Geant4_DNA;UHDR
_Geant4 Version:_11.3.0
_Operating System:_Ubuntu20.04
Dear friends:
When I was modifying the UHDR example, the following error message appeared:
*** G4Exception : InvalidParticlePosition
issued by : BoundedBrownianAction::GetDistanceToBoundary
Point is out of box: {50 um , -50 um , 10 um , -50 um , 50 um , -10 um , } of particle: e_aq (-8077): (1.28652e-05,-1.28872e-05,-0.010046)
*** Fatal Error In Argument *** core dump ***
G4WT0 > G4Track (0x7f6f6f379238) - track ID = 4795, parent ID = 2
G4WT0 > Particle type : e- - creator process : e-_G4DNAIonisation, creator model : model_DNA
G4WT0 > Kinetic energy : 25 meV - Momentum direction : (6.92268e-310,0.612245,-0.614956)
G4WT0 > Step length : 2.54317e-298 fm - total energy deposit : 3.58332 eV
G4WT0 > Pre-step point : (-2.33431e-07,2.29045e-07,-0.0299894) - Physical volume : Tissue (G4_WATER)
G4WT0 > - defined by : not available
G4WT0 > Post-step point : (-2.33431e-07,2.29045e-07,-0.0299894) - Physical volume : Tissue (G4_WATER)
G4WT0 > - defined by : e-_G4DNAElectronSolvation - step status : 4
G4WT0 > *** Note: Step information might not be properly updated.
G4WT0 >
G4WT0 >
G4WT0 > *** G4Exception: Aborting execution ***
Abandoned (core dumped)
I found that the reason was that the XY and Z sizes used in my model were not the same. May I ask if this example does not support cuboid modules, only cubes?
Best Wishes
Hu
Dear,
no, only cubes. This is because of mesoscopic model used in this example.
