Hi all,
I am compiling the geant4-11.0.2/examples/advanced/eRosita. As the instruction, only one need to type make in the dicrectory, but I failed with errors that the compiler can’t find the head file. Do I need some environment settings.
the official procedure is through the cmake building chain, and this is what the geant4.(c)sh scripts are configuring.
In case you want to use the older building procedure via only make you have to also run the geant4make.(c)sh in the <CMAKE_INSTALL_PREFIX>/share/Geant4-/geant4make folder in order to set the environment.
thanks for your help. yeah, I know source geant4make.sh is expected and I already have done this, but it still appeared errors.
Could you run the command:
$ env | sort
in the terminal where you’re trying to build and post the output here please? This should contain all the settings used by the old geant4make system, so can be a start to tracking the problem.
Hi, I posted the output here.
CLING_STANDARD_PCH=none
CLUTTER_IM_MODULE=fcitx
CMAKE_PREFIX_PATH=/home/renqi/Documents/root
COLORTERM=truecolor
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
DESKTOP_SESSION=ubuntu
DISPLAY=:0
DYLD_LIBRARY_PATH=/home/renqi/Documents/root/lib
G4ABLADATA=/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/data/G4ABLA3.1
G4ENSDFSTATEDATA=/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/data/G4ENSDFSTATE2.3
G4INCLDATA=/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/data/G4INCL1.0
G4INCLUDE=/home/renqi/Documents/geant4/geant4-install/include/Geant4
G4INSTALL=/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make
G4LEDATA=/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/data/G4EMLOW8.0
G4LEVELGAMMADATA=/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/data/PhotonEvaporation5.7
G4LIB_BUILD_SHARED=1
G4LIB=/home/renqi/Documents/geant4/geant4-install/lib/Geant4-11.0.2
G4LIB_USE_ZLIB=1
G4NEUTRONHPDATA=/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/data/G4NDL4.6
G4PARTICLEXSDATA=/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/data/G4PARTICLEXS4.0
G4PIIDATA=/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/data/G4PII1.3
G4RADIOACTIVEDATA=/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/data/RadioactiveDecay5.6
G4REALSURFACEDATA=/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/data/RealSurface2.2
G4SAIDXSDATA=/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/data/G4SAIDDATA2.0
G4SYSTEM=Linux-g++
G4UI_USE_QT=1
G4UI_USE_TCSH=1
G4VIS_USE_OPENGLQT=1
G4VIS_USE_OPENGLX=1
G4VIS_USE_RAYTRACERX=1
G4WORKDIR=/home/renqi/geant4_workdir
GDMSESSION=ubuntu
GJS_DEBUG_OUTPUT=stderr
GJS_DEBUG_TOPICS=JS ERROR;JS LOG
GNOME_DESKTOP_SESSION_ID=this-is-deprecated
GNOME_SHELL_SESSION_MODE=ubuntu
GNOME_TERMINAL_SCREEN=/org/gnome/Terminal/screen/da498f6c_471c_4031_b053_fc16d7241e95
GNOME_TERMINAL_SERVICE=:1.491
GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1
GTK_IM_MODULE=fcitx
GTK_MODULES=gail:atk-bridge
HOME=/home/renqi
IM_CONFIG_PHASE=1
INVOCATION_ID=5e14f13b40f8456da547a232012ce5af
JOURNAL_STREAM=8:54678
JUPYTER_CONFIG_DIR=/home/renqi/Documents/root/etc/notebook
JUPYTER_PATH=/home/renqi/Documents/root/etc/notebook
LANG=en_US.UTF-8
LANGUAGE=en_US:en
LC_ADDRESS=zh_CN.UTF-8
LC_IDENTIFICATION=zh_CN.UTF-8
LC_MEASUREMENT=zh_CN.UTF-8
LC_MONETARY=zh_CN.UTF-8
LC_NAME=zh_CN.UTF-8
LC_NUMERIC=zh_CN.UTF-8
LC_PAPER=zh_CN.UTF-8
LC_TELEPHONE=zh_CN.UTF-8
LC_TIME=zh_CN.UTF-8
LD_LIBRARY_PATH=/usr/lib/x86_64-linux-gnu:/home/renqi/Documents/geant4/geant4-install/lib:/usr/lib/x86_64-linux-gnu/qt5
LESSCLOSE=/usr/bin/lesspipe %s %s
LESSOPEN=| /usr/bin/lesspipe %s
LIBPATH=/home/renqi/Documents/root/lib
LOGNAME=renqi
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:.tar=01;31:.tgz=01;31:.arc=01;31:.arj=01;31:.taz=01;31:.lha=01;31:.lz4=01;31:.lzh=01;31:.lzma=01;31:.tlz=01;31:.txz=01;31:.tzo=01;31:.t7z=01;31:.zip=01;31:.z=01;31:.dz=01;31:.gz=01;31:.lrz=01;31:.lz=01;31:.lzo=01;31:.xz=01;31:.zst=01;31:.tzst=01;31:.bz2=01;31:.bz=01;31:.tbz=01;31:.tbz2=01;31:.tz=01;31:.deb=01;31:.rpm=01;31:.jar=01;31:.war=01;31:.ear=01;31:.sar=01;31:.rar=01;31:.alz=01;31:.ace=01;31:.zoo=01;31:.cpio=01;31:.7z=01;31:.rz=01;31:.cab=01;31:.wim=01;31:.swm=01;31:.dwm=01;31:.esd=01;31:.jpg=01;35:.jpeg=01;35:.mjpg=01;35:.mjpeg=01;35:.gif=01;35:.bmp=01;35:.pbm=01;35:.pgm=01;35:.ppm=01;35:.tga=01;35:.xbm=01;35:.xpm=01;35:.tif=01;35:.tiff=01;35:.png=01;35:.svg=01;35:.svgz=01;35:.mng=01;35:.pcx=01;35:.mov=01;35:.mpg=01;35:.mpeg=01;35:.m2v=01;35:.mkv=01;35:.webm=01;35:.ogm=01;35:.mp4=01;35:.m4v=01;35:.mp4v=01;35:.vob=01;35:.qt=01;35:.nuv=01;35:.wmv=01;35:.asf=01;35:.rm=01;35:.rmvb=01;35:.flc=01;35:.avi=01;35:.fli=01;35:.flv=01;35:.gl=01;35:.dl=01;35:.xcf=01;35:.xwd=01;35:.yuv=01;35:.cgm=01;35:.emf=01;35:.ogv=01;35:.ogx=01;35:.aac=00;36:.au=00;36:.flac=00;36:.m4a=00;36:.mid=00;36:.midi=00;36:.mka=00;36:.mp3=00;36:.mpc=00;36:.ogg=00;36:.ra=00;36:.wav=00;36:.oga=00;36:.opus=00;36:.spx=00;36:*.xspf=00;36:
MANAGERPID=1681
MANPATH=/home/renqi/Documents/root/man:/usr/local/man:/usr/local/share/man:/usr/share/man
OLDPWD=/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make
PAPERSIZE=a4
PATH=/home/renqi/geant4_workdir/bin/Linux-g++:/home/renqi/Documents/geant4/geant4-install/bin:/home/renqi/geant4_workdir/bin/Linux-g++:/home/renqi/Documents/geant4/geant4-install/bin:/home/renqi/Documents/root/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
PWD=/home/renqi/Documents/geant4/geant4-11.0.2/examples/advanced/eRosita
PYTHONPATH=/home/renqi/Documents/root/lib
QT4_IM_MODULE=fcitx
QT_ACCESSIBILITY=1
QTHOME=/usr
QT_IM_MODULE=fcitx
QTLIBPATH=/usr/lib/x86_64-linux-gnu
ROOTSYS=/home/renqi/Documents/root
SESSION_MANAGER=local/ubuntu20:@/tmp/.ICE-unix/1948,unix/ubuntu20:/tmp/.ICE-unix/1948
SHELL=/bin/bash
SHLIB_PATH=/home/renqi/Documents/root/lib
SHLVL=0
SSH_AGENT_PID=1872
SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
TERM=xterm-256color
USERNAME=renqi
USER=renqi
_=/usr/bin/env
VTE_VERSION=6003
WINDOWPATH=2
XAUTHORITY=/run/user/1000/gdm/Xauthority
XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg
XDG_CURRENT_DESKTOP=ubuntu:GNOME
XDG_DATA_DIRS=/usr/share/ubuntu:/usr/local/share/:/usr/share/:/var/lib/snapd/desktop
XDG_MENU_PREFIX=gnome-
XDG_RUNTIME_DIR=/run/user/1000
XDG_SESSION_CLASS=user
XDG_SESSION_DESKTOP=ubuntu
XDG_SESSION_TYPE=x11
XMODIFIERS=@im=fcitx
Hi, @bmorgan.
I posted above. By the way, I can successively compile other examples such as /basic/B1, but not this one. Is it possible to compile this example as /basic/B1.
The settings look fine, especially if basic/B1 is building o.k. Could you also try building with:
$ CPPVERBOSE=1 make
and again post the output here please? It seems like something isn’t getting passed through correctly (as noted, we don’t really support geant4make builds anymore, so it’s possible a bug has crept in).
Entering application …
Making dependency for file src/eRositaSteppingAction.cc …
In file included from src/eRositaSteppingAction.cc:31:
include/eRositaSteppingAction.hh:34:10: fatal error: G4UserSteppingAction.hh: No such file or directory
34 | #include “G4UserSteppingAction.hh”
compilation terminated.
Making dependency for file src/eRositaEventAction.cc …
In file included from src/eRositaEventAction.cc:29:
include/eRositaEventAction.hh:32:10: fatal error: G4UserEventAction.hh: No such file or directory
32 | #include “G4UserEventAction.hh”
Making dependency for file src/eRositaSteppingVerbose.cc …
In file included from src/eRositaSteppingVerbose.cc:31:
include/eRositaSteppingVerbose.hh:40:10: fatal error: G4SteppingVerbose.hh: No such file or directory
40 | #include “G4SteppingVerbose.hh”
Making dependency for file src/eRositaTrackerHit.cc …
In file included from src/eRositaTrackerHit.cc:29:
include/eRositaTrackerHit.hh:32:10: fatal error: G4VHit.hh: No such file or directory
32 | #include “G4VHit.hh”
Making dependency for file src/AnalysisManager.cc …
In file included from src/AnalysisManager.cc:26:
include/AnalysisManager.hh:29:10: fatal error: globals.hh: No such file or directory
29 | #include “globals.hh”
Making dependency for file src/eRositaRunAction.cc …
In file included from src/eRositaRunAction.cc:29:
include/eRositaRunAction.hh:33:10: fatal error: G4UserRunAction.hh: No such file or directory
33 | #include “G4UserRunAction.hh”
Making dependency for file src/eRositaActionInitialization.cc …
In file included from src/eRositaActionInitialization.cc:26:
include/eRositaActionInitialization.hh:29:10: fatal error: globals.hh: No such file or directory
Making dependency for file src/eRositaPrimaryGeneratorAction.cc …
In file included from src/eRositaPrimaryGeneratorAction.cc:31:
Making dependency for file src/eRositaTrackerSD.cc …
In file included from src/eRositaTrackerSD.cc:30:
include/eRositaTrackerSD.hh:34:10: fatal error: G4VSensitiveDetector.hh: No such file or directory
34 | #include “G4VSensitiveDetector.hh”
Making dependency for file src/eRositaPhysicsList.cc …
src/eRositaPhysicsList.cc:29:10: fatal error: globals.hh: No such file or directory
Making dependency for file src/eRositaDetectorConstruction.cc …
In file included from src/eRositaDetectorConstruction.cc:31:
include/eRositaDetectorConstruction.hh:34:10: fatal error: globals.hh: No such file or directory
34 | #include “globals.hh”
g++ -W -Wall -ansi -pedantic -Wno-non-virtual-dtor -Wno-long-long -Wwrite-strings -Wpointer-arith -Woverloaded-virtual -Wno-variadic-macros -Wshadow -pipe -pthread -fno-trapping-math -ftree-vectorize -fno-math-errno -std=c++17 -O3 -fPIC -DG4GMAKE -DG4OPTIMISE -Iinclude -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/externals/clhep/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/externals/ptl/include -I/usr/include -std=c++17 -fPIC -DG4VERBOSE -DG4_STORE_TRAJECTORY -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/interfaces/basic/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/interfaces/common/include -DG4UI_USE_TCSH -DG4UI_USE_QT -DG4UI_USE -DG4VIS_USE_ASCIITREE -DG4VIS_USE_DAWNFILE -DG4VIS_USE_GMOCRENFILE -DG4VIS_USE_HEPREPFILE -DG4VIS_USE_RAYTRACER -DG4VIS_USE_VRMLFILE -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/visualization/FukuiRenderer/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/visualization/gMocren/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/visualization/HepRep/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/visualization/RayTracer/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/visualization/Tree/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/visualization/VRML/include -DG4VIS_USE_OPENGLX -DG4VIS_USE_OPENGLQT -DG4VIS_USE_OPENGL -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/visualization/OpenGL/include -DG4VIS_USE_RAYTRACERX -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/visualization/externals/gl2ps/include -DG4VIS_USE -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/visualization/management/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/visualization/modeling/include -DQT_NO_DEPRECATED_WARNINGS -I /usr/include -I/usr/include/Qt -I /usr/include/QtCore -I /usr/include/QtGui -I /usr/include/QtWidgets -I /usr/include/QtOpenGL -I /usr/include/Qt3DCore -I /usr/include/Qt3DExtras -I /usr/include/Qt3DRender -I /usr/include/QtPrintSupport -I/usr/include/X11/extensions -I/usr/include/X11 -DG4INTY_USE_QT -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/global/management/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/global/HEPRandom/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/global/HEPGeometry/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/global/HEPNumerics/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/run/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/materials/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/parameterisations/trd_clusters/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/parameterisations/gflash/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/particles/management/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/particles/bosons/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/particles/leptons/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/particles/hadrons/barions/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/particles/hadrons/ions/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/particles/hadrons/mesons/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/particles/shortlived/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/processes/management/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/processes/cuts/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/processes/decay/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/processes/optical/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/processes/transportation/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/processes/parameterisation/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/processes/electromagnetic/standard/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/processes/electromagnetic/muons/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/processes/electromagnetic/utils/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/processes/electromagnetic/xrays/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/processes/electromagnetic/highenergy/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/processes/electromagnetic/lowenergy/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/processes/electromagnetic/pii/include -I…/physics/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/geometry/management/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/geometry/solids/CSG/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/geometry/solids/specific/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/geometry/solids/BREPS/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/geometry/solids/Boolean/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/geometry/divisions/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/geometry/volumes/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/geometry/navigation/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/geometry/magneticfield/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/geometry/biasing/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/track/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/tracking/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/digits_hits/detector/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/digits_hits/hits/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/digits_hits/digits/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/digits_hits/utils/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/persistency/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/readout/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/event/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/graphics_reps/include -I/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/source/intercoms/include -c -o /home/renqi/geant4_workdir/tmp/Linux-g++/eRosita/eRositaDetectorConstruction.o src/eRositaDetectorConstruction.cc
make[1]: *** [/home/renqi/Documents/geant4/geant4-install/share/Geant4-11.0.2/geant4make/config/common.gmk:81: /home/renqi/geant4_workdir/tmp/Linux-g++/eRosita/eRositaDetectorConstruction.o] Error 1
make: *** [GNUmakefile:37: makesub] Error 2
It’s quite similar with just make. It seems the compiler can’t find head files in geant4-install/include , but it can find head files in the working direcoty(inside this example).
-------update------
I can successively compile this example just as we do in /basic/B1 using cmake .. and ``make ``` in the “build” directory.
