Hello experts. How can I calculate the absorbed dose in geant4? Which example file should I use for this?
If you want examples on how to get the absorbed dose (-> deposited energy per mass) then
example B1 does this with “custom” code and selfmade functions
examples/basic/B1 · master · geant4 / geant4 · GitLab (cern.ch)
As its README says “The energy deposited is collected step by step for a selected volume
in B1::SteppingAction…” and “Total dose deposited is computed at B1::RunAction::EndOfRunAction()”.
A different example is B4d, which explains Primitive Scorers
examples/basic/B4 · master · geant4 / geant4 · GitLab (cern.ch)
which are implemented Geant4-functions. You make a volume a Primitve Scorer/ add a Scorer to a volume in DetectorConstruction and do some histogram creation and filling in EventAction and RunAction. B4d uses G4PSEnergyDeposit
and G4PSTrackLength
but there is also a G4PSDoseDeposit
you can use.
There are many primitive scorer, see here:
Geant4: G4VPrimitiveScorer Class Reference (u-paris.fr)
You need to be a little bit cautious when using these scorers because i noticed G4PSEnergyDeposit
and G4PSDoseDeposit
don’t work for neutrons when you use a HighPrecision (…_HP) physics lists…
If those two examples dont work for you, read through the READMEs of the other examples. They usually mention what is scored.
Regards
Max
Thanks for the nice answer
