I have been using Geant4 10.6 till now and decided to upgrade to Geant4 11. My older source codes that used to work properly on 10.6 and now encountering this error:
/home/sanchit/Softwares/G4_Work/New_N_200V_45/source/include/Analysis.hh:35:10: fatal error: g4csv.hh: No such file or directory
35 | #include "g4csv.hh"
compilation terminated.
make[2]: *** [CMakeFiles/task.dir/build.make:118: CMakeFiles/task.dir/src/EventAction.cc.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/task.dir/all] Error 2
make: *** [Makefile:136: all] Error 2
Can I please get a hint about the changes in this newer version that would fix this issue? My Analysis.hh is below:
#ifndef MyAnalysis_h
#define MyAnalysis_h 1
//#include "g4root.hh"
#include "g4csv.hh"
//#include "g4xml.hh"
#endif
Thanks very much!
The release notes for Geant4 11.0 indicate that the g4csv.hh header has been depreciated.
I haven’t done it myself, but I believe the new approach would be:
#include "G4CsvAnalysisManager.hh"
using G4AnalysisManager = G4CsvAnalysisManager;
#endif
You can find the documentation here .
Joseph
pico
May 6, 2022, 12:26pm
3
Dear @sanchitsharma ,
I believe @JDecunha is almost right in the sense that your code seems to be outdated and not v11 ready -yet-.
You can have a proper look at example B4 for details but if you look at the RunAction class you will notice the following:
#include "G4AnalysisManager.hh"
void RunAction::BeginOfRunAction(const G4Run* /*run*/)
//inform the runManager to save random number seed
//G4RunManager::GetRunManager()->SetRandomNumberStore(true);
// Get analysis manager
// Open an output file
G4String fileName = "B4.root";
// Other supported output types:
// G4String fileName = "B4.csv";
// G4String fileName = "B4.hdf5";
// G4String fileName = "B4.xml";
analysisManager->OpenFile(fileName);
G4cout << "Using " << analysisManager->GetType() << G4endl;
meaning now instead of having a VERY SHORT analysis header (basically one #include ) now this is controlled with the extension of the output file.
Hope this helps.
Cheers,
/Pico
