GEANT4 configuration warning
_Geant4 Version:_v11.2.2
_Operating System:_Linux Mint 21
_Compiler/Version:_11.3.0
_CMake Version:_3.22.1
I’m trying to install GEANT4 in my linux system and encountered the following warnings while configuring. I tried to ignore the warnings and went ahead with the installation and it lead to errors in running example projects.
The warnings message is as follows
CMake Warning at cmake/Modules/G4DeveloperAPI.cmake:1236 (add_library):
** Cannot generate a safe runtime search path for target G4FR because files in**
** some directories may conflict with libraries in implicit directories:**
** runtime library [libexpat.so.1] in /usr/lib/x86_64-linux-gnu may be hidden by files in:**
** /home/shyamvp/anaconda3/lib**
** Some of these libraries may not be found correctly.**
** Call Stack (most recent call first):**
** cmake/Modules/G4DeveloperAPI.cmake:963 (__geant4_add_library)**
** source/CMakeLists.txt:45 (geant4_compose_targets)**
** CMake Warning at cmake/Modules/G4DeveloperAPI.cmake:1236 (add_library):**
** Cannot generate a safe runtime search path for target G4visHepRep because**
** files in some directories may conflict with libraries in implicit**
** directories:**
** Cannot generate a safe runtime search path for target G4RayTracer because**
** directories:**
** Cannot generate a safe runtime search path for target G4Tree because files**
** in some directories may conflict with libraries in implicit directories:**
** Cannot generate a safe runtime search path for target G4VRML because files**
** Cannot generate a safe runtime search path for target G4GMocren because**
** directories:**
** Cannot generate a safe runtime search path for target G4ToolsSG because**
** directories:**
** Cannot generate a safe runtime search path for target G4OpenGL because**
** directories:**
** Cannot generate a safe runtime search path for target G4visQt3D because**
** directories: **
** Generating done**
What could be the possible solution to this?
Hi @Shyamvalliattuvp
I think by default, Geant4 will try to take the EXPAT library from the system, and it seems there is some problem related to the anaconda installation.
May you try configuring the Geant4 disabling such option? To do so, when configuring the cmake project, you can pass the following flag to cmake:
cmake -D GEANT4_USE_SYSTEM_EXPAT=OFF
Best,
Alvaro
