When I am install Gate, I met some error. I have no idea to solve it.
CMake Error at CMakeLists.txt:134 (MESSAGE):
ROOT has been compiled with cxx_std_14, please use cxx_std_17 as your
Geant4.
Can you help me?
Geant4.
Can you help me?
I’d suggest posting on the GATE forums/lists as this looks like an error message from their build scripts.
It looks like it’s checking that the ROOT and Geant4 installs have been compiled with different C++ standards. Given that ROOT used C++14, that generally determines the standard to use for all other packages. Check that your Geant4 install was compiled with C++14 or newer, and if needed, recompile and reinstall. I’m not sure why C++17 is being recommended for Geant4, but if that’s what GATE requires you should compile/install Geant4 with C++17.
Thank you for your reply. I have solved the problem. There’s no need to compile/install Geant4 with C++17. But, before the compilation of root, we need to activate the following flag during the cmake step: -DCMAKE_CXX_STANDARD = 17. I want to thank you again for your reply.
