Geant4-DNA molcounters example -> segmentation crash when moving the source
Geant4 Version: 11.4.0
Operating System: Ubuntu 24.04.3 LTS
Compiler/Version: gcc 13.3.0
CMake Version: 3.28.3
Dear Geant4 users,
I’ll try to explain my problem as clearly as possible, but I’m a little lost…
I’m discovering Geant4 and more precisely Geant4-DNA. I started from the example “molcounters-basic”. To the cell with its nucleus and mitochondria, I added a vesicle with in its inside a cluster of nanoparticles (NPs). The vesicle and the cluster are both placed randomly. The problem I encounter started when I tried to move the source from the center of the nucleus into the cluster of NPs. I obtained the following error message :
→ G4TaskRunManager::CreateAndStartWorkers() → Creating 2 tasks with 1 events/task…
G4WT0 > ### Run 0 starts on worker thread 0.
G4WT0 > ### Run 0 starts.
G4WT0 > → Event 0 starts with initial seeds (13049039,61775110).
G4WT0 > === Event 0 ===
G4WT0 > Vesicle center: (0.0021726,-0.00311178,-0.00473642)
G4WT0 > NanoCluster center: (0.00236337,-0.00285309,-0.00497114)
G4WT0 > Source local pos : (-3.77016e-05,2.90647e-05,2.44878e-05)
G4WT0 > Source global pos: (0.00232567,-0.00282403,-0.00494665)
Erreur de segmentation (core dumped)
If I understand correctly, the molcounters-basic example uses multi-threading. I tried in single-threading :
//auto* runManager = G4RunManagerFactory::CreateRunManager();
auto* runManager = new G4RunManager;
And the problem became the following :
G4VisManager: Using G4TrajectoryDrawByCharge as fallback trajectory model.
See commands in /vis/modeling/trajectories/ for other options.
Run 0 starts.
Run 0 starts.
→ Event 0 starts.
=== Event 0 ===
Vesicle center: (-0.00130582,-0.00266929,0.0042861)
NanoCluster center: (-0.00117777,-0.00233726,0.00410789)
Source local pos : (8.73874e-05,2.93046e-05,7.1352e-06)
Source global pos: (-0.00109038,-0.00230795,0.00411502)
DNAMolecularStepByStepModel will be used
*** G4Exception : G4MoleculeCounterTimeComparer
issued by : G4MoleculeCounterTimeComparer::operator()
Unknown comparison type
G4Track (0x5c2ddb65b1d0) - track ID = -52, parent ID = -3
Particle type : H3O - creator process : H2O_DNAMolecularDecay, creator model : Undefined
Kinetic energy : 38.5195 meV - Momentum direction : (5.00746e-310,-0.8651,0.45141)
Step length : 6.55902e-297 fm - total energy deposit : 7.38716 eV
Pre-step point : (-0.00118125,-0.00228721,0.004017) - Physical volume : Vesicle (G4_WATER)
  • defined by : e-_G4DNAVibExcitation - step status : 4
    Post-step point : (-0.00118125,-0.00228721,0.004017) - Physical volume : Vesicle (G4_WATER)
  • defined by : e-_G4DNAElectronSolvation - step status : 4
    *** Note: Step information might not be properly updated.
Abandon (core dumped)
The crash seems to be caused by the molecule counters. To confirm this I tried to comment out of the ActionInitialization.cc code each
BuildMoleculeCounters
or
BuildMultipleAndCustomMoleculeCounters
and in fact this way the problem disappeared.
Has someone any idea how to help me with this ?
Below are my DetectorConstruction.cc, PrimaryGeneratorAction.cc and MoleculeCounter.cc files.
Thank you very much!
Sarah
DetectorConstruction.cc :
  CLHEP::HepRandom::setTheEngine(new CLHEP::RanecuEngine);
  CLHEP::HepRandom::setTheSeed(time(nullptr));
  auto man = G4NistManager::Instance();
  auto water = man->FindOrBuildMaterial("G4_WATER");
  fAGuIX = Materials::CreateAGuIX();
  const G4double worldXYZ = 50 * um;
  auto solidWorld = new G4Box("World", 0.5 * worldXYZ, 0.5 * worldXYZ, 0.5 * worldXYZ);
  auto lvWorld = new G4LogicalVolume(solidWorld, water, "World");
  auto pvWorld =
    new G4PVPlacement(nullptr, G4ThreeVector(), lvWorld, "World", nullptr, false, 0, true);
  const auto worldVisAtt = new G4VisAttributes(G4Colour(.5, 1.0, .5));
  worldVisAtt->SetVisibility(true);
  worldVisAtt->SetForceWireframe(true);
  lvWorld->SetVisAttributes(worldVisAtt);
  auto lvCell = ConstructCell(pvWorld);
  auto lvVesicle = ConstructVesicle(lvCell);
  ConstructNanoCluster(lvVesicle);
  return pvWorld;
G4LogicalVolume* DetectorConstruction::ConstructCell(G4VPhysicalVolume* pvWorld)
  const G4double cellRadius = 7 * um;
  const G4double nucleusRadius = 4 * um;
  const G4int nMitochondria = 100;
  const G4double mitoA = 0.55 * micrometer;
  const G4double mitoB = 0.25 * micrometer;
  const G4double mitoC = 0.90 * micrometer;
  auto solidCell = new G4Orb("Cell", cellRadius);
  auto lvCell = new G4LogicalVolume(
    solidCell, G4NistManager::Instance()->FindOrBuildMaterial("G4_WATER"), "Cell");
  auto pvCell =
    new G4PVPlacement(nullptr, G4ThreeVector(), "Cell", lvCell, pvWorld, false, 0, true);
  auto cellVisAtt = new G4VisAttributes(G4Colour(0.0, 0.0, 1.0, 0.5));
  cellVisAtt->SetVisibility(false);
  lvCell->SetVisAttributes(cellVisAtt);
  auto solidNucleus = new G4Orb("Nucleus", nucleusRadius);
  auto lvNucleus = new G4LogicalVolume(
    solidNucleus, G4NistManager::Instance()->FindOrBuildMaterial("G4_WATER"), "Nucleus");
  new G4PVPlacement(nullptr, G4ThreeVector(), "Nucleus", lvNucleus, pvCell, false, 0, true);
  auto solidMito = new G4Ellipsoid("Mitochondria", mitoA, mitoB, mitoC);
  auto lvMito = new G4LogicalVolume(
    solidMito, G4NistManager::Instance()->FindOrBuildMaterial("G4_WATER"), "Mitochondria");
  for (auto i = 0; i < nMitochondria; ++i) {
    G4bool overlap = true;
    do {
      auto u = twopi * G4UniformRand();
      auto v = std::acos(2 * G4UniformRand() - 1);
      auto dr = G4UniformRand() * cellRadius;
      auto x = dr * std::cos(u) * std::sin(v);
      auto y = dr * std::sin(u) * std::sin(v);
      auto z = dr * std::cos(v);
      auto pos = G4ThreeVector(x, y, z);
      auto phi = G4UniformRand() * 2 * pi;
      auto psi = G4UniformRand() * 2 * pi;
      auto rot = new G4RotationMatrix();
      rot->rotateX(psi);
      rot->rotateY(phi);
      auto pvMito = new G4PVPlacement(rot, pos, "Mitochondria", lvMito, pvCell, false, i, false);
      overlap = pvMito->CheckOverlaps(1000, 0, false);
      if (overlap) {
        G4PhysicalVolumeStore::DeRegister(pvMito);
    } while (overlap);
  return lvCell;
G4LogicalVolume* DetectorConstruction::ConstructVesicle(G4LogicalVolume* lvCell)
    const G4double vesicleRadius = 0.5 * um;
    fVesicleRadius = vesicleRadius;
    auto solidVesicle = new G4Orb("Vesicle", vesicleRadius);
    auto lvVesicle = new G4LogicalVolume(
        solidVesicle,
        "Vesicle"
    auto vesicleVisAtt = new G4VisAttributes(G4Colour(1.0, 1.0, 0.0));
    vesicleVisAtt->SetVisibility(false);
    lvVesicle->SetVisAttributes(vesicleVisAtt);
    G4ThreeVector vesicle_pos;
    while (overlap)
        auto v = std::acos(2*G4UniformRand() - 1);
        auto r = G4UniformRand() * 7*um;
        vesicle_pos = G4ThreeVector(
            r * std::cos(u) * std::sin(v),
            r * std::sin(u) * std::sin(v),
            r * std::cos(v)
        G4PVPlacement* pvVesicle = new G4PVPlacement(nullptr, vesicle_pos, lvVesicle, "Vesicle", lvCell, false, 0, true);
        overlap = pvVesicle->CheckOverlaps(1000, 0, false);
        if (overlap)
            G4PhysicalVolumeStore::DeRegister(pvVesicle);
        else
          fVesiclePosition = vesicle_pos;
    return lvVesicle;
void DetectorConstruction::ConstructNanoCluster(G4LogicalVolume* lvVesicle)
  const G4double nanoClusterRadius = 100 * nm;
  fNanoClusterRadius = nanoClusterRadius;
  auto solidNanoCluster = new G4Orb("NanoCluster", nanoClusterRadius);
  auto lvNanoCluster = new G4LogicalVolume(solidNanoCluster, fAGuIX, "NanoCluster");
  auto nanoClusterVisAtt = new G4VisAttributes(G4Colour(1.0, 1.0, 0.0,0.2));
  nanoClusterVisAtt->SetForceSolid(true);
  lvNanoCluster->SetVisAttributes(nanoClusterVisAtt);
    double u = G4UniformRand();
    double v = G4UniformRand();
    double theta = std::acos(2.0*v - 1.0);
    double phi = 2.0 * CLHEP::pi * u;
  G4double margin = 2 * nm;
  double r = fVesicleRadius - nanoClusterRadius - margin;
    G4ThreeVector localPos(
        r * std::sin(theta) * std::cos(phi),
        r * std::sin(theta) * std::sin(phi),
        r * std::cos(theta)
    fNanoClusterPV = new G4PVPlacement(
        nullptr,
        localPos,
        lvNanoCluster,
        "NanoCluster",
        lvVesicle,
        false,
        0,
        true
    fNanoClusterLocalPosition = localPos;
PrimaryGeneratorAction.cc :
PrimaryGeneratorAction::PrimaryGeneratorAction() : G4VUserPrimaryGeneratorAction()
  G4int n_particle = 1;
  fParticleGun = std::make_unique<G4ParticleGun>(n_particle);
  // default particle kinematic
  G4ParticleTable* particleTable = G4ParticleTable::GetParticleTable();
  G4ParticleDefinition* particle = particleTable->FindParticle("e-");
  fParticleGun->SetParticlePosition(G4ThreeVector(0., 0., 0.));
  fParticleGun->SetParticleEnergy(100 * keV);
  fParticleGun->SetParticleMomentumDirection(G4ThreeVector(0., 0., 1.));
void PrimaryGeneratorAction::GeneratePrimaries(G4Event* anEvent)
    // 1) Récupérer la géométrie (position + rayon de la vésicule)
    auto det = static_cast<const DetectorConstruction*>(
        G4RunManager::GetRunManager()->GetUserDetectorConstruction());
    G4ThreeVector vesicleCenter = det->GetVesiclePosition();  // centre de la vésicule
    G4ThreeVector nanoClusterLocal = det->GetNanoClusterLocalPosition();
    G4ThreeVector clusterGlobal = vesicleCenter + nanoClusterLocal; // position globale du cluster
    G4double R = det->GetNanoClusterRadius();
    // 2) Tirage uniforme dans le volume d’une sphère
    //    (distribution volumique ∝ r²)
    G4double u = G4UniformRand();
    G4double v = G4UniformRand();
    G4double w = G4UniformRand();
    // pour une génération de source uniforme dans la vésicule
    G4double r     = R * std::cbrt(u);
    G4double theta = std::acos(2.0*v - 1.0);
    G4double phi   = CLHEP::twopi * w;
        r * std::cos(theta)
    // Position globale dans le repère du monde
    G4ThreeVector globalPos = clusterGlobal + localPos;
    G4cout << "=== Event " << anEvent->GetEventID() << " ===" << G4endl;
    G4cout << "Vesicle center: " << vesicleCenter << G4endl;
    G4cout << "NanoCluster center: " << clusterGlobal << G4endl;
    G4cout << "Source local pos : " << localPos << G4endl;
    G4cout << "Source global pos: " << globalPos << G4endl;
    // 2b) Écrire la position de la source dans un CSV
    static bool firstCall = true;
    std::ofstream outFile("SourcePositions.csv", std::ios::app);
    if (outFile.is_open()) {
        if (firstCall) {
            outFile << "EventID,X_um,Y_um,Z_um\n"; // header
            firstCall = false;
        outFile << anEvent->GetEventID() << ","
                << globalPos.x()/um << ","
                << globalPos.y()/um << ","
                << globalPos.z()/um << "\n";
        outFile.close();
    // 3) Direction isotrope
    G4double phiDir = CLHEP::twopi * G4UniformRand();
    G4double cosT   = 2.0 * G4UniformRand() - 1.0;
    G4double sinT   = std::sqrt(1.0 - cosT*cosT);
    G4ThreeVector dir(
        sinT * std::cos(phiDir),
        sinT * std::sin(phiDir),
        cosT
    // 4) Appliquer à la source
    fParticleGun->SetParticlePosition(globalPos);
    fParticleGun->SetParticleMomentumDirection(dir);
    // 5) Générer la particule
And MoleculeCounter.cc :
using G4VMoleculeCounterIndex = G4VMoleculeCounter::G4VMoleculeCounterIndex;
G4ThreadLocal std::unique_ptr<G4Navigator> MoleculeCounter::fNavigator = nullptr;
MoleculeCounter::MoleculeCounter(G4String name)
  : G4VUserMoleculeCounter(name, G4VMoleculeCounter::MoleculeCounterType::Other),
    fIgnoreMoleculePosition(false),
    fIgnoreCopyNumbers(true)
void MoleculeCounter::InitializeUser() {}
std::unique_ptr<G4VMoleculeCounterIndex> MoleculeCounter::BuildIndex(const G4Track* aTrack) const
  if (fVerbose > 1) {
    G4cout << "MoleculeCounter::BuildIndex(" << aTrack->GetTrackID() << " : "
           << GetMolecule(aTrack)->GetName() << ")" << G4endl;
  if (fIgnoreMoleculePosition) {
    return std::make_unique<MoleculeCounterIndex>(
      GetMolecule(aTrack)->GetMolecularConfiguration(), nullptr);
  else {
    const G4VTouchable* touchable = aTrack->GetNextTouchable();
    G4TouchableHistory* touchableHistory = nullptr;
    if (touchable == nullptr) touchable = aTrack->GetTouchable();
    if (touchable == nullptr) {
      auto touchableHandle = G4MoleculeLocator::Instance()->LocateMoleculeTrack(aTrack);
      touchable = touchableHandle();
      G4ExceptionDescription errMsg;
      errMsg << "Molecule scorer requires a valid volume pointer."
             << " G4Track->GetVolume: " << aTrack->GetVolume()
             << " G4Navigator->LocateGlobalPointAndUpdateTouchable: nullptr" << G4endl;
      G4Exception("MoleculeCounter::BuildIndex", "VOL_NOT_FOUND", FatalException, errMsg);
    // Création de la clé spatiale
    // Chaque ROS est compté selon son type, le volume où il se trouve
    auto index = std::make_unique<MoleculeCounterIndex>(
        GetMolecule(aTrack)->GetMolecularConfiguration(), touchable);
    delete touchableHistory;
    return index;
MoleculeCounter::BuildIndex(const G4Track* aTrack, const G4StepPoint* aStepPoint) const
      GetMolecule(aTrack)->GetMolecularConfiguration(), aStepPoint->GetTouchable());
MoleculeCounter::BuildSimpleIndex(const G4MolecularConfiguration* configuration) const
    configuration, nullptr);
G4bool MoleculeCounter::GetIgnoreMoleculePosition() const
  return fIgnoreMoleculePosition;
void MoleculeCounter::SetIgnoreMoleculePosition(G4bool flag)
  fIgnoreMoleculePosition = flag;
void MoleculeCounter::SetNegativeCountsAreFatal(G4bool flag)
  G4VMoleculeCounter::SetNegativeCountsAreFatal(flag);
  // this is protected in G4VMoleculeCounter and thus, must be exposed by the derived class
I find out what the problem is : the material on the cluster is not G4_WATER. If I change the material AGUIX to G4_WATER, then the problem disappears. Now I have to understand how to disable chemistry for the cluster only.
