DEPRECATION -pthread -ftls-model=initial-exec -std=c++17 -O3 -DNDEBUG -fno-trapping-math -ftree-vectorize -fno-math-errno -O3 -DNDEBUG -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk -fPIC -std=gnu++17 -MD -MT CMakeFiles/RE02.dir/src/RE02Physics.cc.o -MF CMakeFiles/RE02.dir/src/RE02Physics.cc.o.d -o CMakeFiles/RE02.dir/src/RE02Physics.cc.o -c /Users/edwardt/Documents/RE02_sensitivity_test/src/RE02Physics.cc
15 warnings generated.
[ 86%] e[32mBuilding CXX object CMakeFiles/RE02.dir/src/RE02PrimaryGeneratorAction.cc.oe[0m
/Library/Developer/CommandLineTools/usr/bin/clang++ -DG4LIB_BUILD_DLL -DG4UI_USE_QT -DG4UI_USE_TCSH -DG4VIS_USE_OPENGL -DG4VIS_USE_OPENGLQT -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NO_DEBUG -DQT_OPENGL_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -I/Users/edwardt/Documents/RE02_sensitivity_test/include -isystem /usr/local/Geant4/include/Geant4 -iframework /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk/System/Library/Frameworks -iframework /opt/homebrew/opt/qt5/lib -isystem /opt/homebrew/opt/qt5/lib/QtGui.framework/Headers -isystem /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk/System/Library/Frameworks/OpenGL.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtCore.framework/Headers -isystem /opt/homebrew/opt/qt5/./mkspecs/macx-clang-arm64 -isystem /opt/homebrew/opt/qt5/lib/QtOpenGL.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtWidgets.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtPrintSupport.framework/Headers -W -Wall -pedantic -Wno-non-virtual-dtor -Wno-long-long -Wwrite-strings -Wpointer-arith -Woverloaded-virtual -Wno-variadic-macros -Wshadow -pipe -Qunused-arguments -DGL_SILENCE_DEPRECATION -pthread -ftls-model=initial-exec -std=c++17 -O3 -DNDEBUG -fno-trapping-math -ftree-vectorize -fno-math-errno -O3 -DNDEBUG -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk -fPIC -std=gnu++17 -MD -MT CMakeFiles/RE02.dir/src/RE02PrimaryGeneratorAction.cc.o -MF CMakeFiles/RE02.dir/src/RE02PrimaryGeneratorAction.cc.o.d -o CMakeFiles/RE02.dir/src/RE02PrimaryGeneratorAction.cc.o -c /Users/edwardt/Documents/RE02_sensitivity_test/src/RE02PrimaryGeneratorAction.cc
[ 90%] e[32mBuilding CXX object CMakeFiles/RE02.dir/src/RE02Run.cc.oe[0m
/Library/Developer/CommandLineTools/usr/bin/clang++ -DG4LIB_BUILD_DLL -DG4UI_USE_QT -DG4UI_USE_TCSH -DG4VIS_USE_OPENGL -DG4VIS_USE_OPENGLQT -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NO_DEBUG -DQT_OPENGL_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -I/Users/edwardt/Documents/RE02_sensitivity_test/include -isystem /usr/local/Geant4/include/Geant4 -iframework /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk/System/Library/Frameworks -iframework /opt/homebrew/opt/qt5/lib -isystem /opt/homebrew/opt/qt5/lib/QtGui.framework/Headers -isystem /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk/System/Library/Frameworks/OpenGL.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtCore.framework/Headers -isystem /opt/homebrew/opt/qt5/./mkspecs/macx-clang-arm64 -isystem /opt/homebrew/opt/qt5/lib/QtOpenGL.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtWidgets.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtPrintSupport.framework/Headers -W -Wall -pedantic -Wno-non-virtual-dtor -Wno-long-long -Wwrite-strings -Wpointer-arith -Woverloaded-virtual -Wno-variadic-macros -Wshadow -pipe -Qunused-arguments -DGL_SILENCE_DEPRECATION -pthread -ftls-model=initial-exec -std=c++17 -O3 -DNDEBUG -fno-trapping-math -ftree-vectorize -fno-math-errno -O3 -DNDEBUG -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk -fPIC -std=gnu++17 -MD -MT CMakeFiles/RE02.dir/src/RE02Run.cc.o -MF CMakeFiles/RE02.dir/src/RE02Run.cc.o.d -o CMakeFiles/RE02.dir/src/RE02Run.cc.o -c /Users/edwardt/Documents/RE02_sensitivity_test/src/RE02Run.cc
[ 95%] e[32mBuilding CXX object CMakeFiles/RE02.dir/src/RE02RunAction.cc.oe[0m
/Library/Developer/CommandLineTools/usr/bin/clang++ -DG4LIB_BUILD_DLL -DG4UI_USE_QT -DG4UI_USE_TCSH -DG4VIS_USE_OPENGL -DG4VIS_USE_OPENGLQT -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NO_DEBUG -DQT_OPENGL_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -I/Users/edwardt/Documents/RE02_sensitivity_test/include -isystem /usr/local/Geant4/include/Geant4 -iframework /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk/System/Library/Frameworks -iframework /opt/homebrew/opt/qt5/lib -isystem /opt/homebrew/opt/qt5/lib/QtGui.framework/Headers -isystem /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk/System/Library/Frameworks/OpenGL.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtCore.framework/Headers -isystem /opt/homebrew/opt/qt5/./mkspecs/macx-clang-arm64 -isystem /opt/homebrew/opt/qt5/lib/QtOpenGL.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtWidgets.framework/Headers -isystem /opt/homebrew/opt/qt5/lib/QtPrintSupport.framework/Headers -W -Wall -pedantic -Wno-non-virtual-dtor -Wno-long-long -Wwrite-strings -Wpointer-arith -Woverloaded-virtual -Wno-variadic-macros -Wshadow -pipe -Qunused-arguments -DGL_SILENCE_DEPRECATION -pthread -ftls-model=initial-exec -std=c++17 -O3 -DNDEBUG -fno-trapping-math -ftree-vectorize -fno-math-errno -O3 -DNDEBUG -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk -fPIC -std=gnu++17 -MD -MT CMakeFiles/RE02.dir/src/RE02RunAction.cc.o -MF CMakeFiles/RE02.dir/src/RE02RunAction.cc.o.d -o CMakeFiles/RE02.dir/src/RE02RunAction.cc.o -c /Users/edwardt/Documents/RE02_sensitivity_test/src/RE02RunAction.cc
3 warnings generated.
[100%] e[32me[1mLinking CXX executable RE02e[0m
/Applications/CMake.app/Contents/bin/cmake -E cmake_link_script CMakeFiles/RE02.dir/link.txt --verbose=1
/Library/Developer/CommandLineTools/usr/bin/clang++ -W -Wall -pedantic -Wno-non-virtual-dtor -Wno-long-long -Wwrite-strings -Wpointer-arith -Woverloaded-virtual -Wno-variadic-macros -Wshadow -pipe -Qunused-arguments -DGL_SILENCE_DEPRECATION -pthread -ftls-model=initial-exec -std=c++17 -O3 -DNDEBUG -fno-trapping-math -ftree-vectorize -fno-math-errno -O3 -DNDEBUG -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk -Wl,-search_paths_first -Wl,-headerpad_max_install_names -L/opt/homebrew/opt/qt@5/lib CMakeFiles/RE02.dir/RE02.cc.o CMakeFiles/RE02.dir/src/G4PSFlatSurfaceCircularCurrent.cc.o CMakeFiles/RE02.dir/src/G4PSFlatSurfaceCircularFlux.cc.o CMakeFiles/RE02.dir/src/Multifoil_Parameterisation.cc.o CMakeFiles/RE02.dir/src/Multitube_Parameterisation.cc.o CMakeFiles/RE02.dir/src/RE02ActionInitialization.cc.o CMakeFiles/RE02.dir/src/RE02DetectorConstruction.cc.o CMakeFiles/RE02.dir/src/RE02EventAction.cc.o CMakeFiles/RE02.dir/src/RE02MFPSFlatSurfaceCurrent.cc.o CMakeFiles/RE02.dir/src/RE02MFPSFlatSurfaceFlux.cc.o CMakeFiles/RE02.dir/src/RE02NestedPhantomParameterisation.cc.o CMakeFiles/RE02.dir/src/RE02PSCellFlux.cc.o CMakeFiles/RE02.dir/src/RE02PSEnergyDeposit.cc.o CMakeFiles/RE02.dir/src/RE02PSFlatSurfaceCurrent.cc.o CMakeFiles/RE02.dir/src/RE02PSFlatSurfaceFlux.cc.o CMakeFiles/RE02.dir/src/RE02PSNofStep.cc.o CMakeFiles/RE02.dir/src/RE02PSPassageCellFlux.cc.o CMakeFiles/RE02.dir/src/RE02Physics.cc.o CMakeFiles/RE02.dir/src/RE02PrimaryGeneratorAction.cc.o CMakeFiles/RE02.dir/src/RE02Run.cc.o CMakeFiles/RE02.dir/src/RE02RunAction.cc.o -o RE02 -F/opt/homebrew/opt/qt5/lib -Wl,-rpath,/usr/local/Geant4/lib /usr/local/Geant4/lib/libG4Tree.dylib /usr/local/Geant4/lib/libG4FR.dylib /usr/local/Geant4/lib/libG4GMocren.dylib /usr/local/Geant4/lib/libG4visHepRep.dylib /usr/local/Geant4/lib/libG4RayTracer.dylib /usr/local/Geant4/lib/libG4VRML.dylib /usr/local/Geant4/lib/libG4OpenGL.dylib /usr/local/Geant4/lib/libG4gl2ps.dylib /usr/local/Geant4/lib/libG4vis_management.dylib /usr/local/Geant4/lib/libG4modeling.dylib /usr/local/Geant4/lib/libG4interfaces.dylib /usr/local/Geant4/lib/libG4persistency.dylib /usr/local/Geant4/lib/libG4error_propagation.dylib /usr/local/Geant4/lib/libG4readout.dylib /usr/local/Geant4/lib/libG4physicslists.dylib /usr/local/Geant4/lib/libG4tasking.dylib /usr/local/Geant4/lib/libG4parmodels.dylib /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk/System/Library/Frameworks/OpenGL.framework/OpenGL.tbd /opt/homebrew/opt/qt5/lib/QtOpenGL.framework/QtOpenGL /opt/homebrew/opt/qt5/lib/QtPrintSupport.framework/QtPrintSupport /opt/homebrew/opt/qt5/lib/QtWidgets.framework/QtWidgets /opt/homebrew/opt/qt5/lib/QtGui.framework/QtGui /opt/homebrew/opt/qt5/lib/QtCore.framework/QtCore /usr/local/Geant4/lib/libG4run.dylib /usr/local/Geant4/lib/libG4event.dylib /usr/local/Geant4/lib/libG4tracking.dylib /usr/local/Geant4/lib/libG4processes.dylib /usr/local/Geant4/lib/libG4analysis.dylib /usr/local/Geant4/lib/libG4tools.dylib /Library/Developer/CommandLineTools/SDKs/MacOSX12.3.sdk/usr/lib/libexpat.tbd /usr/local/Geant4/lib/libG4digits_hits.dylib /usr/local/Geant4/lib/libG4track.dylib /usr/local/Geant4/lib/libG4particles.dylib /usr/local/Geant4/lib/libG4geometry.dylib /usr/local/Geant4/lib/libG4materials.dylib /usr/local/Geant4/lib/libG4zlib.dylib /usr/local/Geant4/lib/libG4graphics_reps.dylib /usr/local/Geant4/lib/libG4intercoms.dylib /usr/local/Geant4/lib/libG4global.dylib /usr/local/Geant4/lib/libG4clhep.dylib /usr/local/Geant4/lib/libG4ptl.0.0.2.dylib
ld: warning: ignoring file /usr/local/Geant4/lib/libG4Tree.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4FR.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4GMocren.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4visHepRep.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4VRML.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4gl2ps.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4RayTracer.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4OpenGL.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4vis_management.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4modeling.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4readout.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4interfaces.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4parmodels.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4persistency.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4physicslists.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4tasking.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4error_propagation.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4run.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /opt/homebrew/opt/qt5/lib/QtOpenGL.framework/QtOpenGL, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4tracking.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /opt/homebrew/opt/qt5/lib/QtCore.framework/QtCore, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /opt/homebrew/opt/qt5/lib/QtWidgets.framework/QtWidgets, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /opt/homebrew/opt/qt5/lib/QtGui.framework/QtGui, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4event.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /opt/homebrew/opt/qt5/lib/QtPrintSupport.framework/QtPrintSupport, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4processes.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4analysis.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4digits_hits.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4track.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4tools.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4particles.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4materials.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4graphics_reps.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4geometry.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4intercoms.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4global.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4zlib.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4clhep.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
ld: warning: ignoring file /usr/local/Geant4/lib/libG4ptl.0.0.2.dylib, building for macOS-x86_64 but attempting to link with file built for macOS-arm64
Undefined symbols for architecture x86_64:
"G4Exception(char const*, char const*, G4ExceptionSeverity, std::__1::basic_ostringstream<char, std::__1::char_traits<char>, std::__1::allocator<char> >&)", referenced from:
G4Tubs::SetOuterRadius(double) in Multifoil_Parameterisation.cc.o
G4Tubs::SetZHalfLength(double) in Multifoil_Parameterisation.cc.o
G4Tubs::SetInnerRadius(double) in Multitube_Parameterisation.cc.o
G4Tubs::SetOuterRadius(double) in Multitube_Parameterisation.cc.o
G4Tubs::SetZHalfLength(double) in Multitube_Parameterisation.cc.o
"G4Exception(char const*, char const*, G4ExceptionSeverity, char const*)", referenced from:
G4PSFlatSurfaceCircularCurrent::SetUnit(G4String const&) in G4PSFlatSurfaceCircularCurrent.cc.o
G4PSFlatSurfaceCircularFlux::SetUnit(G4String const&) in G4PSFlatSurfaceCircularFlux.cc.o
"aCountedObjectAllocator()", referenced from:
G4PSFlatSurfaceCircularCurrent::ProcessHits(G4Step*, G4TouchableHistory*) in G4PSFlatSurfaceCircularCurrent.cc.o
G4PSFlatSurfaceCircularCurrent::IsSelectedSurface(G4Step*, G4Tubs*) in G4PSFlatSurfaceCircularCurrent.cc.o
G4PSFlatSurfaceCircularFlux::ProcessHits(G4Step*, G4TouchableHistory*) in G4PSFlatSurfaceCircularFlux.cc.o
G4PSFlatSurfaceCircularFlux::IsSelectedSurface(G4Step*, G4Tubs*) in G4PSFlatSurfaceCircularFlux.cc.o
"_G4cout_p()", referenced from:
G4PSFlatSurfaceCircularCurrent::PrintAll() in G4PSFlatSurfaceCircularCurrent.cc.o
G4VTHitsMap<double, std::__1::map<int, double*, std::__1::less<int>, std::__1::allocator<std::__1::pair<int const, double*> > > >::PrintAllHits() in G4PSFlatSurfaceCircularCurrent.cc.o
G4PSFlatSurfaceCircularFlux::PrintAll() in G4PSFlatSurfaceCircularFlux.cc.o
G4VTHitsMap<double, std::__1::map<int, double*, std::__1::less<int>, std::__1::allocator<std::__1::pair<int const, double*> > > >::PrintAllHits() in G4PSFlatSurfaceCircularFlux.cc.o
Multifoil_Parameterisation::PrintParams() in Multifoil_Parameterisation.cc.o
RE02PSFlatSurfaceCurrent::GetIndex(G4Step*) in RE02PSFlatSurfaceCurrent.cc.o
RE02Run::RecordEvent(G4Event const*) in RE02Run.cc.o
"G4DAWNFILE::G4DAWNFILE()", referenced from:
G4VisExecutive::RegisterGraphicsSystems() in RE02.cc.o
"G4Material::AddMaterial(G4Material*, double)", referenced from:
RE02DetectorConstruction::Construct() in RE02DetectorConstruction.cc.o
"G4Material::GetMaterial(G4String const&, bool)", referenced from:
"G4Material::G4Material(G4String const&, double, int, G4State, double, double)", referenced from:
"G4ASCIITree::G4ASCIITree()", referenced from:
"G4PSNofStep::EndOfEvent(G4HCofThisEvent*)", referenced from:
vtable for RE02PSNofStep in RE02PSNofStep.cc.o
"G4PSNofStep::Initialize(G4HCofThisEvent*)", referenced from:
"G4PSNofStep::ProcessHits(G4Step*, G4TouchableHistory*)", referenced from:
"G4PSNofStep::clear()", referenced from:
"G4PSNofStep::DrawAll()", referenced from:
"G4PSNofStep::SetUnit(G4String const&)", referenced from:
"G4PSNofStep::PrintAll()", referenced from:
"G4PSNofStep::G4PSNofStep(G4String, int)", referenced from:
RE02PSNofStep::RE02PSNofStep(G4String, int, int, int) in RE02PSNofStep.cc.o
"G4PSNofStep::~G4PSNofStep()", referenced from:
RE02PSNofStep::~RE02PSNofStep() in RE02PSNofStep.cc.o
"G4RayTracer::G4RayTracer()", referenced from:
"G4SDManager::GetSDMpointer()", referenced from:
RE02DetectorConstruction::ConstructSDandField() in RE02DetectorConstruction.cc.o
RE02Run::RE02Run(std::__1::vector<G4String, std::__1::allocator<G4String> >) in RE02Run.cc.o
"G4SDManager::AddNewDetector(G4VSensitiveDetector*)", referenced from:
"G4SDManager::GetCollectionID(G4String)", referenced from:
"G4SDManager::FindSensitiveDetector(G4String, bool)", referenced from:
"G4Threading::G4GetNumberOfCores()", referenced from:
_main in RE02.cc.o
"G4UImanager::ApplyCommand(G4String const&)", referenced from:
_main in RE02.cc.o
"G4UImanager::GetUIpointer()", referenced from:
_main in RE02.cc.o
"G4VRML2File::G4VRML2File()", referenced from:
"G4HepRepFile::G4HepRepFile()", referenced from:
"G4PSCellFlux::EndOfEvent(G4HCofThisEvent*)", referenced from:
vtable for RE02PSCellFlux in RE02PSCellFlux.cc.o
"G4PSCellFlux::Initialize(G4HCofThisEvent*)", referenced from:
"G4PSCellFlux::ProcessHits(G4Step*, G4TouchableHistory*)", referenced from:
"G4PSCellFlux::ComputeVolume(G4Step*, int)", referenced from:
"G4PSCellFlux::DefineUnitAndCategory()", referenced from:
"G4PSCellFlux::clear()", referenced from:
"G4PSCellFlux::DrawAll()", referenced from:
"G4PSCellFlux::SetUnit(G4String const&)", referenced from:
"G4PSCellFlux::PrintAll()", referenced from:
"G4PSCellFlux::G4PSCellFlux(G4String, int)", referenced from:
RE02PSCellFlux::RE02PSCellFlux(G4String, int, int, int) in RE02PSCellFlux.cc.o
"G4PSCellFlux::~G4PSCellFlux()", referenced from:
RE02PSCellFlux::~RE02PSCellFlux() in RE02PSCellFlux.cc.o
"G4RunManager::GetRunManager()", referenced from:
RE02RunAction::EndOfRunAction(G4Run const*) in RE02RunAction.cc.o
"G4VisManager::FilterDigi(G4VDigi const&)", referenced from:
vtable for G4VisExecutive in RE02.cc.o
"G4VisManager::Initialise()", referenced from:
_main in RE02.cc.o
"G4VisManager::BeginDraw2D(HepGeom::Transform3D const&)", referenced from:
"G4VisManager::NotifyHandlers()", referenced from:
"G4VisManager::DispatchToModel(G4VTrajectory const&)", referenced from:
"G4VisManager::SetUpForAThread()", referenced from:
"G4VisManager::FilterTrajectory(G4VTrajectory const&)", referenced from:
"G4VisManager::GeometryHasChanged()", referenced from:
"G4VisManager::IgnoreStateChanges(bool)", referenced from:
"G4VisManager::RegisterModelFactory(G4VModelFactory<G4VTrajectoryModel>*)", referenced from:
G4VisExecutive::RegisterModelFactories() in RE02.cc.o
"G4VisManager::RegisterModelFactory(G4VModelFactory<G4VFilter<G4VTrajectory> >*)", referenced from:
"G4VisManager::RegisterModelFactory(G4VModelFactory<G4VFilter<G4VHit> >*)", referenced from:
"G4VisManager::RegisterModelFactory(G4VModelFactory<G4VFilter<G4VDigi> >*)", referenced from:
"G4VisManager::RegisterGraphicsSystem(G4VGraphicsSystem*)", referenced from:
"G4VisManager::Draw(G4Polyline const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw(G4Polyhedron const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw(G4Polymarker const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw(G4VTrajectory const&)", referenced from:
"G4VisManager::Draw(G4LogicalVolume const&, G4VisAttributes const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw(G4VPhysicalVolume const&, G4VisAttributes const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw(G4Text const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw(G4VHit const&)", referenced from:
"G4VisManager::Draw(G4VDigi const&)", referenced from:
"G4VisManager::Draw(G4Circle const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw(G4Square const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw(G4VSolid const&, G4VisAttributes const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw2D(G4Polyline const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw2D(G4Polyhedron const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw2D(G4Polymarker const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw2D(G4Text const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw2D(G4Circle const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::Draw2D(G4Square const&, HepGeom::Transform3D const&)", referenced from:
"G4VisManager::EndDraw()", referenced from:
"G4VisManager::BeginDraw(HepGeom::Transform3D const&)", referenced from:
"G4VisManager::EndDraw2D()", referenced from:
"G4VisManager::FilterHit(G4VHit const&)", referenced from:
"G4VisManager::G4VisManager(G4String const&)", referenced from:
_main in RE02.cc.o
"G4VisManager::~G4VisManager()", referenced from:
G4VisExecutive::~G4VisExecutive() in RE02.cc.o
"G4GMocrenFile::G4GMocrenFile()", referenced from:
"G4NistManager::Instance()", referenced from:
"G4PVPlacement::G4PVPlacement(CLHEP::HepRotation*, CLHEP::Hep3Vector const&, G4LogicalVolume*, G4String const&, G4LogicalVolume*, bool, int, bool)", referenced from:
"G4ParticleGun::SetParticleEnergy(double)", referenced from:
RE02PrimaryGeneratorAction::RE02PrimaryGeneratorAction() in RE02PrimaryGeneratorAction.cc.o
RE02PrimaryGeneratorAction::GeneratePrimaries(G4Event*) in RE02PrimaryGeneratorAction.cc.o
"G4ParticleGun::SetParticleDefinition(G4ParticleDefinition*)", referenced from:
"G4ParticleGun::G4ParticleGun(int)", referenced from:
"G4UIExecutive::G4UIExecutive(int, char**, G4String const&)", referenced from:
_main in RE02.cc.o
