I’m very new to Geant4 and trying to run example B1. I encounter an error similar to this post. However the fixes of this topic don’t solve my issue, and the origin of the error is probably different as I haven’t had a previous installation of Geant4. I take these steps:
cmake -DGeant4_DIR=“/home/jur/Geant4/geant4_10_06-install/lib/Geant4-10.6.1” …/B1
make -j4
This gives no errors. Now running the application:
./exampleB1
gives error
Available UI session types: [ Qt, GAG, tcsh, csh ]
./exampleB1: symbol lookup error: /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4OpenGL.so: undefined symbol: _ZdlPvm, version Qt_5
The provided fix from the mentioned post (LD_LIBRARY_PATH=/home/jur/Geant4/geant4_10_06_p01-install/lib/ ./exampleB1) gives the exact same error.
My setup is as follows:
Geant4 10.6
Xubuntu 20.04 LTS
gcc 9.3.0
Geant4 is installed with the following options:
-DCMAKE_INSTALL_PREFIX=“/home/jur/Geant4/geant4_10_06_p01-install/”
-DCMAKE_PREFIX_PATH=“/opt/xerces-c/:/home/jur/Qt/5.12.8/gcc_64/:/usr/include/X11/”
-DGEANT4_USE_OPENGL_X11=ON
-DGEANT4_INSTALL_DATA=ON
-DGEANT4_USE_GDML=ON
-DGEANT4_USE_QT=ON
-DGEANT_USE_RAYTRACER_X11=ON
I will post the results of the ldd and readelf -d checks (again as asked in the other post) below.
Input: “ldd ./exampleB1”
Output :
linux-vdso.so.1 (0x00007ffc7bffb000)
libG4Tree.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4Tree.so (0x00007fe11e3b3000)
libG4GMocren.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4GMocren.so (0x00007fe11e367000)
libG4visHepRep.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4visHepRep.so (0x00007fe11e2cb000)
libG4RayTracer.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4RayTracer.so (0x00007fe11e29e000)
libG4VRML.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4VRML.so (0x00007fe11e282000)
libG4OpenGL.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4OpenGL.so (0x00007fe11e1e6000)
libG4interfaces.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4interfaces.so (0x00007fe11e150000)
libG4physicslists.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4physicslists.so (0x00007fe11df96000)
libG4FR.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4FR.so (0x00007fe11df7f000)
libG4vis_management.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4vis_management.so (0x00007fe11de67000)
libG4modeling.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4modeling.so (0x00007fe11dd63000)
libG4run.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4run.so (0x00007fe11dcd4000)
libG4event.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4event.so (0x00007fe11dc55000)
libG4tracking.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4tracking.so (0x00007fe11dc05000)
libG4analysis.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4analysis.so (0x00007fe11d6f2000)
libG4particles.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4particles.so (0x00007fe11d5cd000)
libG4geometry.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4geometry.so (0x00007fe11d2e9000)
libG4materials.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4materials.so (0x00007fe11d207000)
libG4intercoms.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4intercoms.so (0x00007fe11d197000)
libG4global.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4global.so (0x00007fe11d139000)
libG4clhep.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4clhep.so (0x00007fe11d096000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fe11cea1000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fe11ce86000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fe11cc92000)
libG4graphics_reps.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4graphics_reps.so (0x00007fe11cc49000)
libG4digits_hits.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4digits_hits.so (0x00007fe11cb7d000)
libG4zlib.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4zlib.so (0x00007fe11cb5f000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fe11ca10000)
libG4processes.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4processes.so (0x00007fe11825d000)
libG4gl2ps.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4gl2ps.so (0x00007fe11823f000)
libGL.so.1 => /lib/x86_64-linux-gnu/libGL.so.1 (0x00007fe1181b7000)
libX11.so.6 => /lib/x86_64-linux-gnu/libX11.so.6 (0x00007fe11807a000)
libXmu.so.6 => /lib/x86_64-linux-gnu/libXmu.so.6 (0x00007fe11805e000)
libQt5OpenGL.so.5 => /lib/x86_64-linux-gnu/libQt5OpenGL.so.5 (0x00007fe118000000)
libQt5Widgets.so.5 => /lib/x86_64-linux-gnu/libQt5Widgets.so.5 (0x00007fe117965000)
libQt5Gui.so.5 => /lib/x86_64-linux-gnu/libQt5Gui.so.5 (0x00007fe11737a000)
libQt5Core.so.5 => /lib/x86_64-linux-gnu/libQt5Core.so.5 (0x00007fe116e31000)
libG4track.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4track.so (0x00007fe116e0e000)
libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007fe116dde000)
/lib64/ld-linux-x86-64.so.2 (0x00007fe11e3db000)
libGLdispatch.so.0 => /lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007fe116d26000)
libGLX.so.0 => /lib/x86_64-linux-gnu/libGLX.so.0 (0x00007fe116cf2000)
libxcb.so.1 => /lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fe116cc8000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fe116cc0000)
libXt.so.6 => /lib/x86_64-linux-gnu/libXt.so.6 (0x00007fe116a57000)
libXext.so.6 => /lib/x86_64-linux-gnu/libXext.so.6 (0x00007fe116a42000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fe116a1f000)
libpng16.so.16 => /lib/x86_64-linux-gnu/libpng16.so.16 (0x00007fe1169e7000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fe1169cb000)
libharfbuzz.so.0 => /lib/x86_64-linux-gnu/libharfbuzz.so.0 (0x00007fe1168c4000)
libicui18n.so.66 => /lib/x86_64-linux-gnu/libicui18n.so.66 (0x00007fe1165c5000)
libicuuc.so.66 => /lib/x86_64-linux-gnu/libicuuc.so.66 (0x00007fe1163df000)
libpcre2-16.so.0 => /lib/x86_64-linux-gnu/libpcre2-16.so.0 (0x00007fe11635c000)
libdouble-conversion.so.3 => /lib/x86_64-linux-gnu/libdouble-conversion.so.3 (0x00007fe116346000)
libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007fe11621d000)
libXau.so.6 => /lib/x86_64-linux-gnu/libXau.so.6 (0x00007fe116215000)
libXdmcp.so.6 => /lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007fe11620d000)
libSM.so.6 => /lib/x86_64-linux-gnu/libSM.so.6 (0x00007fe116202000)
libICE.so.6 => /lib/x86_64-linux-gnu/libICE.so.6 (0x00007fe1161e4000)
libfreetype.so.6 => /lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007fe116125000)
libgraphite2.so.3 => /lib/x86_64-linux-gnu/libgraphite2.so.3 (0x00007fe1160f6000)
libicudata.so.66 => /lib/x86_64-linux-gnu/libicudata.so.66 (0x00007fe114635000)
libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007fe1145c2000)
libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007fe1145a8000)
libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007fe11459f000)
Input: “readelf -d ./exampleB1”
Output:
Dynamic section at offset 0xe7f0 contains 51 entries:
Tag Type Name/Value
0x0000000000000001 (NEEDED) Shared library: [libG4Tree.so]
0x0000000000000001 (NEEDED) Shared library: [libG4GMocren.so]
0x0000000000000001 (NEEDED) Shared library: [libG4visHepRep.so]
0x0000000000000001 (NEEDED) Shared library: [libG4RayTracer.so]
0x0000000000000001 (NEEDED) Shared library: [libG4VRML.so]
0x0000000000000001 (NEEDED) Shared library: [libG4OpenGL.so]
0x0000000000000001 (NEEDED) Shared library: [libG4interfaces.so]
0x0000000000000001 (NEEDED) Shared library: [libG4physicslists.so]
0x0000000000000001 (NEEDED) Shared library: [libG4FR.so]
0x0000000000000001 (NEEDED) Shared library: [libG4vis_management.so]
0x0000000000000001 (NEEDED) Shared library: [libG4modeling.so]
0x0000000000000001 (NEEDED) Shared library: [libG4run.so]
0x0000000000000001 (NEEDED) Shared library: [libG4event.so]
0x0000000000000001 (NEEDED) Shared library: [libG4tracking.so]
0x0000000000000001 (NEEDED) Shared library: [libG4analysis.so]
0x0000000000000001 (NEEDED) Shared library: [libG4particles.so]
0x0000000000000001 (NEEDED) Shared library: [libG4geometry.so]
0x0000000000000001 (NEEDED) Shared library: [libG4materials.so]
0x0000000000000001 (NEEDED) Shared library: [libG4intercoms.so]
0x0000000000000001 (NEEDED) Shared library: [libG4global.so]
0x0000000000000001 (NEEDED) Shared library: [libG4clhep.so]
0x0000000000000001 (NEEDED) Shared library: [libstdc++.so.6]
0x0000000000000001 (NEEDED) Shared library: [libgcc_s.so.1]
0x0000000000000001 (NEEDED) Shared library: [libc.so.6]
0x000000000000001d (RUNPATH) Library runpath: [/home/jur/Geant4/geant4_10_06_p01-install/lib:/home/jur/Qt/5.12.8/gcc_64/lib:/opt/xerces-c/lib:]
0x000000000000000c (INIT) 0x6000
0x000000000000000d (FINI) 0xb1d8
0x0000000000000019 (INIT_ARRAY) 0xf3c0
0x000000000000001b (INIT_ARRAYSZ) 64 (bytes)
0x000000000000001a (FINI_ARRAY) 0xf400
0x000000000000001c (FINI_ARRAYSZ) 8 (bytes)
0x000000006ffffef5 (GNU_HASH) 0x3a0
0x0000000000000005 (STRTAB) 0x15f0
0x0000000000000006 (SYMTAB) 0x3f0
0x000000000000000a (STRSZ) 8229 (bytes)
0x000000000000000b (SYMENT) 24 (bytes)
0x0000000000000015 (DEBUG) 0x0
0x0000000000000003 (PLTGOT) 0xfb60
0x0000000000000002 (PLTRELSZ) 2880 (bytes)
0x0000000000000014 (PLTREL) RELA
0x0000000000000017 (JMPREL) 0x4678
0x0000000000000007 (RELA) 0x3868
0x0000000000000008 (RELASZ) 3600 (bytes)
0x0000000000000009 (RELAENT) 24 (bytes)
0x000000000000001e (FLAGS) BIND_NOW
0x000000006ffffffb (FLAGS_1) Flags: NOW PIE
0x000000006ffffffe (VERNEED) 0x3798
0x000000006fffffff (VERNEEDNUM) 3
0x000000006ffffff0 (VERSYM) 0x3616
0x000000006ffffff9 (RELACOUNT) 76
0x0000000000000000 (NULL) 0x0
Input: ldd /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4OpenGL.so
Output:
linux-vdso.so.1 (0x00007ffeaf9ed000)
libG4gl2ps.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4gl2ps.so (0x00007f7f1cc7d000)
libG4interfaces.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4interfaces.so (0x00007f7f1cbe7000)
libG4vis_management.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4vis_management.so (0x00007f7f1cacf000)
libGL.so.1 => /lib/x86_64-linux-gnu/libGL.so.1 (0x00007f7f1ca33000)
libX11.so.6 => /lib/x86_64-linux-gnu/libX11.so.6 (0x00007f7f1c8f6000)
libXmu.so.6 => /lib/x86_64-linux-gnu/libXmu.so.6 (0x00007f7f1c8da000)
libQt5OpenGL.so.5 => /lib/x86_64-linux-gnu/libQt5OpenGL.so.5 (0x00007f7f1c87c000)
libQt5Widgets.so.5 => /lib/x86_64-linux-gnu/libQt5Widgets.so.5 (0x00007f7f1c1e1000)
libG4modeling.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4modeling.so (0x00007f7f1c0dd000)
libG4run.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4run.so (0x00007f7f1c050000)
libG4geometry.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4geometry.so (0x00007f7f1bd6c000)
libG4graphics_reps.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4graphics_reps.so (0x00007f7f1bd23000)
libG4intercoms.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4intercoms.so (0x00007f7f1bcb1000)
libG4global.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4global.so (0x00007f7f1bc53000)
libG4clhep.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4clhep.so (0x00007f7f1bbb0000)
libQt5Gui.so.5 => /lib/x86_64-linux-gnu/libQt5Gui.so.5 (0x00007f7f1b5c5000)
libQt5Core.so.5 => /lib/x86_64-linux-gnu/libQt5Core.so.5 (0x00007f7f1b07c000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f7f1ae9b000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f7f1ad4a000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f7f1ad2f000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f7f1ab3d000)
libG4zlib.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4zlib.so (0x00007f7f1ab1f000)
libG4event.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4event.so (0x00007f7f1aaa0000)
libG4tracking.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4tracking.so (0x00007f7f1aa50000)
libG4digits_hits.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4digits_hits.so (0x00007f7f1a982000)
libGLdispatch.so.0 => /lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007f7f1a8ca000)
libGLX.so.0 => /lib/x86_64-linux-gnu/libGLX.so.0 (0x00007f7f1a896000)
libxcb.so.1 => /lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f7f1a86c000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f7f1a866000)
libXt.so.6 => /lib/x86_64-linux-gnu/libXt.so.6 (0x00007f7f1a5fb000)
libXext.so.6 => /lib/x86_64-linux-gnu/libXext.so.6 (0x00007f7f1a5e6000)
libG4processes.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4processes.so (0x00007f7f15e35000)
libG4particles.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4particles.so (0x00007f7f15d10000)
libG4materials.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4materials.so (0x00007f7f15c30000)
/lib64/ld-linux-x86-64.so.2 (0x00007f7f1cd37000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f7f15c0d000)
libpng16.so.16 => /lib/x86_64-linux-gnu/libpng16.so.16 (0x00007f7f15bd3000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f7f15bb7000)
libharfbuzz.so.0 => /lib/x86_64-linux-gnu/libharfbuzz.so.0 (0x00007f7f15ab2000)
libicui18n.so.66 => /lib/x86_64-linux-gnu/libicui18n.so.66 (0x00007f7f157b3000)
libicuuc.so.66 => /lib/x86_64-linux-gnu/libicuuc.so.66 (0x00007f7f155cd000)
libpcre2-16.so.0 => /lib/x86_64-linux-gnu/libpcre2-16.so.0 (0x00007f7f1554a000)
libdouble-conversion.so.3 => /lib/x86_64-linux-gnu/libdouble-conversion.so.3 (0x00007f7f15532000)
libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f7f15409000)
libG4track.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4track.so (0x00007f7f153e6000)
libXau.so.6 => /lib/x86_64-linux-gnu/libXau.so.6 (0x00007f7f153e0000)
libXdmcp.so.6 => /lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f7f153d8000)
libSM.so.6 => /lib/x86_64-linux-gnu/libSM.so.6 (0x00007f7f153cb000)
libICE.so.6 => /lib/x86_64-linux-gnu/libICE.so.6 (0x00007f7f153ad000)
libG4analysis.so => /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4analysis.so (0x00007f7f14e9a000)
libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f7f14e6c000)
libfreetype.so.6 => /lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f7f14dad000)
libgraphite2.so.3 => /lib/x86_64-linux-gnu/libgraphite2.so.3 (0x00007f7f14d7e000)
libicudata.so.66 => /lib/x86_64-linux-gnu/libicudata.so.66 (0x00007f7f132bd000)
libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f7f1324a000)
libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f7f13230000)
libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007f7f13227000)
Input: readelf -d /home/jur/Geant4/geant4_10_06_p01-install/lib/libG4OpenGL.so
Output:
Dynamic section at offset 0x94990 contains 46 entries:
Tag Type Name/Value
0x0000000000000001 (NEEDED) Shared library: [libG4gl2ps.so]
0x0000000000000001 (NEEDED) Shared library: [libGL.so.1]
0x0000000000000001 (NEEDED) Shared library: [libX11.so.6]
0x0000000000000001 (NEEDED) Shared library: [libXmu.so.6]
0x0000000000000001 (NEEDED) Shared library: [libQt5OpenGL.so.5]
0x0000000000000001 (NEEDED) Shared library: [libQt5Widgets.so.5]
0x0000000000000001 (NEEDED) Shared library: [libG4graphics_reps.so]
0x0000000000000001 (NEEDED) Shared library: [libQt5Gui.so.5]
0x0000000000000001 (NEEDED) Shared library: [libQt5Core.so.5]
0x0000000000000001 (NEEDED) Shared library: [libm.so.6]
0x000000000000000e (SONAME) Library soname: [libG4OpenGL.so]
0x000000000000001d (RUNPATH) Library runpath: [/home/jur/Geant4/geant4_10_06_p01-install/lib]
0x000000000000000c (INIT) 0x2a000
0x000000000000000d (FINI) 0x7a3b0
0x0000000000000019 (INIT_ARRAY) 0x91b28
0x000000000000001b (INIT_ARRAYSZ) 208 (bytes)
0x000000000000001a (FINI_ARRAY) 0x91bf8
0x000000006ffffef5 (GNU_HASH) 0x2f0
0x0000000000000005 (STRTAB) 0xa9a0
0x0000000000000006 (SYMTAB) 0x1b50
0x000000000000000a (STRSZ) 63371 (bytes)
0x0000000000000003 (PLTGOT) 0x96000
0x0000000000000002 (PLTRELSZ) 21936 (bytes)
0x0000000000000017 (JMPREL) 0x24430
0x0000000000000007 (RELA) 0x1aea8
0x0000000000000008 (RELASZ) 38280 (bytes)
0x000000006ffffffe (VERNEED) 0x1ad08
0x000000006fffffff (VERNEEDNUM) 8
0x000000006ffffff0 (VERSYM) 0x1a12c
0x000000006ffffff9 (RELACOUNT) 221
Today I redid the installation once again and alas: it works! Not sure how to describe the fix or what changed since last installation, might be the installation of additional packages or simply the reinstall. Additional steps besides installation I did today:
- Rebuilt + installation of xerces-c 3.2.3
- Installed libx11-dev, xorg-dev and qtdeclarative5-dev packages
Everything seems to work fine now!
