Filling std::vector type ntuples using G4root
Dear experts
I want to output the simulation results to a root file using G4AnalysisManager. The format that I want to implement is ntuple columns containing vector entries. The vector will be the collection of hits from one event. I was able to create a std::vector<G4double> type ntuple column, but cannot find any method to fill this. Can you please suggest a way for this?
Regards
Shubham
An example of an ntuple with std::vector ntuple columns types is provided at the basic B5 example.
See:
http://geant4-userdoc.web.cern.ch/geant4-userdoc/Doxygen/examples_doc/html/ExampleB5.html
and the ANALYSIS section.
There is indeed missing mentioning this example in the Application Developers Guide.
As the ntuple column takes the std::vector reference, there is no need to call an extra Fill method to fill a column. The vector content is automatically saved in the ntuple when calling AddNtupleRow .
Thank you very much. That works.
Dear Ivana,
I am using Geant4.10.06.p02.
I have problems by filling Ntuples with some variables of vector type.
I am trying to add rows with the following data:
G4int,G4int,vector,vector,vector
It seems that I have problems with columnID = 0.
I list 5 cases below showing some information.
The output shows always warnings concerning columnId=0.
Sometimes as “Column type does not match: ntupleId 0 columnId 0”
and sometimes as “ntupleId 0 columnId 0 does not exist”.
The CASES have the following information:
  1. Create Ntuple (the way I have created the Ntuples)
  2. Fill Ntuple ( I have filled them with 2 events)
  3. Warning message (the output warning)
  4. ROOT file (the Scan() of the produced ROOT file)
    The output of the ROOT file in CASE 1 is the only one with wrong contents.
    All runs give Warning messages about columnId = 0 that take much processing time.
Thank you for your attention.
Mauricio Moralles
Variable definitions:
G4int ntupleID;
G4int eventID, NhitsID, PDGcodeID, energyID, timeID;
G4int event, Nhits;
std::vector<G4int>    PDG;
std::vector<G4double> En;
std::vector<G4double> Time;
CASE 1:
Create Ntuple:
ntupleID = analysisManager->CreateNtuple(“tree”, “Test”);
// analysisManager->SetFirstNtupleColumnId(1); // eventID should be 1
// G4int type
eventID = analysisManager->CreateNtupleIColumn(“Nevent”); // column Id = 0
NhitsID = analysisManager->CreateNtupleIColumn(“Nhits”); // column Id = 1
// vector
PDGcodeID = analysisManager->CreateNtupleIColumn(“PDGchit”,PDG); // column Id = 2
// vector
energyID = analysisManager->CreateNtupleDColumn(“Enhit”,En); // column Id = 3
timeID = analysisManager->CreateNtupleDColumn(“thit”,Time); // column Id = 4
analysisManager->FinishNtuple();
Fill Ntuple with 2 events
// ---------------------------- Clear vectors
PDG.assign(PDG.size(),0);
PDG.clear();
En.assign(En.size(),0);
En.clear();
Time.assign(Time.size(),0);
Time.clear();
// ------------------------------------------ event1
event = 1000;
Nhits = 4;
// fill the vectors with some values
for(int i = 0; i < Nhits; i++)
PDG.push_back( i + 1 );
En.push_back( i + 10.5 );
Time.push_back( i + 100.8);
analysisManager->FillNtupleIColumn(ntupleID, eventID, event);
analysisManager->FillNtupleIColumn(ntupleID, NhitsID, Nhits);
analysisManager->FillNtupleIColumn(ntupleID, PDGcodeID);
analysisManager->FillNtupleDColumn(ntupleID, energyID);
analysisManager->FillNtupleDColumn(ntupleID, timeID);
analysisManager->AddNtupleRow(ntupleID); // one Row per event, with Nhits particles
PDG.clear();
En.clear();
Time.clear();
// ------------------------------------------ event2
event = 1001;
Nhits = 3;
PDG.push_back( i + 6 );
En.push_back( i + 20.3 );
Time.push_back( i + 200.7);
Warning message:
THREAD_0 >
*** G4Exception : Analysis_W011
issued by : G4TNtupleManager:FillNtupleTColumn
Column type does not match: ntupleId 0 columnId 0 value 3
THREAD_0 >
Column type does not match: ntupleId 0 columnId 0 value 4
THREAD_0 >
THREAD_0 >
ROOT file:
tree->Scan();
  • Row * Instance * Nevent * Nhits * PDGchit * Enhit * thit *
  •    0 *        0 *         2 *         4 *         1 *      10.5 *     100.8 *
  •    0 *        1 *         2 *         4 *         2 *      11.5 *     101.8 *
  •    0 *        2 *         2 *         4 *         3 *      12.5 *     102.8 *
  •    0 *        3 *         2 *         4 *         4 *      13.5 *     103.8 *
  •    1 *        0 *         2 *         3 *         6 *      20.3 *     200.7 *
  •    1 *        1 *         2 *         3 *         7 *      21.3 *     201.7 *
  •    1 *        2 *         2 *         3 *         8 *      22.3 *     202.7 *
—> WRONG values for Nevent
Nevent is always 2. Should be 1000 (4x) and 1001 (3x).
CASE 2:
Create Ntuple change: SetFirstNtupleColumnId(1)
// G4int type
eventID = analysisManager->CreateNtupleIColumn(“Nevent”); // column Id = 1
NhitsID = analysisManager->CreateNtupleIColumn(“Nhits”); // column Id = 2
// vector
PDGcodeID = analysisManager->CreateNtupleIColumn(“PDGchit”,PDG); // column Id = 3
// vector
energyID = analysisManager->CreateNtupleDColumn(“Enhit”,En); // column Id = 4
timeID = analysisManager->CreateNtupleDColumn(“thit”,Time); // column Id = 5
Fill Ntuple: same as CASE 1
Warning Message: (6x)
THREAD_0 >
issued by : G4TNtupleManager::FillNtupleTColumn()
ntupleId 0 columnId 0 does not exist.
ROOT file:
tree->Scan();
  •    0 *        0 *      1000 *         4 *         1 *      10.5 *     100.8 *
  •    0 *        1 *      1000 *         4 *         2 *      11.5 *     101.8 *
  •    0 *        2 *      1000 *         4 *         3 *      12.5 *     102.8 *
  •    0 *        3 *      1000 *         4 *         4 *      13.5 *     103.8 *
  •    1 *        0 *      1001 *         3 *         6 *      20.3 *     200.7 *
  •    1 *        1 *      1001 *         3 *         7 *      21.3 *     201.7 *
  •    1 *        2 *      1001 *         3 *         8 *      22.3 *     202.7 *
—> Now it is correct, but the run produces a lot of Warnings
CASE 3:
Create Ntuple change: vector is the columnId = 0
// vector
PDGcodeID = analysisManager->CreateNtupleIColumn(“PDGchit”,PDG); // column Id = 0
// G4int type
// vector
Fill Ntuple: same as CASE 1 and CASE 2
Warning Message:
THREAD_0 >
Column type does not match: ntupleId 0 columnId 0 value 0
THREAD_0 >
THREAD_0 >
THREAD_0 >
THREAD_0 >
THREAD_0 >
ROOT file:
tree->Scan();
  • Row * Instance * PDGchit * Nevent * Nhits * Enhit * thit *
  •    0 *        0 *         1 *      1000 *         4 *      10.5 *     100.8 *
  •    0 *        1 *         2 *      1000 *         4 *      11.5 *     101.8 *
  •    0 *        2 *         3 *      1000 *         4 *      12.5 *     102.8 *
  •    0 *        3 *         4 *      1000 *         4 *      13.5 *     103.8 *
  •    1 *        0 *         6 *      1001 *         3 *      20.3 *     200.7 *
  •    1 *        1 *         7 *      1001 *         3 *      21.3 *     201.7 *
  •    1 *        2 *         8 *      1001 *         3 *      22.3 *     202.7 *
—> It is correct, but the run produces a lot of Warnings
CASE 4:
Create Ntuple: SetFirstNtupleColumnId(1) vector is the columnId = 1
// vector
PDGcodeID = analysisManager->CreateNtupleIColumn(“PDGchit”,PDG); // column Id = 1
// G4int type
eventID = analysisManager->CreateNtupleIColumn(“Nevent”); // column Id = 2
NhitsID = analysisManager->CreateNtupleIColumn(“Nhits”); // column Id = 3
// vector
Fill Ntuple: same as CASE 1, CASE 2 and CASE 3
THREAD_0 >
ROOT file
tree->Scan();
CASE 5:
Create Ntuple: same as CASE 1
// G4int type
// vector
// vector
Fill Ntuple change: first line with a vector
analysisManager->FillNtupleIColumn(ntupleID, PDGcodeID); // this line was below
// this line was shifted to the first position: analysisManager->FillNtupleIColumn(ntupleID, PDGcodeID);
Warning Message:
THREAD_0 >
THREAD_0 >
THREAD_0 >
THREAD_0 >
ROOT file
tree->Scan();
The Fill…() function should not be called for the columns associated with vectors. You need just to remove these lines from your code:
I will add this information in the documentation, as actually it is missing here.
Thank you.
–> I will add this information in the documentation, as actually it is missing here.
This is very important. I spent a lot of time trying to understand why it was not working.
Mauricio
