I would like to obtain the gamma spectra of the reaction Cl37(n,g) Cl38 and compare it with measured data from NNDC (CapGam - 37CL(N,G) E=THERMAL). To do so, I have started from the Geant4 Activation example (examples/extended/radioactivedecay/Activation · master · geant4 / geant4 · GitLab), and in the run.mac file I set
/testhadr/det/setIsotopeMat Cl37 17 37 2.48 g/cm3
/analysis/h1/set 4 800 0 8 MeV #energy spectrum of emerging gamma
And here is the energy spectrum that I obtained, compared with NNDC.
I also tried Ni60 and then again, the spectra do not correspond.
What am I doing wrong? I also tried different physics list for neutron precision transport, but it did not have any effect. Should I try to select the process radioActivation? I am using G4NDL4.7 and geant4.11.2.1.
Thank you so much!
Geant4 Version: geant4.11.2.1 Operating System: Rocky Linux 9 Compiler/Version: gcc version 11.4.1 CMake Version: cmake version 3.20.2
Thank you so much for taking the time to look into this.
I did exactly as you said, except that I replaced
with
/testhadr/det/setIsotopeMat Ni60 28 60 2.48 g/cm3
since I saw in a previous topic (Question in neutron capture (Gd155(n, gamma)Gd156) reaction - #6 by John_McFee) that NNDC data and Geant4 simulation were found to match for Ni60 activation.
However, using the example Hadr03 instead of Activation does not seem to work any better…
In the previous topic above (Question in neutron capture (Gd155(n, gamma)Gd156) reaction - #6 by John_McFee), I obtained good agreement for Ni60 when HP parameters were set as follows:
SetSkipMissingIsotopes( true );
SetDoNotAdjustFinalState( true );
SetUseOnlyPhotoEvaporation( true );
SetNeglectDoppler( true );
With SetDoNotAdjustFinalState( true ) and all the others were false, I got only fair agreement.
Also, the results in that thread were obtained for Geant4 10.7.2 with G4NDL4.6
I suggest setting the HP parameters appropriately in Hadr03.cc, recompile and try again.
thank you for your anwser. I specified in the mac file
/process/had/particle_hp/use_photo_evaporation true
/process/had/particle_hp/do_not_adjust_final_state true
/process/had/particle_hp/skip_missing_isotopes true
/process/had/particle_hp/neglect_Doppler_broadening true
as you suggested, but nothing changed.
I have also tried different physics lists, namely G4HadronPhysicsFTFP_BERT_HP, G4HadronPhysicsQGSP_BIC_HP, and G4HadronPhysicsQGSP_BERT_HP, but it makes very little difference.
I keep looking and I’m still very open to suggestions!
1- PhysicsList of Hadr03 does not include radioactive decay of Cl38 (see attachement for rdecay01: Cl38.mac.txt). This is a main difference with example Activation.
NNDC data correspond to Hadr03 situation.
2- Ni61 is stable. Therefore Hadr03 and Activation will give more on less similar spectrum.
Comparing with NNDC, as you noticed, gamma rays above 7 MeV are quasi missing in all Geant4 physics variants.
There is something going on that I do not understand. In Nov 2021 using Geant4 10.7.2 as mentioned in above thread (Question in neutron capture (Gd155(n, gamma)Gd156) reaction - #6 by John_McFee) I obtained good agreement between the NNDC database and Geant4 using a simple 25meV neutron beam geometry with a thin (1cm) 60Ni target in vacuum. The spectrum looked like the NNDC spectrum from their website (see NNDC spectrum above and my spectrum immediately following). For the top 36 out of 240 capture gamma rays from NNDC the energies agreed to within 2.2 ± 2.6 keV and the intensities (normalized to 100%) to within 0.810± 3.750 (see spectrum and screenshot of spreadsheet)
I used Physics list: QGSP_BERT_HP
HP parameters: SetSkipMissingIsotopes( true ); SetDoNotAdjustFinalState( true ); SetUseOnlyPhotoEvaporation( true ); SetNeglectDoppler( true );
If I changed all the parameters to false except: SetDoNotAdjustFinalState( true ) the spectrum was very different and there was a poor match to NNDC
Because of the current thread, I decided to rerun my identical code using Geant4 11.2.2, again with
The results were completely different from those of Geant4 10.7.2 with poor agreement between Geant and NNDC. I also varied the HP parameters but the results were very similar to one another.
I would expect that there are differences between G4NDL4.6 (from G4 10.7.2) and G4NDL4.7.1 (G4 11.2.2), but I would not have thought them to be that dramatic. Has something changed in the way the data bases are processed or am I missing something obvious? I am puzzled.
The variable G4NEUTRONHPDATA refers to either :
/usr/local/Geant4/geant4-v11.2.2/install/share/Geant4/data/G4NDL4.7.1
or
/usr/local/Geant4/geant4-v10.7.4/install/share/Geant4-10.7.4/data/G4NDL4.6
Does anyone understand this? In the future I will keep working with Geant4 v10.
Thanks! I also tried activation of N7 and Cl37 (still using the example Hadr03). With Geant4 v10, the gamma spectrum of N7 activation ~ matches NNDC data (peaks are at the same position, but not always same height, as you saw in the topic Question in neutron capture (Gd155(n, gamma)Gd156) reaction - #6 by John_McFee). With v11, activation of N7 does not compare to NNDC data. And for Cl37, both Geant4 v10 and v11 give the same spectrum, which is nothing like NNDC data. So I understand that unfortunately, Geant4 is not yet able to properly model activation…
“The results concerning the production of γ-rays have to be questioned always. For example, the information on the number and energies of γ-rays emitted in the neutron capture process is incomplete for almost all the nuclei and is frequently also uncorrelated. When the information is available, it will be used, but one can obtain results which are quite far from reality on an event by event basis: the total energy of the cascade won’t be correct in many cases and only some specific γ-rays which are stored in the neutron databases will be emitted. If there isn’t any information concerning these γ-rays, Geant4 will use a simple a model instead which is generally missing the relevant spectroscopic information.”
My approach to neutron capture processes now is to check each isotope I will use against the NNDC data base, using Hadr03, before I put it in a simulation of my own. It is tedious because you have to check it for several ParticleHP parameter settings and possibly different versions of Geant4 for each each isotope. If anyone has a better method, I would be delighted to hear it.
Please, be careful if you are using QGSP_BERT_HP, from the release notes [1], section 5, the only exception is when using QGSP_BERT_HP, for which there might be some changes in the physics results (validation is still on-going).
The NUDEX gamma de-excitation model is expected to give proper results, hopefully it will be present in the next release.
Unfortunately, I am not able to give an explanation to what you see.
Thank you. I was aware of the release note comment. My results with Hadr03 using 11.2.2 were all done with QGSP_BIC_HP.
I re-ran my results for my own code using QGSP_BIC_HP. (Previously I had used QGSP_BERT_HP with 11.2.2 to match conditions with my runs using 10.7.2.) Whether I used QGSP_BIC_HP or QGSP_BERT_HP made no difference either for 10.7.2 or 11.2.2.
I look forward to the NUDEX gamma de-excitation model becoming available.
