I am simulating geometry which is defined using G4TessellatedSolid (either reading STL with CADMesh or importing GDML file). The problem is (I guess) that the object structure is to fine and Geant gets stuck trying to transport particles through (the error log is below). I have checked, there no overlaps with other volumes.
So my questions are:
- Does this problem have significant consequences in my result?
- How could it be fixed?
Thank you in advance,
Vsevolod
The error log:
-------- WWWW ------- G4Exception-START -------- WWWW ------- *** G4Exception : GeomNav1002 issued by : G4Navigator::ComputeStep() Stuck Track: potential geometry or navigation problem. Track stuck, not moving for 10 steps. Current phys volume: 'world_volume_PV' - at position : (-20.38472008808071,-31.05675571523701,772.503479) in direction: (-0.03910943821135504,-0.1063828534623101,0.9935558063501058) (local position: (-20.38472008808071,-31.05675571523701,772.503479)) (local direction: (-0.03910943821135504,-0.1063828534623101,0.9935558063501058)). Previous phys volume: 'SCv8_Aluminum_PV' Likely geometry overlap - else navigation problem ! *** Trying to get *unstuck* using a push - expanding step to 1e-07 (mm) ... Potential overlap in geometry ! *** This is just a warning message. *** -------- WWWW -------- G4Exception-END --------- WWWW -------
