_Geant4 Version:_9.2
_Operating System:_Sent-OS
_Compiler/Version:_gcc-11.2.0
Hello
I am new to using GEANT4 and GATE9.2. I am trying to run a simulation but my job crashes immediately when the simulation starts.
here is the error I am getting by looking at the log output file
Idle> /gate/application/setTimeSlice 1.00 s
Idle> /gate/application/setTimeStart 0.00 s
Idle> /gate/application/setTimeStop / 7000.00 s
Idle>
Idle> /gate/application/startDAQ
[Acquisition-0]
[Acquisition-0] ============= Source initialization =============
[Acquisition-0]
[Acquisition-0] ============= Acquisition starts! =============
[Acquisition-0] Simulation start time = 0 sec
[Acquisition-0] Simulation end time = 1 sec
[Acquisition-0] Simulation will have = 1 run(s)
[Acquisition-0] Slice 0 from 0 to 1 s [slice=1 s]
G4VisManager: Using G4TrajectoryDrawByCharge as fallback trajectory model.
See commands in /vis/modeling/trajectories/ for other options.
WARNING: Scene “none” not found. /vis/scene/list to see scenes.
When the simulation crashes it gives me an ‘std::bad_alloc’ error. More specifically this is what I get on my screen when the job crashes.
$ [G4-cerr] /: double value expected.
[G4-cerr] Parameter is wrong type and/or is not omittable (index 0)
terminate called after throwing an instance of ‘std::bad_alloc’
what(): std::bad_alloc
CAUGHT SIGNAL: 6 ### address: 0x19350000cfcb, signal = SIGABRT, value = 6, description = abort program (formerly SIGIOT).
Backtrace:
[PID=53195, TID=-2][ 0/22]> /lib64/libc.so.6(gsignal+0x37) [0x7f22c3873387]
[PID=53195, TID=-2][ 1/22]> /lib64/libc.so.6(abort+0x148) [0x7f22c3874a78]
[PID=53195, TID=-2][ 2/22]> /apps/gcc/gcc-11.2.0/lib64/libstdc++.so.6(+0x9c4ee) [0x7f22c3ec04ee]
[PID=53195, TID=-2][ 3/22]> /apps/gcc/gcc-11.2.0/lib64/libstdc++.so.6(+0xa7856) [0x7f22c3ecb856]
[PID=53195, TID=-2][ 4/22]> /apps/gcc/gcc-11.2.0/lib64/libstdc++.so.6(+0xa78c1) [0x7f22c3ecb8c1]
[PID=53195, TID=-2][ 5/22]> /apps/gcc/gcc-11.2.0/lib64/libstdc++.so.6(+0xa7b45) [0x7f22c3ecbb45]
[PID=53195, TID=-2][ 6/22]> /apps/gcc/gcc-11.2.0/lib64/libstdc++.so.6(+0x9c12b) [0x7f22c3ec012b]
[PID=53195, TID=-2][ 7/22]> Gate(ZNSt6vectorIP18G4VTrajectoryPointSaIS1_EE17_M_realloc_insertIJS1_EEEvN9__gnu_cxx17__normal_iteratorIPS1_S3_EEDpOT+0x11e) [0x8a432e]
[PID=53195, TID=-2][ 8/22]> /apps/geant4/geant4-11.0.3-gcc-11.2.0/lib64/libG4tracking.so(_ZN12G4Trajectory10AppendStepEPK6G4Step+0x105) [0x7f22e24d0675]
[PID=53195, TID=-2][ 9/22]> /apps/geant4/geant4-11.0.3-gcc-11.2.0/lib64/libG4tracking.so(_ZN17G4TrackingManager15ProcessOneTrackEP7G4Track+0x11a) [0x7f22e24cdf2a]
[PID=53195, TID=-2][10/22]> /apps/geant4/geant4-11.0.3-gcc-11.2.0/lib64/libG4event.so(_ZN14G4EventManager12DoProcessingEP7G4Event+0x88a) [0x7f22e27083fa]
[PID=53195, TID=-2][11/22]> /apps/geant4/geant4-11.0.3-gcc-11.2.0/lib64/libG4run.so(_ZN12G4RunManager15ProcessOneEventEi+0x25) [0x7f22e29b4115]
[PID=53195, TID=-2][12/22]> /apps/geant4/geant4-11.0.3-gcc-11.2.0/lib64/libG4run.so(_ZN12G4RunManager11DoEventLoopEiPKci+0x172) [0x7f22e29b4312]
[PID=53195, TID=-2][13/22]> /apps/geant4/geant4-11.0.3-gcc-11.2.0/lib64/libG4run.so(_ZN12G4RunManager6BeamOnEiPKci+0x5e) [0x7f22e29b1f0e]
[PID=53195, TID=-2][14/22]> Gate() [0x917ac7]
[PID=53195, TID=-2][15/22]> /apps/geant4/geant4-11.0.3-gcc-11.2.0/lib64/libG4intercoms.so(_ZN11G4UIcommand4DoItE8G4String+0x7bd) [0x7f22de64243d]
[PID=53195, TID=-2][16/22]> /apps/geant4/geant4-11.0.3-gcc-11.2.0/lib64/libG4intercoms.so(_ZN11G4UImanager12ApplyCommandEPKc+0xd70) [0x7f22de660fc0]
[PID=53195, TID=-2][17/22]> /apps/geant4/geant4-11.0.3-gcc-11.2.0/lib64/libG4interfaces.so(_ZN12G4UIterminal14ExecuteCommandERK8G4String+0x28) [0x7f22e39344d8]
[PID=53195, TID=-2][18/22]> /apps/geant4/geant4-11.0.3-gcc-11.2.0/lib64/libG4interfaces.so(_ZN12G4UIterminal12SessionStartEv+0x43) [0x7f22e3935ac3]
[PID=53195, TID=-2][19/22]> Gate() [0x4d0d50]
[PID=53195, TID=-2][20/22]> /lib64/libc.so.6(__libc_start_main+0xf5) [0x7f22c385f555]
[PID=53195, TID=-2][21/22]> Gate() [0x507a86]
: Aborted (Signal sent by tkill() 53195 6453)
have I forgotten to initialize any parameter. It seems to me that it is a memory allocation error but I am unable to figure out where it is coming from.
Could anyone suggest possible solution?
