The problem is in your application. When using G4TScoreNtupleWriter, there is no need to create G4AnalysisManager or G4TScoreHistFiller.
Creating G4AnalysisManager would be useful if you would have also analysis objects (histograms and/or ntuples) created in your code, in addition to those created automatically by the score ntuple writer.
G4TScoreHistFiller is useful when you want to let your primitive scorers fill
histograms, but in this case, you would need to create these histograms in your macro and assign them to you scorers. As none of these use cases apply to your application, you can remove these objects fron your RunAction.
Then, the G4TScoreNtupleWriter construction has to be moved to your main() (see also e.g. basic example B3a), as this class takes care of creating the analysis manager objects on master and workers:
int main(int argc,char** argv)
// ... skipped
G4VisManager *vis = new G4VisExecutive("quiet"); vis->Initialize();
G4TScoreNtupleWriter<G4AnalysisManager> scoreNtupleWriter;
scoreNtupleWriter.SetVerboseLevel(1);
scoreNtupleWriter.SetNtupleMerging(true);
if (argc==1) { // interactive mode
// ... skipped
After moving this class out of RunAction, there is no need to create the RunAction class at all, and you can remove it from your ActionInitialization.
After these changes, the empty output files (scoring.root from the first three runs) will be still deleted as empty, but without any warning, and the last output file, which was renamed to output.root in your run.mac, and which contains data, will be kept.
@ivana, thanks for the detailed explanation! Reading the code of G4TScoreHistFiller and G4TScoreNtupleWriter, I realize that both can create an analysis manager by themselves. However, since the analysis manager is a singleton, they will share the same analysis manager. Is that right?
I am OK with giving up G4AnalysisManager, but I can imagine that someone may want to create both histograms and ntuples in a single run. If we are not allowed to use G4TScoreHistFiller and G4TScoreNtupleWriter in parallel, how can we achieve this?
Last question, shall we use G4TScoreNtupleWriter<G4AnalysisManager> scoreNtupleWriter; or G4TScoreNtupleWriter<G4GenericAnalysisManager> scoreNtupleWriter;? I thought G4GenericAnalysisManager allows the user to switch in between root and hdf5 format. I’d like to keep that flexibility.
@ivana, I removed G4GenericAnalysisManager and G4TScoreHistFiller from the code, and the error message disappeared. The updated code can be found here: GitHub - jintonic/mingle: Mini Geant4 Learning Example. But I got some new error messages. I can open a new post to discuss that if they are not related.
Adding task 0 to task-group...
Adding task 1 to task-group...
Adding task 2 to task-group...
G4WT3 > /score/create/boxMesh mesh
Adding task 3 to task-group...
G4WT7 > /score/create/boxMesh mesh
Adding task 4 to task-group...
G4WT3 >
*** G4Exception : UIMAN0123
ERROR[/score/create/boxMesh] : Scoring mesh <mesh> already exists. Command ignored.
Error code : 1
Adding task 5 to task-group...
G4WT3 > /score/mesh/boxSize 4 1 1 cm
Adding task 6 to task-group...
Adding task 7 to task-group...
G4WT2 > /score/create/boxMesh mesh
Adding task 8 to task-group...
Adding task 9 to task-group...
G4WT7 >
Error code : 1
Adding task 10 to task-group...
Adding task 11 to task-group...
Adding task 12 to task-group...
Adding task 13 to task-group...
Adding task 14 to task-group...
G4WT7 > /score/mesh/boxSize 4 1 1 cm
Adding task 15 to task-group...
G4WT2 >
Error code : 1
G4WT3 >
ERROR: No mesh is currently open. Open/create a mesh first. Command ignored.
Error code : 1
You are allowed to create both G4AnalysisManager and G4TScoreNtupleWriter in parallel; G4TScoreNtupleWriter performs a check if there is already a file open via G4AnalysisManager, and in this case it does not call Open/CloseFile itself but relies on the user code. However this information about the file ownership is set only once, and it is not reset with CloseFile, what causes a failure in your use case, when OpenFile is called only for the third run. I will take a look at this and fix it. In meantime, if users need to have both G4AnalysisManager and G4TScoreNtupleWriter, they should call Open/CloseFile either in all runs or in none run.
G4AnalysisManager is defined in G4AnalysisManager.hh as another name for the G4GenericAnalysisManager via C++ using directive, so both ways are equivalent.
The warnings issued after /score/create/boxMesh mesh look like a bug; the messages happen when a scoring mesh is created only after processing a run.
It can be reproduced with the Geant4 extended example runAndEvent/RE03, if we add a code for one run processing in the beginning of run1.mac. I suggest you to open a bug report.
The warnings issued after /score/create/realWorldLogVol CsI (not shown in your post) seem to me justified, as they coplain about creating a new mesh while there is already existing one.
I see. This behavior is fine. I guess you just need to emphasize it somewhere in the developer’s manual. There is probably no need to change your code.
