I have tried multiple times but always fail on this step of Geant4 installation.
I have been trying to install Geant4 using both Windows and Ubuntu, following multiple tutorials. However, after running the make command, I encounter the following error and multiple errors when I was trying to download on Windows by Visual Studio:
TLSv1.3 (OUT), TLS alert, close notify (256): [2 bytes data] — LOG END —
make[2]: * [CMakeFiles/G4NDL.dir/build.make:99: Externals/G4NDL-4.7.1/src/G4NDL-stamp/G4NDL-download] Error 1
make[1]: * [CMakeFiles/Makefile2:932: CMakeFiles/G4NDL.dir/all] Error 2
make: * [Makefile:156: all] Error 2
I have already downloaded all 15 required Geant4 libraries and datasets from the official website, and they are saved on my hard drive. Could you help me with:
- How to direct Geant4 to these libraries and datasets during installation to avoid the error if this could help in the installation.
- Any suggestions to resolve the issue that arises after running
make.
Thanks in advance!
Sorry for the delay in replying! O.k, if you have the datasets downloaded already separately then:
Choose/create a suitable directory to hold the unpacked datasets. This doesn’t have to be anywhere specific, just somewhere you can read/write data from/to. For the sake of illustration (and don’t use this specific path), let’s say this is /my/datasets/location.
Unpack each dataset zip/tar.gz file in /my/datasets/location, so you should have directories like
/my/dataset/location/G4ABLA3.3
... etc ...
If you are still building/installing Geant4, then add the following to the CMake arguments:
$ cmake -DGEANT4_INSTALL_DATADIR=/my/dataset/location <otherargs>
This will configure the build/install to look for and use the pre-existing datasets in your chosen location.
If you have already installed Geant4, then you can point it to this location after installation by setting the environment variable GEANT4_DATA_DIR to, in this example, /my/dataset/location. You don’t need to do this if you set the path through the build/installtion process.
Edit: In regard to the issue with make, this could be due to a bad network connection. There’s usually no easy way to resolve this as it’s highly location/time dependent.
