I built geant4.10.7.2 and example B1 on Windows 10 with Qt enabled. When running the example, I get 3 pop up windows regarding Qt53Dcore.dll, Qt53Dextras.dll and Qt53dRender.dll.
Build:
Windows 10
Visual Studio 19.28
cmake 3.19.2
Qt5.15.2
This is strange, since during the cmake process, it looks like Qt libraries were found. And I don’t see errors for Qt5 dlls other than the “3D” ones.
from CMakeCache.txt
//Build Geant4 with Qt support
GEANT4_USE_QT:BOOL=ON//The directory containing a CMake configuration file for Qt53DCore.
Qt53DCore_DIR:PATH=C:/Qt/5.15.2/msvc2019_64/lib/cmake/Qt53DCore//The directory containing a CMake configuration file for Qt53DExtras.
Qt53DExtras_DIR:PATH=C:/Qt/5.15.2/msvc2019_64/lib/cmake/Qt53DExtras//The directory containing a CMake configuration file for Qt53DInput.
Qt53DInput_DIR:PATH=C:/Qt/5.15.2/msvc2019_64/lib/cmake/Qt53DInput//The directory containing a CMake configuration file for Qt53DLogic.
Qt53DLogic_DIR:PATH=C:/Qt/5.15.2/msvc2019_64/lib/cmake/Qt53DLogic//The directory containing a CMake configuration file for Qt53DRender.
Qt53DRender_DIR:PATH=C:/Qt/5.15.2/msvc2019_64/lib/cmake/Qt53DRender//The directory containing a CMake configuration file for Qt5Core.
Qt5Core_DIR:PATH=C:/Qt/5.15.2/msvc2019_64/lib/cmake/Qt5Core//The directory containing a CMake configuration file for Qt5Gamepad.
Qt5Gamepad_DIR:PATH=C:/Qt/5.15.2/msvc2019_64/lib/cmake/Qt5Gamepad//The directory containing a CMake configuration file for Qt5Gui.
Qt5Gui_DIR:PATH=C:/Qt/5.15.2/msvc2019_64/lib/cmake/Qt5Gui//The directory containing a CMake configuration file for Qt5Network.
Qt5Network_DIR:PATH=C:/Qt/5.15.2/msvc2019_64/lib/cmake/Qt5Network//The directory containing a CMake configuration file for Qt5OpenGL.
Qt5OpenGL_DIR:PATH=C:/Qt/5.15.2/msvc2019_64/lib/cmake/Qt5OpenGL//The directory containing a CMake configuration file for Qt5PrintSupport.
Qt5PrintSupport_DIR:PATH=C:/Qt/5.15.2/msvc2019_64/lib/cmake/Qt5PrintSupport//The directory containing a CMake configuration file for Qt5Widgets.
Qt5Widgets_DIR:PATH=C:/Qt/5.15.2/msvc2019_64/lib/cmake/Qt5Widgets
And I can see both the Qt5 cmake files and dll’s in question:
Directory of C:\Qt\5.15.2\msvc2019_64\bin
11/06/2020 05:32 AM 406,000 Qt53DAnimation.dll
11/06/2020 05:32 AM 1,486,320 Qt53DAnimationd.dll
11/06/2020 05:32 AM 414,704 Qt53DCore.dll
11/06/2020 05:32 AM 1,188,848 Qt53DCored.dll
11/06/2020 05:32 AM 666,096 Qt53DExtras.dll
11/06/2020 05:32 AM 1,657,840 Qt53DExtrasd.dll
11/06/2020 05:32 AM 354,800 Qt53DInput.dll
11/06/2020 05:32 AM 1,389,552 Qt53DInputd.dll
11/06/2020 05:32 AM 51,184 Qt53DLogic.dll
11/06/2020 05:32 AM 191,472 Qt53DLogicd.dll
11/06/2020 05:32 AM 167,920 Qt53DQuick.dll
11/06/2020 05:32 AM 59,376 Qt53DQuickAnimation.dll
11/06/2020 05:32 AM 227,824 Qt53DQuickAnimationd.dll
11/06/2020 05:32 AM 474,096 Qt53DQuickd.dll
11/06/2020 05:32 AM 78,320 Qt53DQuickExtras.dll
11/06/2020 05:32 AM 243,696 Qt53DQuickExtrasd.dll
11/06/2020 05:32 AM 55,792 Qt53DQuickInput.dll
11/06/2020 05:32 AM 201,712 Qt53DQuickInputd.dll
11/06/2020 05:32 AM 161,776 Qt53DQuickRender.dll
11/06/2020 05:32 AM 576,496 Qt53DQuickRenderd.dll
11/06/2020 05:32 AM 87,536 Qt53DQuickScene2D.dll
11/06/2020 05:32 AM 359,408 Qt53DQuickScene2Dd.dll
11/06/2020 05:32 AM 2,239,472 Qt53DRender.dll
11/06/2020 05:32 AM 7,005,680 Qt53DRenderd.dll
Directory of C:\Qt\5.15.2\msvc2019_64\lib\cmake
09/23/2021 05:22 PM Qt53DAnimation
09/23/2021 05:22 PM Qt53DCore
09/23/2021 05:22 PM Qt53DExtras
09/23/2021 05:22 PM Qt53DInput
09/23/2021 05:22 PM Qt53DLogic
09/23/2021 05:22 PM Qt53DQuick
09/23/2021 05:22 PM Qt53DQuickAnimation
09/23/2021 05:22 PM Qt53DQuickExtras
09/23/2021 05:22 PM Qt53DQuickInput
09/23/2021 05:22 PM Qt53DQuickRender
09/23/2021 05:22 PM Qt53DQuickScene2D
09/23/2021 05:22 PM Qt53DRender
I don’t get any errors during build or install (RelWithDebInfo). I do get one warning:
C:\Geant4\geant4_10_07\source\visualization\OpenGL\src\G4OpenGLQtViewer.cc(606,77): warning C4305: ‘argument’: truncation from ‘int’ to ‘bool’ [C:\Geant4\geant4.10.7.2-build\source\G4OpenGL.vcxproj]
Then when I build example B1 (also RelWithDebInfo) I don’t get any errors or warnings. I have tried with and without manually putting Qt path in make file. Though it doesn’t seem necessary since again it seems to find the Qt make files.
Yet when I run example B1, I get the popup errors. If I run exampleB1.exe run1.mac, I get 2 popups. If I run without “run1.mac”, so expecting visualization, I get 3 (including Qt53Dcore.dll).
Any ideas?
Thanks!
CMakeCacheGeant build.txt (25.9 KB)
CMakeCache B1-build.txt (16.2 KB)
install output.txt (383.7 KB)
Compile output.txt (100.9 KB)
