Hello!
I was finally able to run example 1 and build the geometry. However, I am having trouble with an error after running the command /run/beamOn 10
After running the executable, I get this output:
The output I am getting after running the command /run/beamOn 10 is this:
Idle> /control/verbose 2
/control/verbose 2
Idle> /tracking/verbose 1
/tracking/verbose 1
Idle> /run/beamOn 10
/run/beamOn 10
*** G4Exception : em0003
issued by : G4SeltzerBergerModel::ReadData()
Bremsstrahlung data file <C:\Geant4\geant4_10_06-install\share\Geant4-10.6.2\data\G4EMLOW7.9.1;/brem_SB/br6> is not opened!G4LEDATA version should be G4EMLOW6.23 or later.
Thank you!!!
