G4ParticleChange compilation errors
I have a class to limit the global time of a track (geant4-11.1), as follows:
Code snippet
class TrackTimeLimiter : public G4VProcess {
	G4double maxTime;
	G4double limit;
	class ParticleChange : public G4ParticleChange {
	public:
	  ParticleChange() : G4ParticleChange() { }
	ParticleChange change;
public:
	TrackTimeLimiter(double _maxTime) :
			G4VProcess("TrackTimeLimiter",fUserDefined), change() {
		maxTime = _maxTime;
		limit = 0.0;
	G4VProcess *clone() { return new TrackTimeLimiter(*this); }
However, errors occur when compiling with geant4-11.1. Could you please take a look and figure out the problem?
Compilation errors
/home/g4bl/BLCMDphysics.cc: In member function ‘G4VProcess* TrackTimeLimiter::clone()’:
/home/g4bl/BLCMDphysics.cc:154:57: error: use of deleted function ‘TrackTimeLimiter::TrackTimeLimiter(const TrackTimeLimiter&)’
  154 |  G4VProcess *clone() { return new TrackTimeLimiter(*this); }
/home/g4bl/BLCMDphysics.cc:139:7: note: ‘TrackTimeLimiter::TrackTimeLimiter(const TrackTimeLimiter&)’ is implicitly deleted because the default definition would be ill-formed:
  139 | class TrackTimeLimiter : public G4VProcess {
/home/g4bl/BLCMDphysics.cc:139:7: error: use of deleted function ‘TrackTimeLimiter::ParticleChange::ParticleChange(const TrackTimeLimiter::ParticleChange&)’
/home/g4bl/BLCMDphysics.cc:142:8: note: ‘TrackTimeLimiter::ParticleChange::ParticleChange(const TrackTimeLimiter::ParticleChange&)’ is implicitly deleted because the default definition would be ill-formed:
  142 |  class ParticleChange : public G4ParticleChange {
/home/g4bl/BLCMDphysics.cc:142:8: error: use of deleted function ‘G4ParticleChange::G4ParticleChange(const G4ParticleChange&)’
In file included from /home/geant4-11.1.0-gcc9.3-c++17/include/Geant4/G4VProcess.hh:51,
                 from /home/geant4-11.1.0-gcc9.3-c++17/include/Geant4/G4VContinuousDiscreteProcess.hh:43,
                 from /home/geant4-11.1.0-gcc9.3-c++17/include/Geant4/G4VEnergyLossProcess.hh:54,
                 from /home/geant4-11.1.0-gcc9.3-c++17/include/Geant4/G4MuIonisation.hh:76,
                 from /home/g4bl/BLCMDphysics.cc:23:
/home/geant4-11.1.0-gcc9.3-c++17/include/Geant4/G4ParticleChange.hh:65:5: note: declared here
   65 |     G4ParticleChange(const G4ParticleChange& right) = delete;
Thanks,
Y
From 11.1, G4VParticleChange and concrete classes thereof have copy constructors and copy assignment operators marked as delete. This was done as these classes are intended to be owned per-process (@civanch can comment better), and processes are not copied.
The workaround in this case would be to hold the custom ParticleChange as a raw pointer, or better std::unique_ptr<ParticleChange>.
