Hello!
I try to use Geant4 -DNA.
After I building again geant411.2.2, I try to check if I have DNA data.
sarahabdelaziz@Sarahs-MacBook-Pro geant4-v11.2.2 % mkdir build
sarahabdelaziz@Sarahs-MacBook-Pro geant4-v11.2.2 % ls
CHANGELOG CONTRIBUTING.rst ReleaseNotes config packaging
CITATION.cff LICENSE build environments source
CMakeLists.txt README.rst cmake examples
sarahabdelaziz@Sarahs-MacBook-Pro geant4-v11.2.2 % cd build
sarahabdelaziz@Sarahs-MacBook-Pro build % ccmake ..
sarahabdelaziz@Sarahs-MacBook-Pro build % cmake ..
-- Checking C++ feature CXXSTDLIB_FILESYSTEM_NATIVE - Success
-- Reusing dataset G4NDL (4.7.1)
-- Reusing dataset G4EMLOW (8.5)
-- Reusing dataset PhotonEvaporation (5.7)
-- Reusing dataset RadioactiveDecay (5.6)
-- Reusing dataset G4PARTICLEXS (4.0)
-- Reusing dataset G4PII (1.3)
-- Reusing dataset RealSurface (2.2)
-- Reusing dataset G4SAIDDATA (2.0)
-- Reusing dataset G4ABLA (3.3)
-- Reusing dataset G4INCL (1.2)
-- Reusing dataset G4ENSDFSTATE (2.3)
-- The following Geant4 features are enabled:
CMAKE_CXX_STANDARD: Compiling against C++ Standard '17'
GEANT4_BUILD_MULTITHREADED: Build multithread enabled libraries
GEANT4_BUILD_TLS_MODEL: Building with TLS model 'initial-exec'
GEANT4_USE_GDML: Building Geant4 with GDML support
GEANT4_USE_OPENGL_X11: Build Geant4 OpenGL driver with X11 support
GEANT4_USE_RAYTRACER_X11: Build RayTracer driver with X11 support
GEANT4_USE_QT: Build Geant4 with Qt5 support
GEANT4_USE_QT3D: Build Geant4 Qt3D driver
-- Configuring done (1.4s)
-- Generating done (0.9s)
-- Build files have been written to: /Users/sarahabdelaziz/Downloads/geant4-v11.2.2/build
sarahabdelaziz@Sarahs-MacBook-Pro build % cmake -DGEANT4_USE_DNA=ON -DGEANT4_USE_DNACHEM=ON ..
-- Configuring done (1.5s)
-- Generating done (0.8s)
CMake Warning:
Manually-specified variables were not used by the project:
GEANT4_USE_DNA
GEANT4_USE_DNACHEM
Then,
sarahabdelaziz@Sarahs-MacBook-Pro build % make
[ 0%] Building CXX object source/externals/ptl/src/CMakeFiles/ptl-shared.dir/TaskGroup.cc.o
[ 0%] Building CXX object source/externals/ptl/src/CMakeFiles/ptl-shared.dir/TaskRunManager.cc.o
[ 0%] Building CXX object source/externals/ptl/src/CMakeFiles/ptl-shared.dir/ThreadData.cc.o
[ 0%] Building CXX object source/externals/ptl/src/CMakeFiles/ptl-shared.dir/ThreadPool.cc.o
[ 0%] Building CXX object source/externals/ptl/src/CMakeFiles/ptl-shared.dir/Threading.cc.o
[ 0%] Building CXX object source/externals/ptl/src/CMakeFiles/ptl-shared.dir/Timer.cc.o
[ 0%] Building CXX object source/externals/ptl/src/CMakeFiles/ptl-shared.dir/UserTaskQueue.cc.o
[ 0%] Building CXX object source/externals/ptl/src/CMakeFiles/ptl-shared.dir/VUserTaskQueue.cc.o
[ 0%] Linking CXX shared library ../../../../BuildProducts/lib/libG4ptl.dylib
[ 0%] Built target ptl-shared
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/AxisAngle.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/BasicVector3D.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/Boost.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/BoostX.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/BoostY.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/BoostZ.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/DoubConv.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/DualRand.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/EngineFactory.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/engineIDulong.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/erfQ.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/EulerAngles.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/Evaluator.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/flatToGaussian.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/gammln.cc.o
[ 0%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/JamesRandom.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/LorentzRotation.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/LorentzRotationC.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/LorentzRotationD.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/LorentzVectorB.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/LorentzVector.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/LorentzVectorC.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/LorentzVectorK.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/LorentzVectorL.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/LorentzVectorR.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/MixMaxRng.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/MTwistEngine.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/NonRandomEngine.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/Normal3D.cc.o
[ 1%] Building CXX object source/externals/clhep/CMakeFiles/G4clhep.dir/src/Plane3D.cc.o
At the end,
[ 90%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmDNAPhysics_option6.cc.o
[ 90%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmDNAPhysics_option7.cc.o
[ 90%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmDNAPhysics_option8.cc.o
[ 90%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmDNAPhysics_stationary.cc.o
[ 90%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmDNAPhysics_stationary_option2.cc.o
[ 90%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmDNAPhysics_stationary_option4.cc.o
[ 90%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmDNAPhysics_stationary_option6.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmDNAPhysicsActivator.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmLivermorePhysics.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmLivermorePolarizedPhysics.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmLowEPPhysics.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmModelActivator.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmParticleList.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmPenelopePhysics.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmStandardPhysics.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmStandardPhysicsGS.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmStandardPhysicsSS.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmStandardPhysicsWVI.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmStandardPhysics_option1.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmStandardPhysics_option2.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmStandardPhysics_option3.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4EmStandardPhysics_option4.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4GammaGeneralProcess.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4OpticalPhysics.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4ChemDissociationChannels.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/electromagnetic/src/G4ChemDissociationChannels_option1.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/factory/src/G4PhysicsConstructorRegistry.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/gamma_lepto_nuclear/src/G4BertiniElectroNuclearBuilder.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/gamma_lepto_nuclear/src/G4EmExtraPhysics.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/gamma_lepto_nuclear/src/G4EmMessenger.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/gamma_lepto_nuclear/src/G4LENDBertiniGammaElectroNuclearBuilder.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/gamma_lepto_nuclear/src/G4NeutrinoPhysics.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/gamma_lepto_nuclear/src/G4NeutrinoPhysicsMessenger.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_elastic/src/G4ChargeExchangeMessenger.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_elastic/src/G4ChargeExchangePhysics.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_elastic/src/G4HadronDElasticPhysics.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_elastic/src/G4HadronElasticPhysics.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_elastic/src/G4HadronElasticPhysicsHP.cc.o
[ 91%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_elastic/src/G4HadronElasticPhysicsHPT.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_elastic/src/G4HadronElasticPhysicsLEND.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_elastic/src/G4HadronElasticPhysicsXS.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_elastic/src/G4HadronHElasticPhysics.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_elastic/src/G4IonElasticPhysics.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_elastic/src/G4HadronElasticPhysicsPHP.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_elastic/src/G4HadronElasticPhysicsVI.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_elastic/src/G4ThermalNeutrons.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronInelasticQBBC.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronInelasticQBBC_ABLA.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsFTF_BIC.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsFTFP_BERT.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsFTFP_BERT_HP.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsFTFP_BERT_TRV.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsFTFP_BERT_ATL.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsFTFQGSP_BERT.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsNuBeam.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsQGS_BIC.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsQGSP_BERT.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsQGSP_BERT_HP.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsQGSP_BIC.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsQGSP_BIC_HP.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsQGSP_FTFP_BERT.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsINCLXX.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsShielding.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsShieldingLEND.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4VHadronPhysics.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/hadron_inelastic/src/G4HadronPhysicsQGSP_BIC_AllHP.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/ions/src/G4IonBinaryCascadePhysics.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/ions/src/G4IonINCLXXPhysics.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/ions/src/G4IonPhysics.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/ions/src/G4IonPhysicsPHP.cc.o
[ 92%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/ions/src/G4IonPhysicsXS.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/ions/src/G4IonQMDPhysics.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/ions/src/G4LightIonQMDPhysics.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/limiters/src/G4ImportanceBiasing.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/limiters/src/G4WeightWindowBiasing.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/limiters/src/G4GenericBiasingPhysics.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/limiters/src/G4FastSimulationPhysics.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/limiters/src/G4MaxTimeCuts.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/limiters/src/G4MinEkineCuts.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/limiters/src/G4NeutronTrackingCut.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/limiters/src/G4SpecialCuts.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/limiters/src/G4StepLimiterPhysics.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/limiters/src/G4ParallelWorldPhysics.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/limiters/src/G4UserSpecialCuts.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/stopping/src/G4StoppingPhysics.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/stopping/src/G4StoppingPhysicsFritiofWithBinaryCascade.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/constructors/stopping/src/G4StoppingPhysicsWithINCLXX.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/FTF_BIC.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/FTFP_BERT_ATL.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/FTFP_BERT.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/FTFP_BERT_HP.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/FTFP_BERT_TRV.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/FTFQGSP_BERT.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/G4PhysListFactoryAlt.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/G4PhysListFactory.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/G4PhysListFactoryMessenger.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/G4PhysListRegistry.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/LBE.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/NuBeam.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/QBBC.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/QBBC_ABLA.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/QGS_BIC.cc.o
[ 93%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/QGSP_BERT.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/QGSP_BERT_HP.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/QGSP_BIC_AllHP.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/QGSP_BIC.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/QGSP_BIC_HP.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/QGSP_BIC_HPT.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/QGSP_FTFP_BERT.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/lists/src/Shielding.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/util/src/G4HadParticles.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/util/src/G4HadProcesses.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/util/src/G4PhysListUtil.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4physicslists.dir/physics_lists/util/src/G4WarnPLStatus.cc.o
[ 94%] Linking CXX shared library ../BuildProducts/lib/libG4physicslists.dylib
[ 94%] Built target G4physicslists
[ 94%] Building CXX object source/CMakeFiles/G4readout.dir/readout/src/G4DCtable.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4readout.dir/readout/src/G4DMmessenger.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4readout.dir/readout/src/G4DigiManager.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4readout.dir/readout/src/G4VDigitizerModule.cc.o
[ 94%] Linking CXX shared library ../BuildProducts/lib/libG4readout.dylib
[ 94%] Built target G4readout
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4ArrowModel.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4AttFilterUtils.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4AxesModel.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4BoundingExtentScene.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4DigiFilterFactories.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4DigiModel.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4ElectricFieldModel.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4GPSModel.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4HitFilterFactories.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4HitsModel.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4LogicalVolumeModel.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4MagneticFieldModel.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4PlotterModel.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4Mesh.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4ModelingParameters.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4NullModel.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4PSHitsModel.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4PhysicalVolumeMassScene.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4PhysicalVolumeModel.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4PhysicalVolumesSearchScene.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4PseudoScene.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TextModel.cc.o
[ 94%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TouchablePropertiesScene.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TouchableUtils.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoriesModel.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoryChargeFilter.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoryDrawByAttribute.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoryDrawByCharge.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoryDrawByOriginVolume.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoryDrawByParticleID.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoryDrawByEncounteredVolume.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoryDrawerUtils.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoryFilterFactories.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoryGenericDrawer.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoryModelFactories.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoryOriginVolumeFilter.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoryParticleFilter.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4TrajectoryEncounteredVolumeFilter.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4VFieldModel.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4VModel.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4VTrajectoryModel.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4modeling.dir/visualization/modeling/src/G4VisTrajContext.cc.o
[ 95%] Linking CXX shared library ../BuildProducts/lib/libG4modeling.dylib
[ 95%] Built target G4modeling
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4GraphicsSystemList.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4PlotterManager.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4Scene.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4SceneHandlerList.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4SceneList.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VGraphicsSystem.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VSceneHandler.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VViewer.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VVisCommand.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4ViewParameters.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4ViewerList.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommands.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsCompound.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsGeometry.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsGeometrySet.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsMultithreading.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsSet.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsScene.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsSceneAdd.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsPlotter.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsSceneHandler.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsTouchable.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsTouchableSet.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsViewer.cc.o
[ 95%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsViewerDefault.cc.o
[ 96%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisCommandsViewerSet.cc.o
[ 96%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisManager.cc.o
[ 96%] Building CXX object source/CMakeFiles/G4vis_management.dir/visualization/management/src/G4VisStateDependent.cc.o
[ 96%] Linking CXX shared library ../BuildProducts/lib/libG4vis_management.dylib
[ 96%] Built target G4vis_management
[ 96%] Building CXX object source/CMakeFiles/G4FR.dir/visualization/FukuiRenderer/src/G4DAWNFILE.cc.o
[ 96%] Building CXX object source/CMakeFiles/G4FR.dir/visualization/FukuiRenderer/src/G4DAWNFILESceneHandler.cc.o
[ 96%] Building CXX object source/CMakeFiles/G4FR.dir/visualization/FukuiRenderer/src/G4DAWNFILEViewer.cc.o
[ 96%] Building CXX object source/CMakeFiles/G4FR.dir/visualization/FukuiRenderer/src/G4VisFeaturesOfDAWNFILE.cc.o
[ 96%] Linking CXX shared library ../BuildProducts/lib/libG4FR.dylib
[ 96%] Built target G4FR
[ 96%] Building CXX object source/CMakeFiles/G4visHepRep.dir/visualization/HepRep/src/G4HepRepFile.cc.o
[ 96%] Building CXX object source/CMakeFiles/G4visHepRep.dir/visualization/HepRep/src/G4HepRepFileSceneHandler.cc.o
[ 96%] Building CXX object source/CMakeFiles/G4visHepRep.dir/visualization/HepRep/src/G4HepRepFileViewer.cc.o
[ 96%] Building CXX object source/CMakeFiles/G4visHepRep.dir/visualization/HepRep/src/G4HepRepFileXMLWriter.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4visHepRep.dir/visualization/HepRep/src/G4HepRepMessenger.cc.o
[ 97%] Linking CXX shared library ../BuildProducts/lib/libG4visHepRep.dylib
[ 97%] Built target G4visHepRep
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RTJpegCoder.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RTJpegMaker.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RTMessenger.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RTOutBitStream.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RTPrimaryGeneratorAction.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RTRun.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RTRunAction.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RTSimpleScanner.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RTSteppingAction.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RTTrackingAction.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RTWorkerInitialization.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RayTracer.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RayTracerSceneHandler.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RayTracerViewer.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RayTrajectory.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RayTrajectoryPoint.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4TheMTRayTracer.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4TheRayTracer.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4VRTScanner.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RayTracerX.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RayTracerXViewer.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4RayTracer.dir/visualization/RayTracer/src/G4RTXScanner.cc.o
[ 97%] Linking CXX shared library ../BuildProducts/lib/libG4RayTracer.dylib
[ 97%] Built target G4RayTracer
[ 97%] Building CXX object source/CMakeFiles/G4Tree.dir/visualization/Tree/src/G4ASCIITree.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4Tree.dir/visualization/Tree/src/G4ASCIITreeMessenger.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4Tree.dir/visualization/Tree/src/G4ASCIITreeSceneHandler.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4Tree.dir/visualization/Tree/src/G4ASCIITreeViewer.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4Tree.dir/visualization/Tree/src/G4VTree.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4Tree.dir/visualization/Tree/src/G4VTreeSceneHandler.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4Tree.dir/visualization/Tree/src/G4VTreeViewer.cc.o
[ 97%] Linking CXX shared library ../BuildProducts/lib/libG4Tree.dylib
[ 97%] Built target G4Tree
[ 97%] Building CXX object source/CMakeFiles/G4VRML.dir/visualization/VRML/src/G4VRML2File.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4VRML.dir/visualization/VRML/src/G4VRML2FileSceneHandler.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4VRML.dir/visualization/VRML/src/G4VRML2FileViewer.cc.o
[ 97%] Linking CXX shared library ../BuildProducts/lib/libG4VRML.dylib
[ 97%] Built target G4VRML
[ 97%] Building CXX object source/CMakeFiles/G4GMocren.dir/visualization/gMocren/src/G4GMocrenFile.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4GMocren.dir/visualization/gMocren/src/G4GMocrenFileCTtoDensityMap.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4GMocren.dir/visualization/gMocren/src/G4GMocrenFileSceneHandler.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4GMocren.dir/visualization/gMocren/src/G4GMocrenFileViewer.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4GMocren.dir/visualization/gMocren/src/G4GMocrenIO.cc.o
[ 97%] Building CXX object source/CMakeFiles/G4GMocren.dir/visualization/gMocren/src/G4GMocrenMessenger.cc.o
[ 97%] Linking CXX shared library ../BuildProducts/lib/libG4GMocren.dylib
[ 97%] Built target G4GMocren
[ 97%] Built target G4ToolsSG_autogen_timestamp_deps
[ 97%] Automatic MOC for target G4ToolsSG
[ 98%] Building CXX object source/CMakeFiles/G4ToolsSG.dir/G4ToolsSG_autogen/mocs_compilation.cpp.o
[ 98%] Building CXX object source/CMakeFiles/G4ToolsSG.dir/visualization/ToolsSG/src/G4ToolsSGSceneHandler.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4ToolsSG.dir/visualization/ToolsSG/src/G4ToolsSGOffscreen.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4ToolsSG.dir/visualization/ToolsSG/src/G4ToolsSGX11GLES.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4ToolsSG.dir/visualization/ToolsSG/src/G4ToolsSGQtGLES.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4ToolsSG.dir/visualization/ToolsSG/src/G4ToolsSGQtGLESViewer.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4ToolsSG.dir/visualization/ToolsSG/src/G4ToolsSGQtZB.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4ToolsSG.dir/visualization/ToolsSG/src/G4ToolsSGQtZBViewer.cc.o
[ 98%] Linking CXX shared library ../BuildProducts/lib/libG4ToolsSG.dylib
[ 98%] Built target G4ToolsSG
[ 98%] Built target G4OpenGL_autogen_timestamp_deps
[ 98%] Automatic MOC for target G4OpenGL
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/G4OpenGL_autogen/mocs_compilation.cpp.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLImmediateViewer.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLImmediateSceneHandler.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLViewer.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLStoredViewer.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLStoredSceneHandler.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLFontBaseStore.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLSceneHandler.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLViewerMessenger.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLTransform3D.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4VisFeaturesOfOpenGL.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4gl2ps.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLImmediateX.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLImmediateXViewer.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLStoredX.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLStoredXViewer.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLXViewer.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLImmediateQt.cc.o
[ 98%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLImmediateQtViewer.cc.o
[100%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLQt.cc.o
[100%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLQtExportDialog.cc.o
[100%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLQtMovieDialog.cc.o
[100%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLQtViewer.cc.o
[100%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLStoredQt.cc.o
[100%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLStoredQtSceneHandler.cc.o
[100%] Building CXX object source/CMakeFiles/G4OpenGL.dir/visualization/OpenGL/src/G4OpenGLStoredQtViewer.cc.o
[100%] Linking CXX shared library ../BuildProducts/lib/libG4OpenGL.dylib
[100%] Built target G4OpenGL
[100%] Building CXX object source/CMakeFiles/G4visQt3D.dir/visualization/Qt3D/src/G4Qt3D.cc.o
[100%] Building CXX object source/CMakeFiles/G4visQt3D.dir/visualization/Qt3D/src/G4Qt3DSceneHandler.cc.o
[100%] Building CXX object source/CMakeFiles/G4visQt3D.dir/visualization/Qt3D/src/G4Qt3DUtils.cc.o
[100%] Building CXX object source/CMakeFiles/G4visQt3D.dir/visualization/Qt3D/src/G4Qt3DViewer.cc.o
[100%] Linking CXX shared library ../BuildProducts/lib/libG4visQt3D.dylib
[100%] Built target G4visQt3D
sarahabdelaziz@Sarahs-MacBook-Pro build % cat CMakeCache.txt | grep DNA
GEANT4_USE_DNA:UNINITIALIZED=ON
GEANT4_USE_DNACHEM:UNINITIALIZED=ON
sarahabdelaziz@Sarahs-MacBook-Pro build % cmake -LAH .. | grep DNA
sarahabdelaziz@Sarahs-MacBook-Pro build % ls
BuildProducts G4X11Shim.cmake _source_extras
CMakeCPackOptions.cmake Geant4Config.cmake cmake_install.cmake
CMakeCache.txt Geant4ConfigVersion.cmake cmake_uninstall.cmake
CMakeFiles Geant4LibraryDepends.cmake cmake_uninstall.cmake.in
CPackConfig.cmake Geant4PackageCache.cmake cxx_filesystem
CPackSourceConfig.cmake InstallTreeFiles geant4-config
G4EXPATShim.cmake LICENSE.txt geant4_module_check.py
G4FreetypeShim.cmake Makefile geant4_validate_sources.cmake
G4HDF5Shim.cmake Modules geant4make.csh
G4ModuleAdjacencyList.txt README.txt geant4make.sh
G4ModuleInterfaceMap.csv UseGeant4.cmake source
G4MotifShim.cmake UseGeant4_internal.cmake source_package_extras.cmake
sarahabdelaziz@Sarahs-MacBook-Pro build % cd ..
sarahabdelaziz@Sarahs-MacBook-Pro geant4-v11.2.2 % grep -r GEANT4_USE_DNA CMakeLists.txt
I try to find DNA data , but it says that
Could you help me to know to know if there is a problem to have Geant4-DNA processes from geant4.11.2.2, please @ivana @ngoc @bmorgan ?
Thanks
I also try to set DNA and DNACHEM in the file CMakefile.txt in geant4.11.2.2 and remove CMakeCache.txt and again cmake build, but it does not work.
bmorgan
September 27, 2024, 4:26pm
6
Sorry, but I’m a bit unclear on what you’re trying to set up here. GEANT4_USE_DNA and GEANT4_USE_DNACHEM are not CMake variables defined for any toolkit or example.
DNA physics models are built by the toolkit by default, and all core data that these use is in (@ngoc can correct me) the G4EMLOW dataset, which is already installed as indicated by:
ngoc
September 30, 2024, 10:03am
7
Yes, these variables are not defined. Shouldn’t use to configure
I mean to add Geant4-DNA if it is not , I know it should be there, but when I check there is not. I just try to solve this problem. Where should I see any thing related Geant4-DNA libraries or classes after building Geant4?
Also, Where should I write this command?
Thanks
@bmorgan @ngoc
I try to find this dataset.
sarahabdelaziz@Sarahs-MacBook-Pro ~ % cd Downloads/geant4-v11.2.2/build
sarahabdelaziz@Sarahs-MacBook-Pro build % echo $G4EMLOW
But I do not have any thing printed related to its path?
The build directory for geant4.11.2.2 contains
BuildProducts Geant4Config.cmake cmake_uninstall.cmake
CMakeCPackOptions.cmake Geant4ConfigVersion.cmake cmake_uninstall.cmake.in
CMakeCache.txt Geant4LibraryDepends.cmake cxx_filesystem
CMakeFiles Geant4PackageCache.cmake geant4-config
CPackConfig.cmake InstallTreeFiles geant4_module_check.py
CPackSourceConfig.cmake LICENSE.txt geant4_validate_sources.cmake
G4EXPATShim.cmake Makefile geant4make.csh
G4FreetypeShim.cmake Modules geant4make.sh
G4HDF5Shim.cmake README.txt install_manifest.txt
G4ModuleAdjacencyList.txt UseGeant4.cmake source
G4ModuleInterfaceMap.csv UseGeant4_internal.cmake source_package_extras.cmake
G4MotifShim.cmake _source_extras
G4X11Shim.cmake cmake_install.cmake
How can I find it, please?
system
Closed
November 4, 2024, 9:14am
10
