I have successfully built and run the example B1 with cmake through the terminal on my mac. It works fine.
Now I tried using Eclipse in order to build and run the projects more conveniently. I set the path to the include directory of Geant4 (also root6). But when I try to build the example I get the following error:
10:57:59 **** Incremental Build of configuration Default for project B1 ****
make all
Building file: ../src/B1ActionInitialization.cc
Invoking: GCC C++ Compiler
g++ -I/Users/.../Geant4_new/geant4-install/include/Geant4 -I/Users/.../root6.18/root6.18-install/include -O2 -g -Wall -c -fmessage-length=0 -MMD -MP -MF"src/B1ActionInitialization.d" -MT"src/B1ActionInitialization.o" -o "src/B1ActionInitialization.o" "../src/B1ActionInitialization.cc"
../src/B1ActionInitialization.cc:30:10: fatal error: 'B1ActionInitialization.hh' file not found
#include "B1ActionInitialization.hh"
1 error generated.
make: *** [src/B1ActionInitialization.o] Error 1
"make all" terminated with exit code 2. Build might be incomplete.
10:58:00 Build Failed. 2 errors, 0 warnings. (took 524ms)
What am I missing?
