I am currently trying to read in particles from a input GENIE root file using Geant4 11.0.1. I have ActionInitialization defined and implemented. In my ActionInitialization::Build(), I call SetUserAction(new PrimaryGeneration);
void ActionInitialization::Build() const
SetUserAction(new RunAction);
SetUserAction(new EventAction);
SetUserAction(new TrackingAction);
SetUserAction(new SteppingAction);
At runtime, Geant4 complains with
*** G4Exception : Run0123
issued by : G4MTRunManager::SetUserAction()
For multi-threaded version, define G4VUserPrimaryGeneratorAction in G4VUserActionInitialization.
This shouldn’t happen because the ActionInitialization::SetUserAction() should handle things properly.
Any suggestions?
Dave
I’ve been trying to help Dave with this. In my simulation framework, with essentially the same Build() function (more like exampleB1’s), I do not see this error with Geant4 10.6 or 10.7.
Has the procedure for registering actions changed with the G4 11 release?
What you do in your ActionInitialization is correct.
Could you check if there still remains a code in your main() that instantiates PrimaryAction and sets directly to RunManager?
Thanks for the reply, Makoto! I’ve checked the version of main() that is “supposed” to be getting compiled, and it does have all the old SetUserAction() calls removed. I have a question out to Dave if there’s any chance that his build script is pick up the wrong source directory.
Has this been resolved? I am running into the same error. I am converting from v10 to v11 and running into this issue. This did not appear when running v10.
Sincerely,
Micah
If I remember correctly, we found that the build script was still picking up the source directory of v10. That being said, after running into many issues, in the interest of timeliness, we abandoned the switch to v11 and stuck with v10. I’m not sure if this issue was part of what was stopping our progress
