I recently updated my computer and when I went to compile my latest GEANT project it failed. I have attempted to reinstall GEANT however have been met with many errors.
I am running OSX 10.14.16 (Mojave)
with Xcode version 11
and cmake 3.15.3
-- The C compiler identification is AppleClang 11.0.0.11000033
-- The CXX compiler identification is AppleClang 11.0.0.11000033
-- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc
-- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -- works
-- Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++
-- Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -- works
-- Found EXPAT: /usr/lib/libexpat.dylib (found version "2.2.5")
-- Found X11: /opt/X11/include
-- Looking for XOpenDisplay in /opt/X11/lib/libX11.dylib;/opt/X11/lib/libXext.dylib
-- Looking for XOpenDisplay in /opt/X11/lib/libX11.dylib;/opt/X11/lib/libXext.dylib - found
-- Looking for gethostbyname
-- Looking for gethostbyname - found
-- Looking for connect
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found OpenGL: /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/OpenGL.framework
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of off64_t
-- Check size of off64_t - failed
-- Looking for fseeko
-- Looking for fseeko - found
-- Looking for unistd.h
-- Looking for unistd.h - found
-- Configuring download of missing dataset G4NDL (4.5)
-- Configuring download of missing dataset G4EMLOW (7.7)
-- Configuring download of missing dataset PhotonEvaporation (5.3)
-- Configuring download of missing dataset RadioactiveDecay (5.3)
-- Configuring download of missing dataset G4PARTICLEXS (1.1)
-- Configuring download of missing dataset G4PII (1.3)
-- Configuring download of missing dataset RealSurface (2.1.1)
-- Configuring download of missing dataset G4SAIDDATA (2.0)
-- Configuring download of missing dataset G4ABLA (3.1)
-- Configuring download of missing dataset G4INCL (1.0)
-- Configuring download of missing dataset G4ENSDFSTATE (2.2)
-- The following Geant4 features are enabled:
GEANT4_BUILD_CXXSTD: Compiling against C++ Standard '11'
GEANT4_USE_OPENGL_X11: Build Geant4 OpenGL driver with X11 support
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
FREETYPE_LIBRARY
linked by target "G4analysis" in directory /usr/local/geant4.10.05-source/source/analysis
See also "/usr/local/geant4.10.05-build/CMakeFiles/CMakeOutput.log".
See also "/usr/local/geant4.10.05-build/CMakeFiles/CMakeError.log".
I can see that it is failing when it checks the size of off64_t and that it needs but can not find FREETYPE_LIBRARY. Does anyone know how to rectify this?
