so, i already download the datasets manually and i already unpack it on
/home/prenaldi/geant4-v11.0.3/build/DATA
but, when i reconfigure Geant4 i got this output
[prenaldi@puspa02 build]$ ../../cmake-3.25.2/bin/cmake ../ -DGEANT4_INSTAL_DATADIR=/home/prenaldi/geant4-v11.0.3/build/DATA
-- Checking C++ feature CXXSTDLIB_FILESYSTEM_NATIVE - Failed
-- Checking C++ feature CXXSTDLIB_FILESYSTEM_STDCXXFS - Success
-- Checking C++ feature CXXSTDLIB_FILESYSTEM_CXXFS - Failed
-- Configuring download of missing dataset G4NDL (4.6)
CMake Warning (dev) at /home/prenaldi/cmake-3.25.2/Modules/ExternalProject.cmake:3075 (message):
The DOWNLOAD_EXTRACT_TIMESTAMP option was not given and policy CMP0135 is
not set. The policy's OLD behavior will be used. When using a URL
download, the timestamps of extracted files should preferably be that of
the time of extraction, otherwise code that depends on the extracted
contents might not be rebuilt if the URL changes. The OLD behavior
preserves the timestamps from the archive instead, but this is usually not
what you want. Update your project to the NEW behavior or specify the
DOWNLOAD_EXTRACT_TIMESTAMP option with a value of true to avoid this
robustness issue.
/home/prenaldi/cmake-3.25.2/Modules/ExternalProject.cmake:4185 (_ep_add_download_command)
cmake/Modules/G4InstallData.cmake:408 (ExternalProject_Add)
cmake/Modules/G4InstallData.cmake:309 (geant4_install_dataset)
cmake/Modules/G4InstallData.cmake:483 (geant4_configure_datasets)
cmake/Modules/G4CMakeMain.cmake:67 (include)
CMakeLists.txt:50 (include)
This warning is for project developers. Use -Wno-dev to suppress it.
-- Configuring download of missing dataset G4EMLOW (8.0)
robustness issue.
-- Configuring download of missing dataset PhotonEvaporation (5.7)
robustness issue.
-- Configuring download of missing dataset RadioactiveDecay (5.6)
robustness issue.
-- Configuring download of missing dataset G4PARTICLEXS (4.0)
robustness issue.
-- Configuring download of missing dataset G4PII (1.3)
robustness issue.
-- Configuring download of missing dataset RealSurface (2.2)
robustness issue.
-- Configuring download of missing dataset G4SAIDDATA (2.0)
robustness issue.
-- Configuring download of missing dataset G4ABLA (3.1)
robustness issue.
-- Configuring download of missing dataset G4INCL (1.0)
robustness issue.
-- Configuring download of missing dataset G4ENSDFSTATE (2.3)
robustness issue.
-- The following Geant4 features are enabled:
CMAKE_CXX_STANDARD: Compiling against C++ Standard '17'
GEANT4_BUILD_MULTITHREADED: Build multithread enabled libraries
GEANT4_BUILD_TLS_MODEL: Building with TLS model 'initial-exec'
-- Configuring done
-- Generating done
CMake Warning:
Manually-specified variables were not used by the project:
-- Build files have been written to: /home/prenaldi/geant4-v11.0.3/build
and when i try to give command make, i got this output
[prenaldi@puspa02 build]$ make -j16
[ 0%] Performing download step (download, verify and extract) for 'G4NDL'
[ 0%] Performing download step (download, verify and extract) for 'RadioactiveDecay'
[ 0%] Performing download step (download, verify and extract) for 'G4EMLOW'
[ 0%] Performing download step (download, verify and extract) for 'PhotonEvaporation'
[ 0%] Performing download step (download, verify and extract) for 'G4PARTICLEXS'
[ 0%] Performing download step (download, verify and extract) for 'G4PII'
[ 0%] Performing download step (download, verify and extract) for 'RealSurface'
[ 0%] Performing download step (download, verify and extract) for 'G4SAIDDATA'
[ 0%] Performing download step (download, verify and extract) for 'G4INCL'
[ 0%] Performing download step (download, verify and extract) for 'G4ABLA'
[ 0%] Performing download step (download, verify and extract) for 'G4ENSDFSTATE'
[ 0%] Built target G4tools
-- verifying file...
file='/home/prenaldi/geant4-v11.0.3/build/Externals/G4NDL-4.6/src/G4NDL.4.6.tar.gz'
-- MD5 hash of
does not match expected value
expected: 'd07e43499f607e01f2c1ce06d7a09f3e'
actual: 'd41d8cd98f00b204e9800998ecf8427e'
-- File already exists but hash mismatch. Removing...
-- Downloading...
dst='/home/prenaldi/geant4-v11.0.3/build/Externals/G4NDL-4.6/src/G4NDL.4.6.tar.gz'
timeout='1500 seconds'
inactivity timeout='none'
-- Using src='https://cern.ch/geant4-data/datasets/G4NDL.4.6.tar.gz'
CMake Error at /home/prenaldi/geant4-v11.0.3/build/Externals/G4NDL-4.6/src/G4NDL-stamp/download-G4NDL.cmake:170 (message):
Each download failed!
error: downloading 'https://cern.ch/geant4-data/datasets/G4NDL.4.6.tar.gz' failed
status_code: 1
status_string: "Unsupported protocol"
log:
--- LOG BEGIN ---
Protocol "https" not supported or disabled in libcurl
Closing connection -1
--- LOG END ---
file='/home/prenaldi/geant4-v11.0.3/build/Externals/G4EMLOW-8.0/src/G4EMLOW.8.0.tar.gz'
file='/home/prenaldi/geant4-v11.0.3/build/Externals/RadioactiveDecay-5.6/src/G4RadioactiveDecay.5.6.tar.gz'
-- MD5 hash of
expected: '6795805f39ac73a71333276756004d99'
-- MD5 hash of
expected: 'acc1dbeb87b6b708b2874ced729a3a8f'
-- Downloading...
dst='/home/prenaldi/geant4-v11.0.3/build/Externals/G4EMLOW-8.0/src/G4EMLOW.8.0.tar.gz'
-- Using src='https://cern.ch/geant4-data/datasets/G4EMLOW.8.0.tar.gz'
-- Downloading...
dst='/home/prenaldi/geant4-v11.0.3/build/Externals/RadioactiveDecay-5.6/src/G4RadioactiveDecay.5.6.tar.gz'
-- Using src='https://cern.ch/geant4-data/datasets/G4RadioactiveDecay.5.6.tar.gz'
file='/home/prenaldi/geant4-v11.0.3/build/Externals/PhotonEvaporation-5.7/src/G4PhotonEvaporation.5.7.tar.gz'
make[2]: *** [CMakeFiles/G4NDL.dir/build.make:99: Externals/G4NDL-4.6/src/G4NDL-stamp/G4NDL-download] Error 1
-- MD5 hash of
expected: '81ff27deb23af4aa225423e6b3a06b39'
file='/home/prenaldi/geant4-v11.0.3/build/Externals/G4PARTICLEXS-4.0/src/G4PARTICLEXS.4.0.tar.gz'
file='/home/prenaldi/geant4-v11.0.3/build/Externals/G4PII-1.3/src/G4PII.1.3.tar.gz'
-- Downloading...
dst='/home/prenaldi/geant4-v11.0.3/build/Externals/PhotonEvaporation-5.7/src/G4PhotonEvaporation.5.7.tar.gz'
-- MD5 hash of
expected: 'd82a4d171d50f55864e28b6cd6f433c0'
CMake Error at /home/prenaldi/geant4-v11.0.3/build/Externals/G4EMLOW-8.0/src/G4EMLOW-stamp/download-G4EMLOW.cmake:170 (message):
error: downloading 'https://cern.ch/geant4-data/datasets/G4EMLOW.8.0.tar.gz' failed
status_code: 1
log:
--- LOG BEGIN ---
--- LOG END ---
-- Using src='https://cern.ch/geant4-data/datasets/G4PhotonEvaporation.5.7.tar.gz'
file='/home/prenaldi/geant4-v11.0.3/build/Externals/RealSurface-2.2/src/G4RealSurface.2.2.tar.gz'
-- MD5 hash of
expected: '05f2471dbcdf1a2b17cbff84e8e83b37'
-- Downloading...
dst='/home/prenaldi/geant4-v11.0.3/build/Externals/G4PARTICLEXS-4.0/src/G4PARTICLEXS.4.0.tar.gz'
CMake Error at /home/prenaldi/geant4-v11.0.3/build/Externals/RadioactiveDecay-5.6/src/RadioactiveDecay-stamp/download-RadioactiveDecay.cmake:170 (message):
error: downloading 'https://cern.ch/geant4-data/datasets/G4RadioactiveDecay.5.6.tar.gz' failed
status_code: 1
log:
--- LOG BEGIN ---
--- LOG END ---
-- Using src='https://cern.ch/geant4-data/datasets/G4PARTICLEXS.4.0.tar.gz'
-- MD5 hash of
expected: 'ea8f1cfa8d8aafd64b71fb30b3e8a6d9'
make[1]: *** [CMakeFiles/Makefile2:855: CMakeFiles/G4NDL.dir/all] Error 2
-- Downloading...
dst='/home/prenaldi/geant4-v11.0.3/build/Externals/G4PII-1.3/src/G4PII.1.3.tar.gz'
make[1]: *** Waiting for unfinished jobs....
-- Using src='https://cern.ch/geant4-data/datasets/G4PII.1.3.tar.gz'
-- Downloading...
dst='/home/prenaldi/geant4-v11.0.3/build/Externals/RealSurface-2.2/src/G4RealSurface.2.2.tar.gz'
-- Using src='https://cern.ch/geant4-data/datasets/G4RealSurface.2.2.tar.gz'
file='/home/prenaldi/geant4-v11.0.3/build/Externals/G4SAIDDATA-2.0/src/G4SAIDDATA.2.0.tar.gz'
CMake Error at /home/prenaldi/geant4-v11.0.3/build/Externals/PhotonEvaporation-5.7/src/PhotonEvaporation-stamp/download-PhotonEvaporation.cmake:170 (message):
error: downloading 'https://cern.ch/geant4-data/datasets/G4PhotonEvaporation.5.7.tar.gz' failed
status_code: 1
log:
--- LOG BEGIN ---
--- LOG END ---
CMake Error at /home/prenaldi/geant4-v11.0.3/build/Externals/G4PARTICLEXS-4.0/src/G4PARTICLEXS-stamp/download-G4PARTICLEXS.cmake:170 (message):
error: downloading 'https://cern.ch/geant4-data/datasets/G4PARTICLEXS.4.0.tar.gz' failed
status_code: 1
log:
--- LOG BEGIN ---
--- LOG END ---
-- MD5 hash of
expected: 'd5d4e9541120c274aeed038c621d39da'
CMake Error at /home/prenaldi/geant4-v11.0.3/build/Externals/G4PII-1.3/src/G4PII-stamp/download-G4PII.cmake:170 (message):
error: downloading 'https://cern.ch/geant4-data/datasets/G4PII.1.3.tar.gz' failed
status_code: 1
log:
--- LOG BEGIN ---
--- LOG END ---
file='/home/prenaldi/geant4-v11.0.3/build/Externals/G4INCL-1.0/src/G4INCL.1.0.tar.gz'
-- Downloading...
dst='/home/prenaldi/geant4-v11.0.3/build/Externals/G4SAIDDATA-2.0/src/G4SAIDDATA.2.0.tar.gz'
make[2]: *** [CMakeFiles/G4EMLOW.dir/build.make:99: Externals/G4EMLOW-8.0/src/G4EMLOW-stamp/G4EMLOW-download] Error 1
CMake Error at /home/prenaldi/geant4-v11.0.3/build/Externals/RealSurface-2.2/src/RealSurface-stamp/download-RealSurface.cmake:170 (message):
error: downloading 'https://cern.ch/geant4-data/datasets/G4RealSurface.2.2.tar.gz' failed
status_code: 1
log:
--- LOG BEGIN ---
--- LOG END ---
-- Using src='https://cern.ch/geant4-data/datasets/G4SAIDDATA.2.0.tar.gz'
-- MD5 hash of
expected: '85fe937b6df46d41814f07175d3f5b51'
make[2]: *** [CMakeFiles/RadioactiveDecay.dir/build.make:99: Externals/RadioactiveDecay-5.6/src/RadioactiveDecay-stamp/RadioactiveDecay-download] Error 1
file='/home/prenaldi/geant4-v11.0.3/build/Externals/G4ABLA-3.1/src/G4ABLA.3.1.tar.gz'
-- Downloading...
dst='/home/prenaldi/geant4-v11.0.3/build/Externals/G4INCL-1.0/src/G4INCL.1.0.tar.gz'
-- MD5 hash of
expected: '180f1f5d937733b207f8d5677f76296e'
-- Using src='https://cern.ch/geant4-data/datasets/G4INCL.1.0.tar.gz'
make[1]: *** [CMakeFiles/Makefile2:881: CMakeFiles/G4EMLOW.dir/all] Error 2
make[1]: *** [CMakeFiles/Makefile2:933: CMakeFiles/RadioactiveDecay.dir/all] Error 2
-- Downloading...
dst='/home/prenaldi/geant4-v11.0.3/build/Externals/G4ABLA-3.1/src/G4ABLA.3.1.tar.gz'
file='/home/prenaldi/geant4-v11.0.3/build/Externals/G4ENSDFSTATE-2.3/src/G4ENSDFSTATE.2.3.tar.gz'
-- Using src='https://cern.ch/geant4-data/datasets/G4ABLA.3.1.tar.gz'
CMake Error at /home/prenaldi/geant4-v11.0.3/build/Externals/G4SAIDDATA-2.0/src/G4SAIDDATA-stamp/download-G4SAIDDATA.cmake:170 (message):
error: downloading 'https://cern.ch/geant4-data/datasets/G4SAIDDATA.2.0.tar.gz' failed
status_code: 1
log:
--- LOG BEGIN ---
--- LOG END ---
-- MD5 hash of
expected: '6f18fce8f217e7aaeaa3711be9b2c7bf'
make[2]: *** [CMakeFiles/PhotonEvaporation.dir/build.make:99: Externals/PhotonEvaporation-5.7/src/PhotonEvaporation-stamp/PhotonEvaporation-download] Error 1
-- Downloading...
dst='/home/prenaldi/geant4-v11.0.3/build/Externals/G4ENSDFSTATE-2.3/src/G4ENSDFSTATE.2.3.tar.gz'
-- Using src='https://cern.ch/geant4-data/datasets/G4ENSDFSTATE.2.3.tar.gz'
make[2]: *** [CMakeFiles/G4PARTICLEXS.dir/build.make:99: Externals/G4PARTICLEXS-4.0/src/G4PARTICLEXS-stamp/G4PARTICLEXS-download] Error 1
CMake Error at /home/prenaldi/geant4-v11.0.3/build/Externals/G4INCL-1.0/src/G4INCL-stamp/download-G4INCL.cmake:170 (message):
error: downloading 'https://cern.ch/geant4-data/datasets/G4INCL.1.0.tar.gz' failed
status_code: 1
log:
--- LOG BEGIN ---
--- LOG END ---
make[2]: *** [CMakeFiles/G4PII.dir/build.make:99: Externals/G4PII-1.3/src/G4PII-stamp/G4PII-download] Error 1
make[2]: *** [CMakeFiles/RealSurface.dir/build.make:99: Externals/RealSurface-2.2/src/RealSurface-stamp/RealSurface-download] Error 1
make[1]: *** [CMakeFiles/Makefile2:907: CMakeFiles/PhotonEvaporation.dir/all] Error 2
CMake Error at /home/prenaldi/geant4-v11.0.3/build/Externals/G4ABLA-3.1/src/G4ABLA-stamp/download-G4ABLA.cmake:170 (message):
error: downloading 'https://cern.ch/geant4-data/datasets/G4ABLA.3.1.tar.gz' failed
status_code: 1
log:
--- LOG BEGIN ---
--- LOG END ---
make[1]: *** [CMakeFiles/Makefile2:959: CMakeFiles/G4PARTICLEXS.dir/all] Error 2
make[1]: *** [CMakeFiles/Makefile2:985: CMakeFiles/G4PII.dir/all] Error 2
make[1]: *** [CMakeFiles/Makefile2:1011: CMakeFiles/RealSurface.dir/all] Error 2
CMake Error at /home/prenaldi/geant4-v11.0.3/build/Externals/G4ENSDFSTATE-2.3/src/G4ENSDFSTATE-stamp/download-G4ENSDFSTATE.cmake:170 (message):
error: downloading 'https://cern.ch/geant4-data/datasets/G4ENSDFSTATE.2.3.tar.gz' failed
status_code: 1
log:
--- LOG BEGIN ---
--- LOG END ---
make[2]: *** [CMakeFiles/G4SAIDDATA.dir/build.make:99: Externals/G4SAIDDATA-2.0/src/G4SAIDDATA-stamp/G4SAIDDATA-download] Error 1
make[1]: *** [CMakeFiles/Makefile2:1037: CMakeFiles/G4SAIDDATA.dir/all] Error 2
make[2]: *** [CMakeFiles/G4INCL.dir/build.make:99: Externals/G4INCL-1.0/src/G4INCL-stamp/G4INCL-download] Error 1
make[2]: *** [CMakeFiles/G4ABLA.dir/build.make:99: Externals/G4ABLA-3.1/src/G4ABLA-stamp/G4ABLA-download] Error 1
make[1]: *** [CMakeFiles/Makefile2:1089: CMakeFiles/G4INCL.dir/all] Error 2
make[2]: *** [CMakeFiles/G4ENSDFSTATE.dir/build.make:99: Externals/G4ENSDFSTATE-2.3/src/G4ENSDFSTATE-stamp/G4ENSDFSTATE-download] Error 1
make[1]: *** [CMakeFiles/Makefile2:1063: CMakeFiles/G4ABLA.dir/all] Error 2
make[1]: *** [CMakeFiles/Makefile2:1115: CMakeFiles/G4ENSDFSTATE.dir/all] Error 2
[ 0%] Built target G4zlib
[ 0%] Built target ptl-shared
[ 2%] Built target G4clhep
make: *** [Makefile:156: all] Error 2
so, am i missing something?
