I cannot seem to get install directory built. I have tried two methods:
I set up the environement following the first step in the link below.
https://twiki.cern.ch/twiki/bin/view/Main/G4Training
Then I continued installation using this:
Building and Installing from Source — Geant4 Installation Guide 10.7 documentation
And also downloaded cmake separately just in case.
I’ve tried both the methods separately but nothing seems to work I never get the install directory built. Here is what it looks like :
Blockquote
esh@work:/ cd /home/esh/Downloads/geant4.10.07-build
esh@work:~/Downloads/geant4.10.07-build cmake -DCMAKE_INSTALL_PREFIX=/home/esh/Downloads/geant4.10.07-install /home/esh/Downloads/geant4.10.07
– Found EXPAT: /usr/lib/x86_64-linux-gnu/libexpat.so (found version “2.2.9”)
– Pre-configuring dataset G4NDL (4.6)
– Pre-configuring dataset G4EMLOW (7.13)
– Pre-configuring dataset PhotonEvaporation (5.7)
– Pre-configuring dataset RadioactiveDecay (5.6)
– Pre-configuring dataset G4PARTICLEXS (3.1)
– Pre-configuring dataset G4PII (1.3)
– Pre-configuring dataset RealSurface (2.2)
– Pre-configuring dataset G4SAIDDATA (2.0)
– Pre-configuring dataset G4ABLA (3.1)
– Pre-configuring dataset G4INCL (1.0)
– Pre-configuring dataset G4ENSDFSTATE (2.3)
WARNING
Geant4 has been pre-configured to look for datasets
in the directory:
/home/esh/Downloads/geant4.10.07-install/share/Geant4-10.7.0/data
but the following datasets are NOT present on disk at
that location:
G4NDL (4.6)
G4EMLOW (7.13)
G4PARTICLEXS (3.1)
G4PII (1.3)
RealSurface (2.2)
G4SAIDDATA (2.0)
G4ABLA (3.1)
G4INCL (1.0)
G4ENSDFSTATE (2.3)
If you want to have these datasets installed automatically
simply re-run cmake and set the GEANT4_INSTALL_DATA
variable to ON. This will configure the build to download
and install these datasets for you. For example, on the
command line, do:
cmake -DGEANT4_INSTALL_DATA=ON <otherargs>
The variable can also be toggled in ccmake or cmake-gui.
If you're running on a Windows system, this is the best
solution as CMake will unpack the datasets for you
without any further software being required
Alternatively, you can install these datasets manually
now or after you have installed Geant4. To do this,
download the following files:
https://cern.ch/geant4-data/datasets/G4NDL.4.6.tar.gz
https://cern.ch/geant4-data/datasets/G4EMLOW.7.13.tar.gz
https://cern.ch/geant4-data/datasets/G4PhotonEvaporation.5.7.tar.gz
https://cern.ch/geant4-data/datasets/G4RadioactiveDecay.5.6.tar.gz
https://cern.ch/geant4-data/datasets/G4PARTICLEXS.3.1.tar.gz
https://cern.ch/geant4-data/datasets/G4PII.1.3.tar.gz
https://cern.ch/geant4-data/datasets/G4RealSurface.2.2.tar.gz
https://cern.ch/geant4-data/datasets/G4SAIDDATA.2.0.tar.gz
https://cern.ch/geant4-data/datasets/G4ABLA.3.1.tar.gz
https://cern.ch/geant4-data/datasets/G4INCL.1.0.tar.gz
https://cern.ch/geant4-data/datasets/G4ENSDFSTATE.2.3.tar.gz
and unpack them under the directory:
As we supply the datasets packed in gzipped tar files,
you will need the 'tar' utility to unpack them.
Nota bene: Missing datasets will not affect or break
compilation and installation of the Geant4
libraries.
– Looking for sys/types.h
– Looking for sys/types.h - found
– Looking for stdint.h
– Looking for stdint.h - found
– Looking for stddef.h
– Looking for stddef.h - found
– Check size of off64_t
– Check size of off64_t - done
– Looking for fseeko
– Looking for fseeko - found
– Looking for unistd.h
– Looking for unistd.h - found
– Looking for pthread.h
– Looking for pthread.h - found
– Performing Test CMAKE_HAVE_LIBC_PTHREAD
– Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
– Check if compiler accepts -pthread
– Check if compiler accepts -pthread - yes
– Found Threads: TRUE
– The following Geant4 features are enabled:
GEANT4_BUILD_CXXSTD: Compiling against C++ Standard ‘11’
– Configuring done
– Generating done
– Build files have been written to: /home/esh/Downloads/geant4.10.07-build
esh@work:~/Downloads/geant4.10.07-build$ cmake -DCMAKE_INSTALL_PREFIX=/home/esh/Downloads/geant4.10.07-install /home/esh/Downloads/geant4.10.07
WARNING
in the directory:
that location:
G4NDL (4.6)
G4EMLOW (7.13)
G4PARTICLEXS (3.1)
G4PII (1.3)
RealSurface (2.2)
G4SAIDDATA (2.0)
G4ABLA (3.1)
G4INCL (1.0)
G4ENSDFSTATE (2.3)
command line, do:
libraries.
– Configuring done
– Generating done
