Fast neutrons from reaction of deutrons (energy up to 2 MeV) with 7Li/6Li
Geant4 Version: 11.4.1
Operating System: ubuntu 24.04
Compiler/Version: gcc 13.3.0
CMake Version: 3.28.3
I have question about simulation of the yield of fast neutrons. So, task is
next - deuterons with energy up to 1.5 MeV hit to natural lithium target (7Li/
6Li - 92.5/7.5). Main nuclear reaction are:
  1. 7Li(d,n)8Be, then 8Be->alpha+alpha
  2. 7Li(d,n)alpha+alpha
  3. 7Li(d,alpha)5He, then 5He->n+alpha
  4. 6Li(d,n)7Be
  5. 6Li(d,3He)5He, then 5He->n+alpha
I used G4VModularPhysicsList* phys_list = new QGSP_BIC_AllHP(0).
I see 3 resonances for 8Be - gs, 3.03 MeV and 11.25 MeV conditions from
7Li(d,n)8Be reactions (see the attachment, 3 lines correspond 3 resonances)
and few background up to 5 MeV. Background it seems coming from 3) and 5)
reactions.
Additionally info is next:
* creator process: dInelastic, neutronInelastic
* number of processes: 17
7Li(d,n): 2685413 (94.765%)
6Li(d,n): 77534 ( 2.736%)
7Li(d,n)n: 22789 ( 0.804%)
7Li(d,n)n_n: 17402 ( 0.614%)
7Li(d,n)n_n_n: 12690 ( 0.448%)
7Li(d,n)n_n_n_n: 8206 ( 0.290%)
7Li(d,n)n_n_n_n_n: 4483 ( 0.158%)
6Li(d,n)n: 1176 ( 0.041%)
6Li(d,n)n_n: 1022 ( 0.036%)
6Li(d,n)n_n_n: 790 ( 0.028%)
7Li(d,n)n_n_n_n_n_n: 784 ( 0.028%)
6Li(d,n)n_n_n_n: 650 ( 0.023%)
6Li(d,n)n_n_n_n_n: 438 ( 0.015%)
6Li(d,n)n_n_n_n_n_n: 256 ( 0.009%)
6Li(d,n)n_n_n_n_n_n_n: 131 ( 0.005%)
6Li(d,n)n_n_n_n_n_n_n_n: 5 ( 0.000%)
7Li(n,n)7Li_g: 2 ( 0.000%)
It is very strange - any alpha particles did not observed.
From 2) reaction I expected wide continuum, from 0 to 15 MeV, but I did not
see.
What is nature of secondary peaks for each resonance in 7Li(d,n)8Be reaction
(I mean 8Be in gs and 3.03 MeV) ? Why peak for 8Be in 3.03 is very narrow - it
has own width about 1.5 MeV. The same for 8Be in 11.35 condition (width is 3.5
MeV).
So, my question - what is right way to simulation yield of fast neutrons in
Geant4 (physics list, cuts and so on) ?
Viktor
Here, a run of example Hadr03 and the plots of neutrons and alphas.
victor.mac.txt (380 Bytes)
victor.out.txt (3.3 KB)
for completion, a run with more events and a refined binning.
victor.mac.txt (382 Bytes)
victor.out.txt (3.4 KB)
Dear Maire1,
thank a lot for you help.
So, I made calculation with physics list as in Hadr03.
It is length of deuteron track [cm] vs energy - results from geant4 and it is very strange results
root_length_vs_energy.pdf (21.5 KB)
Here results from https://lief.if.ufrgs.br/pub/CasP/ - you can see a smooth, falling curve with a rapid rise in the low-energy region following the Bragg peak.
Hadr03 compute and print the nuclear interaction length, also called mean free path.
Do we speak of the same thing ?
I`m not think so.
I mean stopping power S=-dE/dx [MeV/cm].
For that I made:
in RunAction::BeginOfRunAction(const G4Run*) {
auto an_man = G4AnalysisManager::Instance();
an_man->CreateH1(“L_Ed”, “Track length of deuterons vs energy”, 250, 0.0, 2.5, “MeV”);
and in SteppingAction::UserSteppingAction(const G4Step* step) {
G4Track* p_track = step->GetTrack();
G4ParticleDefinition* p = p_track->GetDefinition();
std::string p_name = p->GetParticleName();
if (p_name!=“deuteron”) return;
if (p_track->GetTrackID()!=1) return;
// - volume check
auto vol = p_track->GetVolume();
if (vol && vol->GetName()!=“layer_phys”) return;
G4double energy = step->GetPreStepPoint()->GetKineticEnergy();
G4double length = step->GetStepLength();
an_man->FillH1(0, energy/MeV, length/mm);
If you are trying to compute stopping power it is better to just directly get the change in kinetic energy to make like to like comparison, i.e.
dE → change in kinetic energy
Like:
deltaKE = -(step->GetPostStepPoint()->GetKineticEnergy() - step->GetPreStepPoint()->GetKineticEnergy());
How to interpret a 1D histogram of kinetic energy with StepLength as a weight ?
Computation of stopping power is illustrated in example TestEm5
victorb.mac.txt (402 Bytes)
victorb.out.txt (2.0 KB)
