Geant4 Version:
Operating System:
We are simulating Bi@Cu core-shell nanoparticle radiosensitization using Geant4-DNA chemistry (option3, IRT model) with a single NP geometry.
Current status after debugging:
- Changing World from G4_WATER to G4_Galactic + nested water mother volume resolved the initial crash.
- Chemistry now works at low statistics (history=1000).
- Crash persists at history=2000+ when H2O2 molecules are injected via G4MoleculeGun in StackingAction.
Geometry:
- World: G4_Galactic
- WaterMother: large G4_WATER sphere containing everything
- NP: Bi core + Cu shell (nested inside WaterMother)
- Water shells: hollow G4Sphere volumes, nested inside WaterMother
- DNA region: single “WaterShells” region assigned to shell logical volumes
H2O2 injection:
- Done in StackingAction::NewStage() via G4MoleculeGun + DefineTracks()
- 20 molecules per event, injected into spherical shell around NP
What we tried:
- G4MoleculeCounter::ResetCounter() at BeginOfEventAction → no effect
- G4Scheduler::Instance()->Reset() at BeginOfEventAction → no effect
- Reducing endTimePs → no effect
- NTotalTrack = 0 at each event start (confirmed via debug log)
Crash location:
Run 0 starts.
DNAMolecularIRTModel will be used
[exit code -1073740940]
Question:
Is there a known issue with G4MoleculeGun injection combined with IRT model at higher event counts? Is there a correct way to reset IRT internal state between events?
Geant4 version: 11.1.3 | OS: Windows | Build: Release, MSVC
