I am using Geant4 10.4.2 to create a HitMap at a detector, where the particle hit position is stored in NTupleDColumns by the AnalysisManager. I created the HitMap with two approaches:
Do it directly in Geant4, like
 AnalysisManager->CreateH2(…)
 AnalysisManager->FillH2(0, StoredHit1->GetInteractionPosition().x(), StoredHit1->GetInteractionPosition().y())
On the other hand, I have a small C++ program to read the tracking data directly from a ROOT tree (where this exact data is written to by the Analysis Manager) AFTER the simulation and put it in a HitMap afterwards.
 TTree * trackingtree =(TTree*)file->Get(“Tracking”);
 trackingtree->SetBranchAddress(“D1X”, &x1);
 trackingtree->SetBranchAddress(“D1Y”, &y1);
 histoCounts1->Fill(x1,y1);
However, these two approaches lead to different results (but the number of tracks used is the same in both cases). In the case where I read the data from the ROOT file and put it into HitMaps afterwards is a lot more blurry. So far, I couldn’t find the reason for this problem - maybe someone already had the same issue and solved it? In advance, thank you very much for your help!
Regards, Stefanie
