Dear Users,
I want to talk about a compiling error. i am just beginner level user. I installed the Gean410.06 version issueless and i could compile the basic examples and i saw a repository of a LaBr3 in github via giglio(https://github.com/giglio0/DRAGON-G4-LaBr3.git) also giglio shared how to compline it with the code but i cannot compine it. The output;
make -DGEANT4_DIR=/home/cancan/Gatev9/geant4_10_06-install/lib/Geant4-10.6.3 /home/cancan/Gatev9/example_Geant4/LaBr/LaBr3
CMake Deprecation Warning at CMakeLists.txt:3 (cmake_minimum_required):
Compatibility with CMake < 2.8.12 will be removed from a future version of
CMake.
Update the VERSION argument value or use a … suffix to tell
CMake that the project does not need compatibility with older versions.
– The C compiler identification is GNU 9.3.0
– The CXX compiler identification is GNU 9.3.0
– Check for working C compiler: /usr/bin/cc - skipped
– Check for working CXX compiler: /usr/bin/c++ - skipped
– Found EXPAT: /usr/lib/x86_64-linux-gnu/libexpat.so (found suitable version “2.2.9”, minimum required is “2.2.9”)
– Found OpenGL: /usr/lib/x86_64-linux-gnu/libOpenGL.so
– Found X11: /usr/include
– Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so
– Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so - found
– Looking for gethostbyname
– Looking for gethostbyname - found
– Looking for connect
– Looking for connect - found
– Looking for remove
– Looking for remove - found
– Looking for shmat
– Looking for shmat - found
– Looking for IceConnectionNumber in ICE
– Looking for IceConnectionNumber in ICE - found
– Found Motif: /usr/lib/x86_64-linux-gnu/libXm.so
– Configuring done
– Generating done
CMake Warning:
Manually-specified variables were not used by the project:
GEANT4_DIR
– Build files have been written to: /home/cancan/Gatev9/example_Geant4/LaBr
cancan@cancan:~/Gatev9/example_Geant4/LaBr$ make
Scanning dependencies of target LaBr3_v4
[ 9%] Building CXX object CMakeFiles/LaBr3_v4.dir/LaBr3_v4.cc.o
[ 18%] Building CXX object CMakeFiles/LaBr3_v4.dir/src/DetectorConstruction.cc.o
[ 27%] Building CXX object CMakeFiles/LaBr3_v4.dir/src/DetectorMessenger.cc.o
[ 36%] Building CXX object CMakeFiles/LaBr3_v4.dir/src/EventAction.cc.o
[ 45%] Building CXX object CMakeFiles/LaBr3_v4.dir/src/HistoManager.cc.o
/home/cancan/Gatev9/example_Geant4/LaBr/LaBr3/src/HistoManager.cc:29:10: fatal error: TH1D.h: No such file or directory
29 | #include <TH1D.h>
compilation terminated.
make[2]: *** [CMakeFiles/LaBr3_v4.dir/build.make:134: CMakeFiles/LaBr3_v4.dir/src/HistoManager.cc.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:95: CMakeFiles/LaBr3_v4.dir/all] Error 2
make: *** [Makefile:149: all] Error 2
Can anybody help me?
