Geant4 Version: 10.7.4 (but present in 11-Series)
Operating System: RHEL8, MacOS 10.15.7
Compiler/Version: GCC 12.2.0, Apple Clang 12.0.0
CMake Version: 3.24.3, 3.15.2
I’ve discovered that calling G4Exception
with FatalException
causes a segfault if we use /run/beamOn
without a primary generator. We have a Digitizer class which can operate without hits (to generate a detector response with test signals), so this should be a legitimate configuration.
However, we get a segfault in G4ExceptionHandler::DumpTrackInfo()
at the line
if(theStep->GetPreStepPoint()->GetPhysicalVolume())
and internally within GetPhysicalVolume()
, at
G4ReferenceCountedHandle<X>::operator->()
There is a test for theStep
being not null at the beginning of DumpTrackInfo()
, but unfortunately the step is always not null, but may be incomplete! The G4SteppingManager
constructor does this:
// Construct simple 'has-a' related objects
fStep = new G4Step();
fSecondary = fStep->NewSecondaryVector();
fPreStepPoint = fStep->GetPreStepPoint();
fPostStepPoint = fStep->GetPostStepPoint();
So whether or not there is actual tracking, G4SteppingManager::fStep
is not null, but won’t have valid touchables internally.
We’re using Geant4 10.7.4 in our experiment, but I’ve reviewed the classes in G4 11.2.1 and the issues are still present. We will probably institute a workaround, but I wanted to pass this on to both other users and the G4 developers.
