Hello, I try to install Geant4 10.6 with the option -DGEANT4_USE_QT=ON (“cmake --DGEANT4_USE_QT=ON …”) during the cmake step. Here is what I get
-- Found EXPAT: /usr/lib64/libexpat.so (found version "2.2.7")
CMake Error at /usr/share/cmake/Modules/FindQt4.cmake:1314 (message):
Found unsuitable Qt version "5.12.6" from /usr/bin/qmake, this code
requires Qt 4.x
cmake/Modules/Geant4InterfaceOptions.cmake:117 (find_package)
cmake/Modules/G4CMakeMain.cmake:64 (include)
CMakeLists.txt:50 (include)
See also "/home/pamputt/geant4.10.06/build/CMakeFiles/CMakeOutput.log".
I removed the first lines. I am a bit lost because it is written in the release notes that Qt4 is deprecated. Here cmake finds my version of Qt5 but does not want to use it. Any hints on how to solve that? I would prefer using Qt5 and not installing Qt4.
Here is the output of “qmake -v”
QMake version 3.1
Using Qt version 5.12.6 in /usr/lib64
Actually, GEANT4 is looking for Qt using /usr/share/cmake/Modules/FindQt4.cmake that try to find either Qt3 or Qt4 (but not Qt5). Yet Qt5Config.cmake is located in /usr/lib64/cmake/Qt5. How to point to the good cmake file?
The fallback to Qt4 should only happen if one or more of the following Qt5 packages were not found:
Qt5Core
Qt5Gui
Qt5Widgets
Qt5OpenGL
Qt5PrintSupport
As I don’t know what system you’re running on, I can’t advise which packages supply these, but there should be directories for each under /usr/lib64/cmake, e.g. /usr/lib64/cmake/Qt5Core.
Problem solved, actually Qt5OpenGL was missing. I installed it and now cmake goes further. Thanks
Is it documented somewhere that all these packages are needed?
CMake Error at cmake/Modules/G4InterfaceOptions.cmake:143 (find_package):
By not providing “FindQt5OpenGL.cmake” in CMAKE_MODULE_PATH this project
has asked CMake to find a package configuration file provided by
“Qt5OpenGL”, but CMake did not find one.
Could not find a package configuration file provided by “Qt5OpenGL” with
any of the following names:
Qt5OpenGLConfig.cmake
qt5opengl-config.cmake
Add the installation prefix of “Qt5OpenGL” to CMAKE_PREFIX_PATH or set
“Qt5OpenGL_DIR” to a directory containing one of the above files. If
“Qt5OpenGL” provides a separate development package or SDK, be sure it has
been installed.
CMakeLists.txt:51 (include)
– Configuring incomplete, errors occurred!
See also “/home/lorgum25/geant4.10.07-build/CMakeFiles/CMakeOutput.log”.
See also “/home/lorgum25/geant4.10.07-build/CMakeFiles/CMakeError.log”.
I have also inspected CMakeCache.txt:
I looked at the path directories used for Qt on my system to look for Qt5OpenGL, and find a folder name ‘Qt5OpenGLExtensions’.
Perhaps you are able to assist with this. Thank you.
If set to ON, build Qt5 User Interface and Visualization drivers.Requires: Qt5 and OpenGL libraries and headers.See the CMAKE_PREFIX_PATH variable under Advanced Options if CMake has trouble locating Qt.
Your explanation of adding the installation path, based off the installation guide, is very clear, and I hope it is helpful to others.
I have realised my bigger issue was the way in which I was trying to install Qt5OpenGL, which was missing. I ended up messing up my system a lot, and had to get someone to help to restore it. We purged all of Qt in the process, and I am back at square one.
