G4RadioactiveDecayPhysics forces Auger electron production with zero production threshold
Geant4 Version: 11.4
Operating System: Ubuntu 22.04
Whenever I include G4RadioactiveDecayPhysics in my Physics list or just use a reference list like QGSP_BIC_HP where it’s included, Auger electron production is activated and the deexcitationIgnoreCut flag is set to true. Moreover, I can no longer control these settings using
UImanager->ApplyCommand("/process/em/auger false");
UImanager->ApplyCommand(“/process/em/deexcitationIgnoreCut false”);
or
G4EmParameters::Instance()->SetDeexcitationIgnoreCut(false);
before or after initialising the run manager. These settings appear to be overridden by G4RadioactiveDeacayPhysics, so regardless of my settings I always get a bunch of low energy-energy Auger electrons produced and Geant4 prints the following:
======                 Atomic Deexcitation Parameters          ========
Fluorescence enabled                               1
Directory in G4LEDATA for fluorescence data files  fluor
Auger electron cascade enabled                     1
PIXE atomic de-excitation enabled                  0
De-excitation module ignores cuts                  1
Type of PIXE cross section for hadrons             Empirical
Type of PIXE cross section for e+-                 Livermore
### ===  Deexcitation model UAtomDeexcitation is activated for 1 region:
          DefaultRegionForTheWorld  1  1  0
### ===  Auger flag: 1
### ===  Ignore cuts flag:   1
and further
======          Radioactive Decay Physics Parameters           =======
min MeanLife (from G4NuclideTable)                1 ns
Max life time (from G4DeexPrecoParameters)        1000 ps
Internal e- conversion flag                       1
Stored internal conversion coefficients           1
Enabled atomic relaxation mode                    1
Enable correlated gamma emission                  0
Max 2J for sampling of angular correlations       10
Atomic de-excitation enabled                      1
Auger electron emission enabled                   1
Check EM cuts disabled for atomic de-excitation   1
Use Bearden atomic level energies                 0
Use ANSTO fluorescence model                      0
Threshold for very long decay time at rest        1 y
This behaviour is different form an earlier Geant4 version 10.2, where Auger production was disabled by default and I could control it by setting the flags. I can still control it in version 11.4 if G4RadioactiveDecayPhysics is not included.
If this is the intended behaviour, I have two questions:
  1. Is there a reason why ‘/process/em/deexcitationIgnoreCut’ is enabled by default by G4RadioactiveDecayPhysics? I thought in the majority of use cases one wouldn’t want to produce and track locally absorbed particles.
  2. Is it still possible to override this behaviour and impose a cut or disable Auger electrons?
It may still be possible to override this after initialization. Please try:
/run/initialize
/run/physicsModified
/process/em/printParameters
G4RadioactiveDecayPhysics appears to force these settings during initialization, so the override may need to be done afterward…
It works. Many thanks!
