Dear all,
I am trying to understand how to properly describe the surface properties of a scintillating crystal wrapped with Teflon, in order to correctly take into account optical photons behavior at the boundaries.
For this reason, I am following what is described in the “Optical Photon Processes” section of the “Book for Application Developers”, but I don’t quite understand the meaning of some parameter settings for the G4OpticalSurface in listing 66:
I had also a look at the example under:
examples/extended/optical/OpNovice
but I am left with the same doubts.
In particular, to what do the values of photon energies and rindex refer to?
const G4int NUM = 2;
G4double pp[NUM] = {2.038*eV, 4.144*eV};
G4double rindex[NUM] = {1.35, 1.40};
Why are there two values specified for each parameter? Are they referring to volume1 and volume2 respectively? I am confused about this, first of all because the rindex values would be already defined in the properties of the materials filling the two volumes, and secondly because they would be limited to just one value of the photon energy for each volume……so, there is something I am not getting!
Just to get a bit more concrete, in my particular setting I guess that groundbackpainted finish is what I am looking for: this is what I understand from fig. 17, with Teflon as wrapping. The two volumes, volume1 and volume2, would be the crystal and the experimental hall (filled with air), respectively. What is in this case the values I should specify for pp and rindex?
Any help would be very much appreciated!
Antonio
