Hi John,
Thanks again for your reply! I used the debugger and terminated the run when the UI froze. I then checked info threads
and where
. Here’s what I got (sorry for the length of the result
The last line suggests that it died at line 96 of exampleB1.cc, which says ui->SessionStart();
. Is the problem from my UI?
^C
Thread 1 "exampleB1" received signal SIGINT, Interrupt.
__pthread_clockjoin_ex (threadid=140736546375424, thread_return=0x0,
clockid=<optimised out>, abstime=<optimised out>, block=<optimised out>)
at pthread_join_common.c:145
145 pthread_join_common.c: No such file or directory.
(gdb) info threads
Id Target Id Frame
* 1 Thread 0x7fffee1f7b80 (LWP 2239) "exampleB1" __pthread_clockjoin_ex (threadid=140736546375424, thread_return=0x0, clockid=<optimised out>,
2 Thread 0x7fffec899700 (LWP 2240) "QXcbEventQueue" 0x00007ffff5412aff in poll () from /usr/lib/x86_64-linux-gnu/libc.so.6
3 Thread 0x7fffe6d01700 (LWP 2241) "gmain" 0x00007ffff5412aff in poll () from /usr/lib/x86_64-linux-gnu/libc.so.6
4 Thread 0x7fffe6500700 (LWP 2242) "gdbus" 0x00007ffff5412aff in poll () from /usr/lib/x86_64-linux-gnu/libc.so.6
5 Thread 0x7fffe5a9a700 (LWP 2243) "QDBusConnection" 0x00007ffff5412aff in poll () from /usr/lib/x86_64-linux-gnu/libc.so.6
6 Thread 0x7fffe514c700 (LWP 2246) "exampleB1" futex_wait_cancelable
(private=<optimised out>, expected=0, futex_word=0x55555584c750)
at ../sysdeps/nptl/futex-internal.h:183
7 Thread 0x7fffe494b700 (LWP 2247) "exampleB1" futex_wait_cancelable
8 Thread 0x7fffc7da8700 (LWP 2251) "exampleB1" futex_wait_cancelable
futex_word=0x7ffff7c75688 <(anonymous namespace)::c2_VisSubThreadQtOpenGLContextMoved+40>) at ../sysdeps/nptl/futex-internal.h:183
(gdb) where
#0 __pthread_clockjoin_ex (threadid=140736546375424, thread_return=0x0,
#1 0x00007ffff5731fe7 in std::thread::join() ()
from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#2 0x00007ffff7a7dcf5 in G4VisManager::EndOfRun (this=0x555555ef13b0)
at /home/chloe/geant4/geant4.10.07/source/visualization/management/src/G4VisManager.cc:2202
#3 0x00007ffff7a9c67d in G4VisStateDependent::Notify (this=0x555555ef10f0,
requestedState=G4State_Idle)
at /home/chloe/geant4/geant4.10.07/source/visualization/management/src/G4VisStateDependent.cc:49
#4 0x00007ffff5ae9ec8 in G4StateManager::SetNewState (this=0x5555555ef5e0,
requestedState=@0x7fffffffbf64: G4State_Idle, msg=0x0)
at /home/chloe/geant4/geant4.10.07/source/global/management/src/G4StateManager.cc:164
#5 0x00007ffff5ae9dc8 in G4StateManager::SetNewState (this=0x5555555ef5e0,
requestedState=@0x7fffffffbf64: G4State_Idle)
at /home/chloe/geant4/geant4.10.07/source/global/management/src/G4StateManager.cc:138
#6 0x00007ffff714dea4 in G4RunManagerKernel::RunTermination (
this=0x555555941030)
at /home/chloe/geant4/geant4.10.07/source/run/src/G4RunManagerKernel.cc:872
#7 0x00007ffff713ab1a in G4RunManager::RunTermination (this=0x55555584c370)
at /home/chloe/geant4/geant4.10.07/source/run/src/G4RunManager.cc:630
#8 0x00007ffff7141d39 in G4MTRunManager::RunTermination (this=0x55555584c370)
at /home/chloe/geant4/geant4.10.07/source/run/src/G4MTRunManager.cc:496
#9 0x00007ffff71397be in G4RunManager::BeamOn (this=0x55555584c370,
n_event=10, macroFile=0x0, n_select=-1)
at /home/chloe/geant4/geant4.10.07/source/run/src/G4RunManager.cc:344
#10 0x00007ffff7155d1e in G4RunMessenger::SetNewValue (this=0x555555d00bc0,
command=0x555555d01050, newValue=...)
at /home/chloe/geant4/geant4.10.07/source/run/src/G4RunMessenger.cc:460
#11 0x00007ffff5b92d9b in G4UIcommand::DoIt (this=0x555555d01050,
parameterList=...)
--Type <RET> for more, q to quit, c to continue without paging--RET
4UIcommand.cc:262
#12 0x00007ffff5baa494 in G4UImanager::ApplyCommand (this=0x5555555ef2c0,
aCmd=0x7fffffffc9e0 "/run/beamOn 10")
at /home/chloe/geant4/geant4.10.07/source/intercoms/src/G4UImanager.cc:584
#13 0x00007ffff5ba9baa in G4UImanager::ApplyCommand (this=0x5555555ef2c0,
aCmd=...)
at /home/chloe/geant4/geant4.10.07/source/intercoms/src/G4UImanager.cc:481
#14 0x00007ffff762f870 in G4VBasicShell::ExecuteCommand (this=0x5555555eebb0,
aCommand=...)
at /home/chloe/geant4/geant4.10.07/source/interfaces/common/src/G4VBasicShell.cc:213
#15 0x00007ffff763027b in G4VBasicShell::ApplyShellCommand (
this=0x5555555eebb0, a_string=..., exitSession=@0x7ffff76604c0: false,
exitPause=@0x7ffff76604c1: true)
at /home/chloe/geant4/geant4.10.07/source/interfaces/common/src/G4VBasicShell.cc:308
#16 0x00007ffff761370f in G4UIQt::CommandEnteredCallback (this=0x5555555eeba0)
at /home/chloe/geant4/geant4.10.07/source/interfaces/basic/src/G4UIQt.cc:3820
#17 0x00007ffff75ffc50 in G4UIQt::qt_static_metacall (_o=0x5555555eeba0,
_c=QMetaObject::InvokeMetaMethod, _id=3, _a=0x7fffffffcd20)
at /home/chloe/geant4/geant4.10.07-build/source/G4interfaces_autogen/include/moc_G4UIQt.cpp:162
#18 0x00007ffff0dff300 in QMetaObject::activate(QObject*, int, int, void**) ()
from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#19 0x00007ffff21be4a9 in ?? ()
from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#20 0x00007ffff0dff300 in QMetaObject::activate(QObject*, int, int, void**) ()
#21 0x00007ffff21c4c85 in QWidgetLineControl::processKeyEvent(QKeyEvent*) ()
#22 0x00007ffff21b799f in QLineEdit::keyPressEvent(QKeyEvent*) ()
#23 0x00007ffff20b477d in QWidget::event(QEvent*) ()
#24 0x00007ffff21bdd32 in QLineEdit::event(QEvent*) ()
#25 0x00007ffff2071a66 in QApplicationPrivate::notify_helper(QObject*, QEvent*)
() from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#26 0x00007ffff207b81e in QApplication::notify(QObject*, QEvent*) ()
#27 0x00007ffff0dd393a in QCoreApplication::notifyInternal2(QObject*, QEvent*)
() from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#28 0x00007ffff20d3216 in ?? ()
#29 0x00007ffff2071a66 in QApplicationPrivate::notify_helper(QObject*, QEvent*)
#30 0x00007ffff207b0f0 in QApplication::notify(QObject*, QEvent*) ()
#31 0x00007ffff0dd393a in QCoreApplication::notifyInternal2(QObject*, QEvent*)
#32 0x00007ffff11bab2b in QGuiApplicationPrivate::processKeyEvent(QWindowSystemInterfacePrivate::KeyEvent*) () from /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
#33 0x00007ffff11c00f1 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) ()
#34 0x00007ffff119a35b in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) ()
#35 0x00007fffed13c32e in ?? ()
from /usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
#36 0x00007ffff00b117d in g_main_context_dispatch ()
from /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#37 0x00007ffff00b1400 in ?? () from /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#38 0x00007ffff00b14a3 in g_main_context_iteration ()
#39 0x00007ffff0e2b565 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#40 0x00007ffff0dd24db in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#41 0x00007ffff0dda246 in QCoreApplication::exec() ()
#42 0x00007ffff760508b in G4UIQt::SessionStart (this=0x5555555eeba0)
at /home/chloe/geant4/geant4.10.07/source/interfaces/basic/src/G4UIQt.cc:1922
#43 0x00007ffff75f6d73 in G4UIExecutive::SessionStart (this=0x5555555ee500)
at /home/chloe/geant4/geant4.10.07/source/interfaces/basic/src/G4UIExecutive.cc:309
#44 0x000055555555d3c7 in main (argc=1, argv=0x7fffffffdb78)
at /home/chloe/workspace/G4WORK/B1/exampleB1.cc:96
