I want to use G4PhantomParameterisation build a phantom(Geant4.11.0), and encounter the following problem:
When I run the same code in Geant4.10.06, I get the following prompt:
Why does this happen, and how can I solve it?
It is probably a precision problem, please see DICOM example Stuck Track error for small voxels
Thanks for your reply!I tried but there was a problem.
There is something wrong with this sentence…Maybe there should be an operator, right?
Of course, you have to put
100kCarTolerancestd::pow(10.,fNumberOfZeroSteps)
And you need to use the backquote (accent grave) to delimit code; otherwise the multiplication (asterisk) gets interpreted by the forum as “make this italics.” The full expression should be
Step += 100 * kCarTolerance * std::pow(10.,fNumberOfZeroSteps);
Thanks Michael, I did not realize of it
Thanks very much!
