G4Region with a different physics list
Geant4 Version: 11.2
Operating System: linux el9
Compiler/Version: clang16
Good morning,
I would like to use the liste “Shielding” in the DefaultRegionForTheWorld and to use ideally G4EmLivermore + Pixe (+ Std Had Physics) in a G4Region (as Livermore ad Pixe are time consuming).
Is it possible without redefining all the Livermore processes ? Thank you
Corinne Goy
Hi Corinne,
provided that you already defined the G4Region in which you would like to alter the EM physics, you can use the following macro command, assuming your G4Region is named “MyRegionName”:
/process/em/AddEmRegion DefaultRegionForTheWorld G4EmStandard
/process/em/AddEmRegion MyRegionName G4EmLivermore
You also find a full list of parameter candidates here:
For switching on/off PIXE and other atomic deexcitation physics, you can use the following command (see above link for the order: Fluorescence, Auger, PIXE):
/process/em/deexcitation DefaultRegionForTheWorld false false false
/process/em/deexcitation MyRegionName true true true
Birgit
Hello Birgit,
Thanks for ideas and links.
Best regards, Corinne
