First run no scene
_Geant4 Version:11.03
_Operating System: Macos
_Compiler/Version: with QT=6
Hi all, Is any one have the same situation
void cxEventAction::EndOfEventAction(const G4Event* evt) {  // NOLINT
  G4HCofThisEvent* hitsCollections = evt->GetHCofThisEvent();
  auto* aWDhits = static_cast<WSDPMTHitsCollection*>(hitsCollections->GetHC(0));  //
  aWDhits->DrawAllHits();
1 event per run.
then.
for the first run, nothing show until I input /vis/scene/add/hits
after the first event. All works fine whatever I input /vis/scene/add/hits or not
It seems the reason of lack of vis command.
Hi Chen Xu
If you ask the vis manager to draw hits (/vis/scene/add/hits), you don’t need a Draw in your EndOfEventAction.
